Topic: Arduino EasyVR Compiling / Upload Error [SOLVED] (Read 727 times) previous topic - next topic
BeEasy114
Dec 06, 2013, 12:51 am Last Edit: Dec 07, 2013, 12:52 am by BeEasy114 Reason: 1
I Downloaded all the files I was supposed to put them in the Arduino libraries esc... and Tried uploading the code that EasyVR generated after i made several commands. this all went smoothly, but once I got to Arduino and tried to run the code that EasyVR made I got this error? can anyone help me?
Trials:
1.The EasyVR_AccessControl_Demo.pde give me the same error as well.
2.I disconnected my pin 12 & 13 also to see if that might change it with no luck. I attached the files it is giving me the errors on and also the test.pde code the EasyVR made for me... PLEASE HELP!!!
Compiling Error:
In file included from test.pde:3:
C:\Users\DoctorRight\Documents\Arduino\libraries\SoftwareSerial/SoftwareSerial.h:52: error: conflicting return type specified for 'virtual void SoftwareSerial::write(uint8_t)'
C:\Program Files\Arduino\hardware\arduino\cores\arduino/Print.h:48: error:   overriding 'virtual size_t Print::write(uint8_t)'?
codlink
I am not getting any errors from your code.  What IDE version are you using?
//LiNK
BeEasy114
Figured it out. For anyone having this problem. You placed the wrong version of arduino EasyVR library in your libraries folder. I needed to delete both the NewSoft and Software
POST COMPLETED
codlink
Edit your original post and add [SOLVED] to the title.
//LiNK
