Topic: High Speed Actuator (Read 5451 times) previous topic - next topic
zoomkat
All you need is a threaded rod of the desired length, a captive nut that the rod drives, and a geared-down DC motor to rotate the threaded rod.
Don't forget you also have to mount the rod with radial support bearings and an axial thrust bearing.
ScottA1
Thank you very much everyone. I've gone with a servo. It is so much easier to program. Check out the code...
#include "Servo.h"
Servo miservo;
int inBy;
  // attaches a servo connected to pin 10
  miservo.attach(10);  //attach servo to adafruit motor shield
  Serial.begin(9600); //open serial port
  miservo.writeMicroseconds(1450); //set beginning angle
  if (Serial.available() >0) {
    inBy = Serial.read();
  if (inBy == 'H') {
    miservo.writeMicroseconds(1900); //turn servo to the LEFT
  if (inBy == 'L') {
    miservo.writeMicroseconds(1000); //turn servo to the RIGHT
  if (inBy == 'C') {
    miservo.writeMicroseconds(1450); //turn servo to the CENTER
