Topic: Serial.Available is blocking (Read 1 time) previous topic - next topic
bclay
I have a sketch that  reads switch positions and sends a message  on the net when they change using an Ethernet Shield.  I am trying to add a capability to temporarily update some parameters at startup using the USB port and the Serial interface.  The problem I run into is that any serial input calls seem to block.  I can output using Serial.print and Serial.println but Serial.Available and Serial.peek both see to block waiting for input which may not always be available.
Bruce
AWOL
...I'm not going to share with you.
Grumpy_Mike
No they don't.
You can write code using them that does block if you want, which it looks like what you have done. But the functions themselves do not block.
AWOL
Well, that code doesn't compile, so when you've got the actual code, and figured how to post it correctly , get back to us.
bclay
#4
Dec 08, 2013, 10:19 pm Last Edit: Dec 09, 2013, 02:46 am by bclay Reason: 1
I am currently using an Arduino Uno with a Ethernet Shield from Seeed Studio.  The circuit boards are installed in a plastic project box .  The only hardware added to this project are the connectors use to connect external switches.  Before I added the software to read configuration information from the computer the software worked properly.  After adding the Serial code it stopped working.  If I add debug information (printing to the terminal) I can see that the Application on the Arduino is waiting / blocking at the Serial.available line.  No errors are reported.
I did not see any setup options available to set blocking to non-blocking mode for the serial class.
Any help would be greatly appreciated.
#include <SPI.h>  // needed for Arduino versions later than 0018
#include <Ethernet.h>
#include <EthernetUdp.h>  // UDP library from: bjoern@cs.stanford.edu 12/30/2008
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mLocalMacAddr[] = {0xD6, 0xAD, 0xBE, 0x00, 0x00, 0x02 };
IPAddress localIp(10, 99, 99, 99);
unsigned int localPort = 8888;      // local port to listen on
// buffers for receiving and sending data
char  mSendMsgBuf[40];       // a string to send back
char mReadBuf[40];
int mReadIndex = 0;
// An EthernetUDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
#define ACTIVE_PINS 4
int mPinBuf[ACTIVE_PINS];
int mActivePins = ACTIVE_PINS;
unsigned short mRemotePortNum = 4000;
IPAddress mRemoteAddress(10, 99, 99, 99);
 // start the Ethernet and UDP:
 Ethernet.begin(mLocalMacAddr, localIp);
 Udp.begin(localPort);
 // clear all pins in buffer and emable the pullup resistor
 // the switches toggle to ground
 for (int index = 0; index < ACTIVE_PINS; index++)
   mPinBuf[index] = 1;
   pinMode(index, INPUT_PULLUP);
 if (Serial.available() > 0)
   char inChar = Serial.read();
  if (inChar != '\n')
     mReadBuf[mReadIndex++] = inChar;
     mReadBuf[mReadIndex] = '\0';
     mReadIndex = 0;
 for (int index = 0; index < mActivePins; index++)
   int pinVal = digitalRead(index);
   if (pinVal != mPinBuf[index])
     mPinBuf[index] = pinVal;
#ifdef DEBUG
     Serial.print("Pin ");
     Serial.print(index);
     Serial.print(": ");
     Serial.println(pinVal);
#endif // DEBUG
     if (index == 2)
       if (pinVal == 1)
         sprintf(mSendMsgBuf, "<PTT>ON</PTT>", index);
         sprintf(mSendMsgBuf, "<PTT>OFF</PTT>", index);
     else if (index == 3)
       if (pinVal == 1)
         sprintf(mSendMsgBuf, "<STT>ON</STT>", index);
         sprintf(mSendMsgBuf, "<STT>OFF</STT>", index);
#ifdef DEBUG
     Serial.println(mSendMsgBuf);
#endif // DEBUG
     // send a reply, to the IP address and port that sent us the packet we received
     Udp.beginPacket(mRemoteAddress, mRemotePortNum);
     Udp.write(mSendMsgBuf);
     Udp.endPacket();
 delay(10);
AWOL
Pins zero and one?
The ones you're using for the serial interface?
Me neither.
el_supremo
Your code reads lines of data from the serial port but does nothing when a complete line is entered.
You don't do any bounds checking so that if a line of more than 39 characters is entered, your code will clobber something off the end of the array, leading to unpredictable behaviour such as "blocking at the Serial.available line".
Pete
Don't send me technical questions via Private Message.
