Topic: Splitting words out of a char * string (Read 983 times) previous topic - next topic
majenko
Just thought I'd share a little routine with you all that I find very useful.
The idea of this function is to split words out of a char * string (C string) in the same way that the Unix shell does - that is, things between " and " are returned complete, as well as things between ' and '.  Spaces can be escaped with a backslash.
Code: [Select]
*  Word Parsing Routine.
*  Majenko Technologies, 2013
*  Routine to split words out of a string using standard
*  UNIX-style command-line escaping.  Anything between
*  matching single- or double-quotes is taken as one single
*  atomic unit and returned as a word.  Any spaces preceeded
*  by a backslash (\) are taken as part of the current word
*  instead of word breaks.  Spaces and tabs are both used for
*  word break characters.
*  The first time you call the routine with a fresh string
*  you provide the pointer to the start of the string.
*  Subsequent calls with the same string should have NULL passed
*  as the string - it keeps an internal static pointer for its
*  progress through the string.
*  Returns a pointer to the next word or NULL if no more
*  words exists.
*  This routine modifies the string in place.
char *getWord(char *buf) {
    static char *ptr = NULL;
    char *start, *scan;
    char term = ' ';
    if (buf != NULL) {
        ptr = buf;
    while (*ptr == ' ' || *ptr == '\t' && *ptr != '\0') {
        ptr++;
    if (*ptr == '\0') {
        return NULL;
    if (*ptr == '"' || *ptr == '\'') {
        term = *ptr;
        ptr++;
    start = ptr;
    while (*ptr != '\0') {
        if (*ptr == '\\') {
            for (scan = ptr; *scan != '\0'; scan++) {
                *scan = *(scan+1);
            ptr++;
            continue;
        if (*ptr == term || (term == ' ' && *ptr == '\t')) {
            *ptr = '\0';
            ptr++;
            return start;
        ptr++;
    if (ptr == start) {
        return NULL;
    return start;
    char test[80];
    // This is the string we're going to split.  It may have arrived via serial?
    sprintf(test, "The following \"escaped section\" should not\\ be\\ separated");
    // We get the first word from the string
    char *b = getWord(test);
    while (b) {
        Serial.println(b);
        // All subsequent words come from the internal static pointer
        b = getWord(NULL);
The example string
Code: [Select]
The following "escaped section" should not\ be\ separated
should result in this output:
Code: [Select]
The
following
escaped section
should
not be separated
Note how all the words between the quotes are kept together, and any spaces that are escaped form part of the word instead of breaking a new word.
Great for parsing simple serial command line interfaces.
Graynomad
Nice. Now maybe add the ability to change the delimiter, for CSV files etc. :)
I wrote something similar for the string class in my LPC port, each call to getword() (actually getNextField()) passed a parm that was the delimiter so I could pick and choose the "field" I wanted returned.
I never implemented protecting quoted words etc though, might have to add that :)
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
majenko
______
Rob
Yeah, but that function already exists - it's called strtok.
Graynomad
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
