Topic: 8x8 dot matrix with MAX7219 (Read 2148 times) previous topic - next topic
wilson16
i want to show string on the three 8x8 LED dot matrix ( same signal) with different animation.
1st:  shirt the string to Left
2nd: shirt the string UP
3rd: display and hold the sting only.
is possible to do like that?
if can`t , can i use different signal to control each dot matrix with same arduino?
marco_c
Look at Parola (http://parola.codeplex.com) and on this thread http://forum.arduino.cc/index.php?topic=171056.0
I would say this will do close to what you want and more.
Arduino Libraries https://github.com/MajicDesigns?tab=Repositories
Parola for Arduino https://github.com/MajicDesigns/Parola
fungus
wilson16
i want to show different animation string for 3 of 8x8 dot matrix at the same time.  really no idea, because all the tutorial is show a animation string in the same. How to make it to show different pattern in the 3  of dot matrix  in same signal? :)
marco_c
As I said in my previous post, look at Parola if you want to have message on the display. If you just want to treat the 8x8 displays as individual smaller display (independent), then the transformation functions in my MD_MAX72xx library (link below in the repository). Read the documentation for the library.
You will not find examples to do exactly what you want because it is pretty unusual!
wilson16
yes ,it is really unusual. I will try understand and testing. thank you very much...
