Topic: [SD] Weird-Unable to write into files, reading works ! (Read 957 times) previous topic - next topic
Helium328PU
Hi all!
I am having quite strange problem with my current project.
I am using Arduino Mega 2560r3 with RTC (I2C), SD (SPI) and B/W dot matrix lcd (UART).
Basic operation of my project - read 8 analog samples, create average and write it into SD with timestamp.
Finally connected SD module with compatible SD (worst experience ever - tried 8 cards and only the last one worked!!!). Checked it with "CardInfo" sketch.
THE PROBLEM: My program reads current date from RTC and creates string which is used as filename. But program only writes s file, but nothing into it! It is still 0 bytes... If I change filename, file is written, but again - empty.
Once I have done "something" and everything worked correctly - had data in files. Later againt "something" happened and now I have again empty files :(
I thought about some bad connections (something like WR - write protection), but SD doesnt have anything like this.
Could it be software related? I am suspicious about function "sprintf()" that caused some problems early...
Thanks for any ideas!
I may post full code, but dont want to paste all (over 300 lines and still growing - not finished), so here is part of code that writes into SD:
//filename
  sprintf (DateField, "20%02u%02u%02u.CSV",year,date,month); // http://forum.arduino.cc/index.php?PHPSESSID=go7j8f5fpvr23ooqtbr23lnmd0&topic=106697.msg800508#msg800508
  mydisp.setPrintPos(0, 5);
  mydisp.print("FILE: ");
  mydisp.print(DateField);
  mydisp.print("  ");
  //ukladani do souboru
  String dataString = "";
  File dataFile = SD.open(DateField, FILE_WRITE);
  dataString += String(mVvalueInt);
  // if the file is available, write to it:
  if (dataFile) {
    SDerror=false;
    if (FirstStart==true) {
      dataFile.println("SYSTEM ONLINE");
      //dataFile.println("FILENAME     - TIME     - DOSE (nSv/h)");
    dataFile.print(DateField);
    dataFile.print(" - ");
    sprintf (TimeField, "%02u:%02u:%02u",hour,minute,second);
    dataFile.print(TimeField);
    dataFile.print(dataString);
    dataFile.println("");
    dataFile.close();
  // if the file isn't open, pop up an error:
  else {
    SDerror=true;
Helium328PU
OK, so did some tests and tweaks:
- Tried slow down SPI speed to HALF and QUARTER, no luck.
- Also checked all resistors onboard and they are 10k as marked.
- Twisted data wires and added a ferrite core filter.
- Finally checked SD with fdisk (on Kubuntu). Because after each write from arduino  card apperas in my notebook as read-only.  Fdisk reported to me there are clusters with out of range - doe to count of them, it seems that these are which arduino attempted to write into.
Here is output from fdisk:
helium@ThinkPad:~$ sudo fsck -a /dev/mmcblk0p1
fsck z util-linux 2.20.1
dosfsck 3.0.16, 01 Mar 2013, FAT32, LFN
FATs differ but appear to be intact. Using first FAT.
Cluster 20 out of range (135323653 > 501545). Setting to EOF.
Cluster 22 out of range (6309504 > 501545). Setting to EOF.
Cluster 23 out of range (6947848 > 501545). Setting to EOF.
Cluster 24 out of range (267911169 > 501545). Setting to EOF.
Cluster 25 out of range (268212223 > 501545). Setting to EOF.
Cluster 26 out of range (268208127 > 501545). Setting to EOF.
Cluster 27 out of range (268208127 > 501545). Setting to EOF.
Cluster 28 out of range (268234751 > 501545). Setting to EOF.
Cluster 29 out of range (268216319 > 501545). Setting to EOF.
Cluster 30 out of range (268224511 > 501545). Setting to EOF.
Cluster 31 out of range (268210175 > 501545). Setting to EOF.
Cluster 32 out of range (268208127 > 501545). Setting to EOF.
Cluster 33 out of range (268208127 > 501545). Setting to EOF.
Cluster 34 out of range (268208127 > 501545). Setting to EOF.
Cluster 35 out of range (268208127 > 501545). Setting to EOF.
Cluster 36 out of range (268208127 > 501545). Setting to EOF.
Cluster 37 out of range (268238847 > 501545). Setting to EOF.
Cluster 38 out of range (268224511 > 501545). Setting to EOF.
Cluster 39 out of range (268238847 > 501545). Setting to EOF.
Cluster 40 out of range (268404735 > 501545). Setting to EOF.
