system
December 3, 2013, 4:21pm
1
Hi All,
I was trying to upload a bit of code and got this error:
avrdude: verification error, first mismatch at byte 0x0086
0x04 != 0x44
I'm still very new to arduino and have no idea how to fix this. I've searched the forum and found nothing helpful other than it might need to be told to wipe the previous code before uploading the new code and isn't, which is causing the problem. Is this the case and if so, how can I solve it? I know the code I'm uploading is fine and working as I have uploaded it to another board and it works fine.
Thanks in advance!
Jack
system
December 3, 2013, 9:51pm
3
Hi Coding Badly,
Thanks for moving my post, I'm still finding my way around on here!
Its an Arduino Uno board. I've got three of them and the code works fine on the other two but I need them for other projects so I really need to find out whats wrong with this one
Thanks again,
Jack
Post the verbose output. Please use
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags.
system
December 4, 2013, 2:35pm
5
Hi Coded Badly,
Is this what you mean?
Binary sketch size: 5,020 bytes (of a 32,256 byte maximum)
0x04 != 0x44
avrdude: verification error; content mismatch
Or something else? Sorry, I'm not the best at this.
Thanks again,
Jack
system
December 4, 2013, 2:59pm
6
Hi Coding Badly,
Sorry, got what you wanted.
PART 1:
Binary sketch size: 466 bytes (of a 32,256 byte maximum)
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P/dev/tty.usbmodem1421 -b115200 -D -Uflash:w:/var/folders/68/t83q_vns5k36c1k18pzd08pc0000gp/T/build1433395646767163271.tmp/sketch_dec04a.cpp.hex:i
avrdude: Version 5.11, compiled on Sep 2 2011 at 18:52:52
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/jacktomkins/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/tty.usbmodem1421
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
avrdude: Send: A [41] . [80] [20]
avrdude: Recv: . [03]
avrdude: Send: A [41] . [81] [20]
avrdude: Recv: . [04]
avrdude: Send: A [41] . [82] [20]
avrdude: Send: A [41] . [98] [20]
Hardware Version: 3
Firmware Version: 4.4
avrdude: Send: A [41] . [84] [20]
avrdude: Send: A [41] . [85] [20]
avrdude: Send: A [41] . [86] [20]
avrdude: Send: A [41] . [87] [20]
avrdude: Send: A [41] . [89] [20]
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: Send: B [42] . [86] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] . [80] . [04] . [00] . [00] . [00] . [80] . [00] [20]
avrdude: Send: E [45] . [05] . [04] . [d7] . [c2] . [00] [20]
avrdude: Send: P [50] [20]
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Send: u [75] [20]
avrdude: Recv: . [14] . [1e] . [95] . [0f] . [10]
################################################## | 100% 0.00s
Thanks again,
Jack
system
December 4, 2013, 3:00pm
7
PART 2:
avrdude: Device signature = 0x1e950f
avrdude: Send: V [56] . [a0] . [03] . [fc] . [00] [20]
avrdude: Recv: . [00]
avrdude: Send: V [56] . [a0] . [03] . [fd] . [00] [20]
avrdude: Send: V [56] . [a0] . [03] . [fe] . [00] [20]
avrdude: Send: V [56] . [a0] . [03] . [ff] . [00] [20]
avrdude: reading input file "/var/folders/68/t83q_vns5k36c1k18pzd08pc0000gp/T/build1433395646767163271.tmp/sketch_dec04a.cpp.hex"
avrdude: writing flash (466 bytes):
Writing | avrdude: Send: U [55] . [00] . [00] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [0c] . [94] 4 [34] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] d [64] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [11] $ [24] . [1f] . [be] . [cf] . [ef] . [d8] . [e0] . [de] . [bf] . [cd] . [bf] . [11] . [e0] . [a0] . [e0] . [b1] . [e0] . [e2] . [ed] . [f1] . [e0] . [02] . [c0] [20]
