Topic: Simple DAC output (Read 1 time) previous topic - next topic
Hi I'm really new in Arduino.. I'm just trying to get two DAC output from Arduino with one for minimum and another for maximum. can you please help me. to write the code for that.
Thanks in advance
Grumpy_Mike
MarkT
You can increase the resolution from the default of 8 bit (upto 12 bits) using the
Code: [Select]
analogWriteResolution(12) ;
And then provide values from 0.. 4095 to analogWrite().
Thus:
Code: [Select]
  analogWriteResolution (12) ;
  for (int i = 0 ; i < 4096 ; i++)
    analogWrite (DAC0, i) ;
    delayMicroseconds (100) ;
(The Due native DAC resolution is 12 bits, the default at start up is only 8 to be
compatible with other Arduinos)
[ I won't respond to messages, use the forum please ]
Thanks a lot for the help. it worked.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
