Topic: client.available() returning strange data (Read 600 times) previous topic - next topic
Scott216
I thought client.available() is supposed to return the number of bytes available for reading.  See: http://arduino.cc/en/Reference/ClientAvailable
But when I use it like this:
Code: [Select]
  Serial.println(client.available());
I get stiff like this:
Code: [Select]
H344
T343
T342
P341
/340
1339
.338
1337
336
2335
Here's my entire skecth
Code: [Select]
#include <Ethernet.h>
#include <SPI.h>
long unsigned int time = 0;
byte mac[] = {  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] =  { 192, 168, 216, 50 };   // IP address of Ethernet Shield
char serverName[] = "api.pushingbox.com";
char url[] = "/pushingbox";
EthernetClient client; // create a client that connects to Google
boolean lastConnected = false; // State of the connection last time through the main loop
  Serial.println("Begin Setup");
  Ethernet.begin(mac, ip);
  delay(1000); // give the Ethernet shield a second to initialize
  Serial.print(F("My IP address: "));
  Serial.println(Ethernet.localIP());
  byte temp[4];
  static byte cnt;
  if ( millis() > time + 30000)
    client.connect(serverName, 80);
    temp[0] = cnt++;
    temp[1] = 61;
    temp[2] = 92;
    temp[3] = millis();
    char sensorTemp[10];
    char feedData[150];
    strcpy(feedData, "devid=vB************8A");   // removed real devid for forum post
    for(int i=0; i<4; i++)
      sprintf(sensorTemp, "&T%d=%d", i+1, temp[i]);
      strcat(feedData, sensorTemp);
    postRequest(serverName, url, feedData);
    time = millis();
  delay(100);
  // print the response from server
  // Should get HTTP/1.1 200 OK
  if (client.available())
    char c = client.read();
    Serial.print(c);
  // if there's no net connection, but there was one last time
  // through the loop, then stop the client:
  if (!client.connected() && lastConnected)
    Serial.println(F("disconnecting..."));
    client.stop();
  lastConnected = client.connected();
void postRequest(char *hostName, char *url, String feedData)
  String buf = "POST " + String(url) + " HTTP/1.1";
  Serial.println(F("Data sent to server: "));
  Serial.println(buf);
  Serial.println("Host: " + String(hostName));
  Serial.println("Content-Type: application/x-www-form-urlencoded");
  Serial.println("Content-Length: " + String(feedData.length()));
  Serial.println("");
  Serial.println(feedData);
  Serial.println("");
  Serial.println("");
  client.println(buf);
  client.println("Host: " + String(hostName));
  client.println("Content-Type: application/x-www-form-urlencoded");
  client.println("Content-Length: " + String(feedData.length()));
  client.println("");
  client.println(feedData);
  client.println("");
  client.println("");
SurferTim
You are printing both the input and the count. If I break it up like this...
Code: [Select]
H  344
T  343
T  342
P  341
/  340
1  339
.  338
1  337
   336
2  335
As you read the characters "HTTP/1.1", the count decreases.
Scott216
Thanks.  I didn't realize the remaining bytes from client.available() were getting mixed in with the  Serial.print(c); characters.  I see my mistake now.
