Author Topic: Cheap Oscilloscope  (Read 905 times)
Grenoble/Lyon - France
Hi
I'm thinking about buying an oscilloscope, and I saw some USB probes, really cheap (like 50 euros on eBay).
I'm pretty sure those items are just a lost of money ^^
I just wanted to know if anyone have any good reference for cheap oscilloscopes, USB or not.
My goal is to be able to analyze signals encoded via NE5044 or LM1871 for RC toys transmission. If I can do more, it's ok ^^
Thanks
melka
London
Have fun!
Hi melka, how about free?
At the relativly slow data rates of an RC decoder, you could use your computer sound card with some freely downloadable software to display the waveform.
Have a search on google for: sound card oscilloscope
That seems to be just perfect ^^
I'll check about the probes (I don't want to burn my soundcard) but I just tested quickly Virtins MultiInstruments.... That's nice ^^
I think I'll buy some of their probes, or I'll try to modify some regular oscilloscope probes.
Thanks mem
Thanks mem.  I've been looking for an affordable oscilloscope solution for a few days.  After a bit of reading this seems perfect.
Netherlands
How about a scope based on Arduino: http://accrochages.drone.ws/en/node/90
London
Have fun!
Nice!
Although a sound card would give better resolution (16 bits vs 10) and higher sampling rate (44khz vs around 10khz for the arduino),  but for relatively slow waveforms its nice to have a solution that's easy to customize. You would need to use a second board for the scope if the signal you wanted to measure was generated by an arduino, the scope board will be working flat out sampling and sending the data.
Netherlands
What are the limits of using a soundcard as an oscilloscope? 5V, 12V?
London
Have fun!
Sound cards take an audio input. This means the voltage should be less than  ±1 volt on the auxiliary input, but check the specs for your card. A voltage divider is usually used to drop the voltage into that range and a 10k pot works well for me.
I have to go check the electronics shops in my area and test it myself, but I think a simple classic Oscilloscope Probe with the x1/x10 selector might just work fine. There was a link posted, not so long ago, on this forum I think, a japanese guy who used this kind of cheap probe and just changed the BNC connector with a simple Jack.
Denver
Inactive - PM
Christian Zeitnitz has made a nice (free) sound card oscilloscope that's worth looking at -
http://zeitnitz.de/Christian/Scope/Scope_en.html .
As for limitations, besides the +/- 1V, my understanding is that the input signal must go through a capacitor on the sound card. This means no DC measurements and uncertain performance when viewing low freq. (<20Hz?) pulse streams. (From my experience with that scope.)
It would seem the Arduino scope would not need a coupling capacitor and not have that limitation, but I don't know.
Other than the frequency limitations common to sound card scopes, Christian's scope has often come in handy. It does a good job measuring frequency, and includes a wave form generator and other goodies.
FWIW
"Data is not information, information is not knowledge, knowledge is not understanding, understanding is not wisdom."
~ Clifford Stoll
New Jersey
Ard at work
The other downside to sound card oscilloscopes is that most cards are mono on mic input... so you only have channel on the scope.
I'd gladly pay $60 for a second channel when I'm working on stereo sound generation!
Mathieu
i have the rs232 version, $25, -- works great..
http://www.dataq.com/194.htm
Compact Data Acquisition Starter Kit
4-Channel, 10-Bit, ±10V ADC
Provided with a Serial Port Interface Cable
Two Digital Inputs For Remote Start/Stop and Remote Event Marker Control
Includes WinDaq/Lite Chart Recorder Software, WinDaq Waveform Browser Playback and Analysis Software, and Documentation
Provided ActiveX Controls allow you to program the DI-194 from any Windows programming environment
Kids - Get a free Data Acquisition Starter Kit for your Science Fair Project. Click here to learn more.
Working on a Science Fair Project? Considering a Science Fair Project from Bright Science? Click here for some very important information regarding science fair projects.
