Topic: Serial port already in use. (Read 1 time) previous topic - next topic
hilukasz
I am using a leonardo and for some reason I can only upload sometimes to it. I've noticed it happens usually only when I have serial communication happening, I am assuming its because leonardo continues to read serial even when window is closed.
I am on OSX and have tried two things:
1. adding delay in setup of 5seconds so I could try a reboot and upload right after its been rebooted.
2. this suggestion http://www.baldengineer.com/blog/2012/10/08/arduino-fixing-serial-port-in-use/
not sure what else it could be. any ideas on fixing this? It only happens with leonardo.
for(i = 0, i < 820480075, i++){ Design(); Code(); delay(1000); } // hellowoo.com
cmiyc
No, that doesn't make sense.  "Serial port in use" is on the PC side, not the Leonardo's side.
If you load Blink on the Leonardo and keep trying to reload it, do you still get the serial port in use?
Yeah, I wrote that with the Uno and Mega in mind.  The Leonardo is different.  Although, it would be good to use lsof to find out what is holding the port open (something has to be).
hilukasz
nope, like i mentioned earlier, it only happens when I have serial communication it seems, simple sketches like blink don't seem to have an affect.
cmiyc
Okay then load something with serial communication and run lsof to find out what is keeping the port open.  Again, if you're getting "serial port in use" that means some process is holding it open.
