Topic: A link to info on 'function pointers' (Read 13706 times) previous topic - next topic
JohnHoward
Dec 13, 2013, 01:11 am Last Edit: Dec 13, 2013, 02:20 am by JohnHoward Reason: 1
http://www.newty.de/fpt/index.html
I discovered this site today and found it useful.
One example I got running on Arduino:
[edit: Oops, From another site http://www.codeterrorizer.com/cc/using-function-pointers-function-pointer-part-ii]
Code: [Select]
#include <stdio.h>
#include <Serial.h>
* Using a function pointer in a structure.
struct _Object {
   void (* functionPointer)();
   int value;
* Passing a function pointer to a function.
void passFunction(void (* functionPointer)()) {
   /* call our passed function */
   functionPointer();
void testFunction() {
   Serial.println("hello");
void testFunction2() {
   Serial.println("juhu");
   /* pointer to void function with no parameters myFunction */
   void (* myFunctionPointer)() = testFunction;
   /* call original function */
   Serial.print("#1 ");
   testFunction();
   /* call our new pointer function */
   Serial.print("#2 ");
   myFunctionPointer();
   /* create struct */
   struct _Object Object;
   Object.value = 1;
   Object.functionPointer = testFunction;
   Serial.print("#3 ");
   printf("%d\n", Object.value);
   Serial.print("#4 ");
   Object.functionPointer();
   /* Add function pointer to our gobal array. */
   int functionPointers[2];
   functionPointers[0] = (int)testFunction;
   Serial.print("#5 ");
   printf("%d\n", functionPointers[0]);
   functionPointers[1] = (int)testFunction2;
   printf("%d\n", functionPointers[1]);
   /* Creepy! but possible. */
   Serial.print("#6 ");
   ((void (*)()) functionPointers[0])();
   Serial.print("#7 ");
   ((void (*)()) functionPointers[1])();
Interesting, though, cases #3 and #5 do not appear to call the function (neither 'hello' nor 'juhu' is printed).
[edit, again]
I compiled the example as a Win32 console app (to see what it presumably SHOULD do) and get this output, indicating the Arduino incarnation has 'problems':
hello
hello
1
hello
19665356
19665151
hello
juhu
[edit: Still reading?  OK, I changed the example so it appears to work the same as in Win32]
Code: [Select]
#include <stdio.h>
#include <Serial.h>
struct _Object {
    int value;
    functionPointer();
    testFunction();
    /* create struct */
    Object.value = 1;
    Serial.println(Object.value);
    Serial.print("#5 ");  ////////////////////////////////////// Changed
    Serial.println(functionPointers[0]);
    Serial.print("#6 ");  ////////////////////////////////////// Changed
    Serial.println(functionPointers[1]);
    Serial.print("#8 ");
and this prints out:
#1 hello
#2 hello
#3 1
#4 hello
#5 103
#6 96
#7 hello
#8 juhu
PeterH
That's because you never actually call the pointed-to function in either of those cases.
Storing function pointers as ints is wrong. Don't do it, even on platforms where ints happens to be the same size as function pointers. If you want an array of function pointers, declare an array of function pointers.
I can't match up the output you presented with the code and I guess this was not the actual output of the code you posted. In light of the comments above, is there any part of the behaviour of your sketch that you still think is wrong?
JohnHoward
Yeah, got the numbering wrong as I was experimenting and exploring.  The 2nd variant of my code seems to do what it's supposed to do.  Or at least mirrors what the original author's example does when I compile it in Visual Studio and run that.
The two I thought were problematic seem to print out the address or value of the pointer, not the output of the two functions, if I'm understanding correctly now.  As you say, the functions aren't called.
Hopefully it's useful info for the rather frequent questions here about pointers.  I recall one person asking to make an array of function pointers, which this example also happens to illustrate.
It made some concepts clearer for my pointer-phobic brain.
nickgammon
I cleaned up your code a bit. One of the reasons things weren't printing was that you were mixing printf with Serial.print.
Modified version:
Code: [Select]
typedef void (* myFunctionPointer) ();
typedef struct myObject {
  myFunctionPointer functionPointer;
  int value;
void passFunction(myFunctionPointer functionPointer) ;
void passFunction(myFunctionPointer functionPointer) {
  functionPointer();
myFunctionPointer functionPointers[2];
  myFunctionPointer functionPointer = testFunction;
  testFunction();
  functionPointer();
  /* create struct */
  myObject Object;
  Object.value = 1;
  functionPointers[0] = testFunction;
  Serial.println((int) functionPointers[0]);
  functionPointers[1] = testFunction2;
  Serial.println((int) functionPointers[1]);
  functionPointers[0] ();
  functionPointers[1] ();
Output:
Code: [Select]
#1 hello
#2 hello
#3 1
#4 hello
#5 103
96
#6 hello
#7 juhu
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
JohnHoward
Nick, I think you missed the intent of the originator of that code example -- to examine possible alternatives for declaring pointers to functions.  'Creepy' but valid; impractical perhaps but instructive, brain stretchers for the learners.
Cleaned up is better, though.
nickgammon
Oh, yes?
Here's another way. Function objects:
Code: [Select]
// function object
 // constructor
 myObject (const int value) : value_ (value) {}
 // operator ()
 void operator () (void)
   Serial.print ("Value = ");
   Serial.println (value_);
   }  // end of operator ()
 private:
   int value_;
 myObject obj1 (42);
 myObject obj2 (22);
 myObject obj3 (55);
  // call the function objects
 obj1 ();
 obj2 ();
 obj3 ();
void loop() { }
Output:
Code: [Select]
Value = 42
Value = 22
Value = 55
In this case the object "behaves like" a function, except you can hold private variables (state). Quite a useful trick if you want multiple copies of a function that do the same thing but "remember" things between function calls.
JohnHoward
Clever fellow!  I must digest more fully, but much like I often do with passing anonymous functions in javascript.
PeterH
#7
Dec 14, 2013, 03:43 am Last Edit: Dec 14, 2013, 03:45 am by PeterH Reason: 1
I think it's closer to creating a closure in Javascript.
JohnHoward