#############avrdude: Send: U [55] @ [40] . [00] [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [05] . [90] . [0d] . [92] . [a0] 0 [30] . [b1] . [07] . [d9] . [f7] . [11] . [e0] . [a0] . [e0] . [b1] . [e0] . [01] . [c0] . [1d] . [92] . [a9] 0 [30] . [b1] . [07] . [e1] . [f7] . [0e] . [94] U [55] . [00] . [0c] . [94] . [e7] . [00] . [0c] . [94] . [00] . [00] . [08] . [95] . [08] . [95] . [cf] . [93] . [df] . [93] . [0e] . [94] . [ac] . [00] . [0e] . [94] S [53] . [00] . [c0] . [e0] . [d0] . [e0] . [0e] . [94] T [54] . [00] [20] . [97] . [e1] . [f3] . [0e] . [94] . [00] . [00] . [f9] . [cf] . [1f] . [92] . [0f] . [92] . [0f] . [b6] . [0f] . [92] . [11] $ [24] / [2f] . [93] ? [3f] . [93] . [8f] . [93] . [9f] . [93] . [af] . [93] . [bf] . [93] . [80] . [91] . [04] . [01] . [90] . [91] . [05] . [01] . [a0] . [91] . [06] . [01] . [b0] . [91] . [07] . [01] 0 [30] . [91] . [08] . [01] . [01] . [96] . [a1] . [1d] . [b1] . [1d] # [23] / [2f] - [2d] _ [5f] - [2d] 7 [37] [20] . [f0] [20]
##############avrdude: Send: U [55] . [80] . [00] [20]
avrdude: Send: d [64] . [00] . [80] F [46] - [2d] W [57] . [01] . [96] . [a1] . [1d] . [b1] . [1d] [20] . [93] . [08] . [01] . [80] . [93] . [04] . [01] . [90] . [93] . [05] . [01] . [a0] . [93] . [06] . [01] . [b0] . [93] . [07] . [01] . [80] . [91] . [00] . [01] . [90] . [91] . [01] . [01] . [a0] . [91] . [02] . [01] . [b0] . [91] . [03] . [01] . [01] . [96] . [a1] . [1d] . [b1] . [1d] . [80] . [93] . [00] . [01] . [90] . [93] . [01] . [01] . [a0] . [93] . [02] . [01] . [b0] . [93] . [03] . [01] . [bf] . [91] . [af] . [91] . [9f] . [91] . [8f] . [91] ? [3f] . [91] / [2f] . [91] . [0f] . [90] . [0f] . [be] . [0f] . [90] . [1f] . [90] . [18] . [95] x [78] . [94] . [84] . [b5] . [82] ` [60] . [84] . [bd] . [84] . [b5] . [81] ` [60] . [84] . [bd] . [85] . [b5] . [82] ` [60] . [85] . [bd] . [85] . [b5] . [81] ` [60] . [85] . [bd] . [ee] . [e6] . [f0] . [e0] . [80] . [81] . [81] ` [60] . [80] . [83] . [e1] . [e8] . [f0] . [e0] [20]
##############avrdude: Send: U [55] . [c0] . [00] [20]
avrdude: Send: d [64] . [00] R [52] F [46] . [10] . [82] . [80] . [81] . [82] ` [60] . [80] . [83] . [80] . [81] . [81] ` [60] . [80] . [83] . [e0] . [e8] . [f0] . [e0] . [80] . [81] . [81] ` [60] . [80] . [83] . [e1] . [eb] . [f0] . [e0] . [80] . [81] . [84] ` [60] . [80] . [83] . [e0] . [eb] . [f0] . [e0] . [80] . [81] . [81] ` [60] . [80] . [83] . [ea] . [e7] . [f0] . [e0] . [80] . [81] . [84] ` [60] . [80] . [83] . [80] . [81] . [82] ` [60] . [80] . [83] . [80] . [81] . [81] ` [60] . [80] . [83] . [80] . [81] . [80] h [68] . [80] . [83] . [10] . [92] . [c1] . [00] . [08] . [95] . [f8] . [94] . [ff] . [cf] [20]
######### | 100% 0.08s
system
8
PART 3:
avrdude: 466 bytes of flash written
avrdude: verifying flash memory against /var/folders/68/t83q_vns5k36c1k18pzd08pc0000gp/T/build1433395646767163271.tmp/sketch_dec04a.cpp.hex:
avrdude: load data flash data from input file /var/folders/68/t83q_vns5k36c1k18pzd08pc0000gp/T/build1433395646767163271.tmp/sketch_dec04a.cpp.hex:
avrdude: input file /var/folders/68/t83q_vns5k36c1k18pzd08pc0000gp/T/build1433395646767163271.tmp/sketch_dec04a.cpp.hex contains 466 bytes
avrdude: reading on-chip flash data:
Reading | avrdude: Send: U [55] . [00] . [00] [20]
avrdude: Send: t [74] . [00] . [80] F [46] [20]
avrdude: Recv: . [0c] . [94] 4 [34] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] d [64] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [11] $ [24] . [1f] . [be] . [cf] . [ef] . [d8] . [e0] . [de] . [bf] . [cd] . [bf] . [11] . [e0] . [a0] . [e0] . [b1] . [e0] . [e2] . [ed] . [f1] . [e0] . [02] . [c0]
avrdude: Recv: . [05] . [90] . [0d] . [92] . [a0] 0 [30] . [f1] . [07] . [d9] . [f7] . [11] . [e0] . [a0] . [e0] . [b1] . [e0] . [01] . [c0] . [1d] . [92] . [a9] 0 [30] . [f1] . [07] . [e1] . [f7] . [0e] . [94] U [55] . [00] . [0c] . [94] . [e7] . [00] . [0c] . [94] . [00] . [00] . [08] . [95] . [08] . [95] . [cf] . [93] . [df] . [93] . [0e] . [94] . [ac] . [00] . [0e] . [94] S [53] . [00] . [c0] . [e0] . [d0] . [e0] . [0e] . [94] T [54] . [00] [20] . [97] . [e1] . [f3] . [0e] . [94] . [00] . [00] . [f9] . [cf] . [1f] . [92] . [0f] . [92] . [0f] . [b6] . [0f] . [92] . [11] $ [24] / [2f] . [93] ? [3f] . [93] . [8f] . [93] . [9f] . [93] . [af] . [93] . [bf] . [93] . [80] . [91] . [04] . [01] . [90] . [91] . [05] . [01] . [a0] . [91] . [06] . [01] . [b0] . [91] . [07] . [01] 0 [30] . [91] . [08] . [01] . [01] . [96] . [a1] . [1d] . [b1] . [1d] # [23] / [2f] - [2d] _ [5f] - [2d] 7 [37] [20] . [f0]
