Topic: A/D sampling frequency (Read 5067 times) previous topic - next topic
DanRek
Since the Clock frequency is 84 MHz, I'd like to know if it is possibile to have an A/D sampling frequency of minimum 100KHz.
Thank you very much.
ralphnev
all the way up to 1M sample/sec
MarkT
That's what the hardware can support, analogRead() out of the box takes 39us
DanRek
Ok, then the maximum sampling rate is 1 MHz?
Gericom
Yes, but only under perfect conditions.
Subscribe my youtube channel: http://www.youtube.com/user/MKDS3
DanRek
How can I reach 100Ksps if the AnalogRead() takes 39us? ...
ralphnev
RTFM
      Search & Read the forums  - people have talked about this before
      may people have posted code (myself included)
     my favourite way is use the PDC
     others favour  tight loops after modifying the analog read command
     others rewrite the analog read
Gericom
Use native code. Take a look over here: http://asf.atmel.com/docs/latest/sam3x/html/group__sam__drivers__adc__group.html
DanRek
RTFM
May you link me the FM you say in "RTFM"? Thanks.
ralphnev
http://www.atmel.com/Images/doc11057.pdf
MarkT
For the record my previous timing for analogRead() was with 1.5.4.
I've now installed 1.5.5 and the speed has increased dramatically (as the release notes
state), getting between 2.0us and 3.3us for analogRead() now.
Interestingly the slower case was consecutive reads of analog pin 0, whereas
reading analog pins 0 to 9 in turn was quicker...  Done with an unrolled loop
of 10 consecutive analogreads.
DanRek
Very nice ... May you can give an example of your unrolled loop of 10 consecutive analogRead() code?
Thank u very much.
MarkT
You need an example of 10 analogRead()'s in a row?
DanRek
Yes ... You'd be very kind
