Topic: what about ClearType BUG !? Why is it not getting fixed? (Read 10208 times) previous topic - next topic
smilem
I use latest Arduino IDE. What about ClearType BUG !? Why is it not getting fixed?
I'm using WinXP SP3, and using "standard" is not an option as it does not work for desktop, and some other windows UI components. You can't customize it either. Other JAVA software works fine so this is clearly Arduino IDE bug, an old bug.
CrossRoads
smilem
What is cleartype: http://www.microsoft.com/typography/ClearTypeInfo.mspx
Why is better than standard antialiashing WinXP http://www.microsoft.com/typography/cleartype/tuner/step1.aspx
Win7 http://www.howtogeek.com/howto/28790/
And yes it works on CRT fine.
westfw
#3
Dec 08, 2013, 10:09 am Last Edit: Dec 08, 2013, 10:12 am by westfw Reason: 1
Ok, but what is the "bug" you speak of?  Simply that you think the IDE should use cleartype, but it doesn't?
(so: it's not getting fixed, because no one has reported a bug?
There is https://github.com/arduino/Arduino/issues/154
and https://github.com/arduino/Arduino/issues/232 )
smilem
The menus are all blank, the program is not usable with Creartype enable, and without I can't use my PC because of poor  readability of text. This is on both Arduino IDE versions.
westfw
Ah; more debugging will be necessary.  It works fine for me with cleartype enabled, on XP, W7, and 8.1, and it's not a problem that anyone else has reported, so it seems to be something particular to your system.  You mentioned that you've been trying to manually edit preferences and themes; does it work better if you clear out all those files and start with a fresh install of Arduino?
(some of the files you'll have to delete manually, I think.)
I don't think anyone will claim that the arduino font and color choices are the most wonderful of all possible, but it should be better than "completely blank" and "unreadable."
smilem
Quote
No, it was like this from the start.
Quote
yes the menus are white, blank, empty.
smilem
I downloaded v1.5.8 latest, the cleartype bug is still there, win xp32 bit sp3 here.
el_supremo
Don't send me technical questions via Private Message.
smilem
I haven't got WinXP any more so I can't try this out but is the info in this link any help?
http://www.gnostice.com/nl_article.asp?id=189&t=Is_ClearType_Enabled_On_Your_Windows_XP_Desktop
Pete
Well yes I know that disabling cleartype will make the arduino IDE work. However this makes text hard to read. So I do not think this is a proper way to solve this, no other Java app has this bug on winxp (at least that I use).
I now use UECIDE as alternative to arduino IDE. But I would like to use official version too. If somebody would debug this .
pjrc
This is the first I've ever heard of this problem, so as a quick sanity check, I fired up a virtual machine with XP and turned on ClearType.
As you can see in this screenshot, Arduino 1.0.6 seems to work find on a clean XP system with ClearType enabled.  Perhaps you've tweaked and fiddled with many system settings on your XP install?  I'm sure if you test with a clean XP system, you'll get the same results I just did.
dito3
Hello
Smilem is right !!!. I just tested it with an old PC with Windows XP SP3 and cleartype activated. Therefore, this bug is not a problem specific of the Smilem's PC.
My nose tells me that the root of the problem must be sought in java of IDE.
Regards
pjrc
#13
Feb 13, 2015, 07:59 am Last Edit: Feb 13, 2015, 08:01 am by Paul Stoffregen
Try using VirtualBox.  It's free.  Install Windows in a virtual machine, so you have a fresh & clean copy of Windows without all sorts of "theme" customizations.  Do NOT install other software, especially things that customize Windows appearance.
I recommend configuring the virtual machine with no networking, but with a shared folder.  Then it's easy to let it use files from your machine, but you don't have to worry about it getting network access and getting infected with all sorts of adware and malware.
Install only Arduino and turn on ClearType.  I'm sure you'll see the same results I did.  It does work properly.
Then you could start really working on this problem, by slowly duplicating your system's customizations, one by one, until you discover what changes messed up the Arduino menus.
