Topic: Dimming ZXLD1366 LED Driver via PWM (Read 5258 times) previous topic - next topic
Cherubim
Dec 11, 2013, 03:49 pm Last Edit: Dec 11, 2013, 08:41 pm by Cherubim Reason: 1
I want to dim my LED and have a LED driver based on the ZXLD1366  IC.
The PWM input voltage of this IC is max 2.5V according to it's datasheet: http://www.diodes.com/datasheets/ZXLD1366.pdf
Now I thought "that's okay, as long as I don't set PWM above 60 (which should be around the 2.5V) all will be okay".
Well: It wasn't okay and the IC blew :(  =(
What did I do wrong and how exactly will I be able to use PWM with this IC?
Thanks for your help  :)
arduinodlb
Where does it say this?
Do not IM me. I will not respond. Ask questions in the forum.
Cherubim
arduinodlb
OK,
So the datasheet says:
Maximum ratings: Vadj = -0.3 - 6VDC.
It also says:
ADJ: Drive with DC Voltage 0.3 < Vadj < 2.5 to adjust from 25% to 200%., with normal operation at 1.25V.
So, I would interpret that as you want to be operating at 1.25V, unless you have a reason to do otherwise. If you were operating at 5V, 60% duty cycle, you're at 3V, which it's not going to like.
Cherubim
Exactly - I already found out the hard way that the IC doesn't like too much voltage :)
arduinodlb
Does that mean your original questions have now been answered?
Cherubim
No, not at all. I know that I need to have max 2.5V - but I don't know how to get there.
fungus
It also says:
Variable voltage? That doesn't sound like a PWM input to me. I think the PWM input is the other pin...
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
Cherubim
Well the datasheet says otherwise :)
"Enhanced output current dimming resolution can be achieved by
applying a PWM signal to the 'ADJ' pin. "
"Single pin on/off and brightness control using DC voltage or
PWM "
So it is a combined pin.
fungus
PWM "
Oh, I see.
It says "PWM frequency < 300Hz PWM amplitude = VREF Measured on ADJ pin "
So you need a voltage divider to drop 5V down to whatever reference voltage you want.
PS: Arduino PWM frequency is higher then 300Hz so that's another problem you need to solve.
arduinodlb
In this case, it means either a DC voltage of 2.5V Max, or an average PWM voltage of 2.5V Max. This is how you get there:
It also says:
So, for your 5V supply, you want a duty cycle of 1.25/5 = 25%. This will provide an AVERAGE voltage of 1.25V, which is less than the 2.5V MAX.
fungus
No. The datasheet specifically says the PWM amplitude must be Vref.
arduinodlb
Hmmm. You're right. That seems odd.
Cherubim
Thanks for your posts.
As you see, this isn't an easy matter - at least when you only know the basic electronics stuff like me :(
I can programm my arduino, but when it comes to things like that, I'm overchallenged.
fungus
There's nothing "odd" about it. It was probably a case of do it that way or add more pins to the chip.
You can set the PWM amplitude with two resistors. No big deal.