Cluster 41 out of range (9865215 > 501545). Setting to EOF.
Cluster 42 out of range (135405632 > 501545). Setting to EOF.
Cluster 43 out of range (234947076 > 501545). Setting to EOF.
Cluster 44 out of range (184582144 > 501545). Setting to EOF.
Cluster 45 out of range (152051904 > 501545). Setting to EOF.
Cluster 50 out of range (8401921 > 501545). Setting to EOF.
Cluster 51 out of range (268377888 > 501545). Setting to EOF.
Cluster 52 out of range (33880304 > 501545). Setting to EOF.
Cluster 53 out of range (1). Setting to EOF.
Cluster 54 out of range (2097216 > 501545). Setting to EOF.
Cluster 57 out of range (2113664 > 501545). Setting to EOF.
Cluster 58 out of range (67110912 > 501545). Setting to EOF.
Cluster 60 out of range (2113664 > 501545). Setting to EOF.
Cluster 63 out of range (4194432 > 501545). Setting to EOF.
Cluster 64 out of range (67637248 > 501545). Setting to EOF.
Cluster 66 out of range (2113664 > 501545). Setting to EOF.
Cluster 67 out of range (33816584 > 501545). Setting to EOF.
Cluster 69 out of range (2113664 > 501545). Setting to EOF.
Cluster 70 out of range (33816584 > 501545). Setting to EOF.
Cluster 72 out of range (2097216 > 501545). Setting to EOF.
Cluster 75 out of range (2113664 > 501545). Setting to EOF.
Cluster 76 out of range (524288 > 501545). Setting to EOF.
Cluster 79 out of range (134221856 > 501545). Setting to EOF.
Cluster 81 out of range (1). Setting to EOF.
Cluster 82 out of range (2113536 > 501545). Setting to EOF.
Cluster 83 out of range (33816584 > 501545). Setting to EOF.
Cluster 84 out of range (8388609 > 501545). Setting to EOF.
Cluster 85 out of range (1056768 > 501545). Setting to EOF.
Cluster 87 out of range (1). Setting to EOF.
Cluster 88 out of range (4194304 > 501545). Setting to EOF.
Cluster 89 out of range (67633168 > 501545). Setting to EOF.
Cluster 90 out of range (16777728 > 501545). Setting to EOF.
Cluster 91 out of range (4227072 > 501545). Setting to EOF.
Cluster 92 out of range (135266336 > 501545). Setting to EOF.
Cluster 93 out of range (16908292 > 501545). Setting to EOF.
Cluster 94 out of range (8388608 > 501545). Setting to EOF.
Cluster 95 out of range (135274560 > 501545). Setting to EOF.
Cluster 96 out of range (16909312 > 501545). Setting to EOF.
Cluster 97 out of range (4227072 > 501545). Setting to EOF.
Cluster 98 out of range (33818640 > 501545). Setting to EOF.
Cluster 100 out of range (1056832 > 501545). Setting to EOF.
Cluster 101 out of range (33555464 > 501545). Setting to EOF.
Cluster 104 out of range (33818640 > 501545). Setting to EOF.
Cluster 106 out of range (2113664 > 501545). Setting to EOF.
Cluster 108 out of range (8388609 > 501545). Setting to EOF.
Cluster 109 out of range (134221856 > 501545). Setting to EOF.
Cluster 111 out of range (8388609 > 501545). Setting to EOF.
Cluster 112 out of range (67637280 > 501545). Setting to EOF.
Cluster 115 out of range (135266336 > 501545). Setting to EOF.
Cluster 117 out of range (4227072 > 501545). Setting to EOF.
Cluster 118 out of range (135266336 > 501545). Setting to EOF.
Cluster 120 out of range (8388609 > 501545). Setting to EOF.
Cluster 121 out of range (135266336 > 501545). Setting to EOF.
Cluster 123 out of range (2113664 > 501545). Setting to EOF.
Cluster 124 out of range (67633168 > 501545). Setting to EOF.
Cluster 125 out of range (16777728 > 501545). Setting to EOF.
/test
  File size is 12288 bytes, cluster chain length is 4096 bytes.
  Truncating file to 4096 bytes.
/FSCK0001.REC
  Contains a free cluster (32790). Assuming EOF.
/FSCK0001.REC
  File size is 49152 bytes, cluster chain length is 36864 bytes.
  Truncating file to 36864 bytes.
Reclaimed 90 unused clusters (368640 bytes) in 89 chains.
Performing changes.
/dev/mmcblk0p1: 109 files, 126/501544 clusters
