Topic: Keyboard controlled robot (Read 3047 times) previous topic - next topic
erickdmarine
Hi, i purchased a robot shop rover and at the moment i have the basic wasd keyboard control code working very nicely. I also have a separate servo left and right manipulation code working nicely. I need to combine them for a presentation tommorow afternoon. Here are the two codes if someone could please mix them so that they both function together that would excellent. Thankyou
Code 1 Basic wasd control
/*To control the rover, Copy and paste the code below into the Arduino software*/
int E1 = 6; //M1 Speed Control
int E2 = 5; //M2 Speed Control
int M1 = 8; //M1 Direction Control
int M2 = 7; //M2 Direction Control
void setup(void)
  int i;
  for(i=5;i<=8;i++)
  pinMode(i, OUTPUT);
  Serial.println("setup");
void loop(void)
  while (Serial.available() < 1) {} // Wait until a character is received
  char val = Serial.read();
  int leftspeed = 120; //255 is maximum speed
  int rightspeed = 120;
  switch(val) // Perform an action depending on the command
    case 'w'://Move Forward
    case 'W':
      forward (leftspeed,rightspeed);
    case 's'://Move Backwards
    case 'S':
      reverse (leftspeed,rightspeed);
    case 'a'://Turn Left
    case 'A':
      left (leftspeed,rightspeed);
    case 'd'://Turn Right
    case 'D':
      right (leftspeed,rightspeed);
    default:
      stop();
void stop(void) //Stop
  digitalWrite(E1,LOW);
  digitalWrite(E2,LOW);
  Serial.println("stop");
void forward(char a,char b)
  analogWrite (E1,a);
  digitalWrite(M1,LOW);
  analogWrite (E2,b);
  digitalWrite(M2,LOW);
  Serial.println("forward");
void reverse (char a,char b)
  analogWrite (E1,a);
  digitalWrite(M1,HIGH);
  analogWrite (E2,b);
  digitalWrite(M2,HIGH);
  Serial.println("reverse");
void left (char a,char b)
  analogWrite (E1,a);
  analogWrite (E2,b);
  Serial.println("left");
void right (char a,char b)
  analogWrite (E1,a);
  analogWrite (E2,b);
  Serial.println("right");
Code 2 servo control
* NewSerialServo
* Servo control from the Serial port
* Alteration of the control interface to use < and > keys
* to slew the servo horn left and right.  Works best with
* the Linux/Mac terminal "screen" program.
* Created 10 December 2007
* copyleft 2007 Brian D. Wendt
* http://principialabs.com/
* Adapted from code by Tom Igoe
* http://itp.nyu.edu/physcomp/Labs/Servo
/** Adjust these values for your servo and setup, if necessary **/
int servoPin     =  2;    // control pin for servo motor
int minPulse     =  600;  // minimum servo position
int maxPulse     =  2400; // maximum servo position
int turnRate     =  200;  // servo turn rate increment (larger value, faster rate)
int refreshTime  =  30;   // time (ms) between pulses (50Hz)
/** The Arduino will calculate these values for you **/
int centerServo;         // center servo position
int pulseWidth;          // servo pulse width
int moveServo;           // raw user input
long lastPulse   = 0;    // recorded time (ms) of the last pulse
  pinMode(servoPin, OUTPUT);  // Set servo pin as an output pin
  centerServo = maxPulse - ((maxPulse - minPulse)/2);
  pulseWidth = centerServo;   // Give the servo a starting point (or it floats)
  Serial.println("      Arduino Serial Servo Control");
  Serial.println("Press < or > to move, spacebar to center");
  // wait for serial input
  if (Serial.available() > 0) {
    // read the incoming byte:
    moveServo = Serial.read();
    // ASCII '<' is 44, ASCII '>' is 46 (comma and period, really)
    if (moveServo == 44) { pulseWidth = pulseWidth - turnRate; }
    if (moveServo == 46) { pulseWidth = pulseWidth + turnRate; }
    if (moveServo == 32) { pulseWidth = centerServo; }
    // stop servo pulse at min and max
    if (pulseWidth > maxPulse) { pulseWidth = maxPulse; }
    if (pulseWidth < minPulse) { pulseWidth = minPulse; }
    // print pulseWidth back to the Serial Monitor (uncomment to debug)
    // Serial.print("Pulse Width: ");
    // Serial.print(pulseWidth);
    // Serial.println("us");   // microseconds
  // pulse the servo every 20 ms (refreshTime) with current pulseWidth
  // this will hold the servo's position if unchanged, or move it if changed
  if (millis() - lastPulse >= refreshTime) {
    digitalWrite(servoPin, HIGH);   // start the pulse
    delayMicroseconds(pulseWidth);  // pulse width
    digitalWrite(servoPin, LOW);    // stop the pulse
    lastPulse = millis();           // save the time of the last pulse
PaulS
Quote
I could take the odd numbered lines from one file and the even numbered lines from the other file and put them in a new file. I could sort them alphabetically.
Of course, the result wouldn't compile. Nor, would it do what you want. Of course, that last statement is only a supposition, since you didn't bother saying what you want the final program to do.
If you were making the presentation to me, and couldn't explain the code, I'd give you a failing grade, even if the robot could dance the entire Ring Opera in 20 minutes.
erickdmarine
My apoligies. And the presentation would be stated allot better than that trust me. What i need to be able to do is control the rover, front, back, left right like it already does in the wasd code. And control the servo to move the mount its upporting left and right like the servo coder can do on its own. I need to be able to do both at the same time.
PaulS
Quote
So, specifically, what is the problem?
What have you tried, in terms of merging the code?
erickdmarine
The problem is once I make an attempt at merging the two codes and I can only move te rover not the servo I have setup. Basically I've tried taking each section of servo code and putting it where I believed it belonged in the wasd control code. It all condenses however does not allow me to control servos and rover at same time.
JimboZA
I'm looking at the code right now, and it's soooooo difficult to read without the code tags.
Please, go and Modify that post. Select the code text, hit the # key above the  :smiley-sweat: smily so that the code gets
Code: [Select]
formatted like this.
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
