Topic: binary form in Serial window (Read 946 times) previous topic - next topic
m_lab85
hi all,
i am using the following code DAC from
http://www.youtube.com/watch?v=-hKIXj5dAjc
int led = 31;
//1kHz
int sine[] = {2048,2305,2557,2802,3034,3251,3449,3625,3777,3901,3995,4059,4092,4092,4060,3996,3902,3778,3628,3452,3254,3037,2805,2560,2308,2051,1795,1542,1297,1065,847,649,473,321,197,102,37,4,4,35,99,193,316,466,642,839,1056,1288,1533,1785,2041};
// the setup routine runs once when you press reset:
  // initialize the digital pin as an output.
  pinMode(led, OUTPUT);
  pinMode(DAC0, OUTPUT);
// the loop routine runs over and over again forever:
  for(int i = 0; i<50;i++){
      if(sine[i]>4095) {
         sine[i]=4095;
         digitalWrite(led, LOW);
    analogWriteResolution(12);
    analogWrite(DAC0, sine[i]);
    delayMicroseconds(14);
i want to see the binary form of the sine wave in Serial window. i know there is print() function but i am not sure how to use it.
any help would be greatly appreciated,
m,
garygid
#1
Dec 05, 2013, 02:36 pm Last Edit: Dec 05, 2013, 02:40 pm by garygid Reason: 1
Perhaps...
Serial.println(sine[i], HEX) ; // or DEC
in the loop, in the for-I, maybe just print the first
time through the Loop to avoid printing too much?
Serial.begin(115200) ;
in the setup
m_lab85
thanks i will try it,
regards,
m
m_lab85
hi
i've tried this function but it gives me HEX. not binary
Serial.println(sine, HEX) ; // or DEC
regards,
M
Gericom
Subscribe my youtube channel: http://www.youtube.com/user/MKDS3