avrdude: Recv: - [2d] W [57] . [01] . [96] . [a1] . [1d] . [b1] . [1d] [20] . [93] . [08] . [01] . [80] . [93] . [04] . [01] . [90] . [93] . [05] . [01] . [a0] . [93] . [06] . [01] . [b0] . [93] . [07] . [01] . [80] . [91] . [00] . [01] . [90] . [91] . [01] . [01] . [a0] . [91] . [02] . [01] . [b0] . [91] . [03] . [01] . [01] . [96] . [a1] . [1d] . [b1] . [1d] . [80] . [93] . [00] . [01] . [90] . [93] . [01] . [01] . [a0] . [93] . [02] . [01] . [b0] . [93] . [03] . [01] . [bf] . [91] . [af] . [91] . [9f] . [91] . [8f] . [91] ? [3f] . [91] / [2f] . [91] . [0f] . [90] . [0f] . [be] . [0f] . [90] . [1f] . [90] . [18] . [95] x [78] . [94] . [84] . [b5] . [82] ` [60] . [84] . [bd] . [84] . [b5] . [81] ` [60] . [84] . [bd] . [85] . [b5] . [82] ` [60] . [85] . [bd] . [85] . [b5] . [81] ` [60] . [85] . [bd] . [ee] . [e6] . [f0] . [e0] . [80] . [81] . [81] ` [60] . [80] . [83] . [e1] . [e8] . [f0] . [e0]
avrdude: Send: t [74] . [00] R [52] F [46] [20]
avrdude: Recv: . [10] . [82] . [80] . [81] . [82] ` [60] . [80] . [83] . [80] . [81] . [81] ` [60] . [80] . [83] . [e0] . [e8] . [f0] . [e0] . [80] . [81] . [81] ` [60] . [80] . [83] . [e1] . [eb] . [f0] . [e0] . [80] . [81] . [84] ` [60] . [80] . [83] . [e0] . [eb] . [f0] . [e0] . [80] . [81] . [81] ` [60] . [80] . [83] . [ea] . [e7] . [f0] . [e0] . [80] . [81] . [84] ` [60] . [80] . [83] . [80] . [81] . [82] ` [60] . [80] . [83] . [80] . [81] . [81] ` [60] . [80] . [83] . [80] . [81] . [80] h [68] . [80] . [83] . [10] . [92] . [c1] . [00] . [08] . [95] . [f8] . [94] . [ff] . [cf]
######### | 100% 0.06s
avrdude: verifying ...
0xb1 != 0xf1
avrdude: Send: Q [51] [20]
avrdude done. Thank you.
system
December 4, 2013, 3:01pm
9
Sorry the Verbose output is in 3 parts, it was exceeding the 9500 character limit.
Thanks again,
Jack
system
December 4, 2013, 10:54pm
10
Hi All,
Could someone tell me how to reset the arduino to factory settings? I think its worth a try and might solve the issue.
Thanks again,
Jack
dantedraven13:
The closest thing is to re-burn the bootloader. All you need is some wire and a second board.
I agree.
system
December 5, 2013, 8:54am
13
Where did you buy it?
How old is it?
From Maplins Electronics about 4 or 5 months ago.
How would I got about doing that? I have a second board a can use.
system
December 5, 2013, 11:57am
14
Hi Coding Badly,
I found an online tutorial for reinstalling the bootloader here:
https://www.sparkfun.com/tutorials/247
However, after doing this I get this message now:
Any ideas?
Yeah. Don't use that tutorial. It's missing at least one important step and the wiring method is just plain stupid.
Give this one a try...
system
December 7, 2013, 4:38pm
16
Hi Coding Badly,
Can I do this without the resistor? I don't have 10uF ones and I'm pressed for time so sourcing one is an issue. Also, I've bought a completely new board and encountered the same error as first listed. Could something in my circuit cause this error? I've tried uploading the code to another board and its working fine so I'm worried the circuit might be the issue, although its exactly the same as the other one with the exception of running off a different power supply, however they are the same voltage and amperage (9v, 2A). I've updated my arduino software and that hasn't solved the issue either.
Thanks,
Jack
dantedraven13:
"Resistor"? Did you mean to write "capacitor"?
Are you asking about a 120 ohm resistor connected from RESET to +5V to disable auto-reset?
Or you could cut the auto-reset trace.
Anything larger will work. Smaller may work. The capacitor size is not very important.
dantedraven13:
Do you have anything connected to pins 0 or 1?
system
December 8, 2013, 1:16am
19
No, the only pins used are 3-11, 5v and Gnd.
system
December 8, 2013, 1:39pm
20
Hi Coding Badly,
Thanks for all your help! Finally got it working Managed to reprogram the board using the tutorial you posted and it all works fine now.
Thanks again,
Jack
