Topic: delay() issue - where to best report Due bugs? (Read 932 times) previous topic - next topic
MarkT
Has anyone noticed the glaring bug in Due delay() function?
Code: [Select]
void delay( uint32_t ms )
    uint32_t end = GetTickCount() + ms;
    while (GetTickCount() < end)
    yield();
[ Namely failure to deal with wrap-around ]
Suggested fix:
Code: [Select]
void delay (uint32_t ms)
  if (ms == 0)
    return ;
  uint32_t start = GetTickCount () ;
  do { yield () ; } while (GetTickCount() - start < ms) ;
noblepepper
I believe you will get a warm reception at https://github.com/arduino/Arduino/issues?page=1&state=open, make sure you check the open issues to avoid a duplicate bug report.
MarkT
Thanks - if they had simply copied the Wait() function from libsam's timetick.c and
added the call to yield() it would have been fine!
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
