Topic: Tracking of position and movement of a person? (Read 2388 times) previous topic - next topic
Pixelhook
Hello!
I'm looking for - with great interest ;) information for the following problem:
(in ARDUINO or Processing?)
- A person enters a room
- Whose position and movement is detected by sensors (PIR, Ultrasonic Parallax, Videocam?)
- And controls reasonably proportional to the movement of the person
- A servo or stepper motor
- Which in turn e.g. a camera (only horizontal) in the direction of the person moves / rotates and actionable.
Can anyone help me in the right direction?
Thanks for the tips and many thanks
newman
well i guess you want to move a camera in a single axis if it is so it is well within capabilities of arduino as richard said prepare a grid of sensors and check which one is triggered and move the camera in the +ve or -ve direction based on the postion of the sensor triggred it can be acheived using a servo
  :)                                        - hopethis helps
zoomkat
Probably the simplest setup might be have an Ir heat detector panned by a servo scan for something warmer than ambient. When a hot object is detected have the cam servo pan the cam to the same servo position where the IR servo detected the heat.
Pixelhook
thank you all for the prompt responses.  I would like to see that, and report the results...
