Topic: High Speed Actuator (Read 5142 times) previous topic - next topic
All you need is a threaded rod of the desired length, a captive nut that the rod drives, and a geared-down DC motor to rotate the threaded rod.
Don't forget you also have to mount the rod with radial support bearings and an axial thrust bearing.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
Thank you very much everyone. I've gone with a servo. It is so much easier to program. Check out the code...
Code: [Select]
#include "Servo.h"
Servo miservo;
int inBy;
  // attaches a servo connected to pin 10
  miservo.attach(10);  //attach servo to adafruit motor shield
  Serial.begin(9600); //open serial port
  miservo.writeMicroseconds(1450); //set beginning angle
  if (Serial.available() >0) {
    inBy = Serial.read();
  if (inBy == 'H') {
    miservo.writeMicroseconds(1900); //turn servo to the LEFT
  if (inBy == 'L') {
    miservo.writeMicroseconds(1000); //turn servo to the RIGHT
  if (inBy == 'C') {
    miservo.writeMicroseconds(1450); //turn servo to the CENTER
