Topic: Arduino Yun temperature web panel example (Read 4497 times) previous topic - next topic
Rico_Bravo
not working?
All I get is a zero in the upper left corner of the web page?
It also asked me to login into arduino server??
Help please.   =(
Thanks
raxpa
A lot of questions...
let's start from the beginning ... follow this sample
http://scuola.arduino.cc/courses/lessons/view/zzdeJ3m
is better ... ad remember that in your sketch folder you must create a folder named www ad put index.html and the .js file
Rico_Bravo
Thank you so much!
I just replaced the code for my temperature sensor LM34 which is what I am using and then BOOM everything work!!!  :)
vmdg
Hello raxpa
My page says "Waiting for Arduino"
Where do you issue the "temperature" command (string)?
tia
DannySwarzman
In the documentation at http://arduino.cc/en/Tutorial/TemperatureWebPanel it says:
"In this sketch folder is a basic webpage and a copy of zepto.js, a minimized version of jQuery."
After installing the latest IDE, I didn't see that. Does anyone know where the folder is?
chrisnet
If you go to arduino install directory
and then the libraries folder
then the Bridge folder
then the examples folder
then the TemperatureWebPanel folder!
Then you will see the www folder right next to the  TemperatureWebPanel.ino sketch in there you will find the index.html and the zepto.min files.
Al so I had to use the url of the Yun in place of the Yun's name "192.168.1.103" in place of "ardunio" in order for the html page to come up, don't ask me why because I have no idea! Maybe someone else could answer that?
So the url would look something like this
http://192.168.1.103.local/sd/TemperatureWebPanel
vmdg
All
  I was getting '0' just like the opening message of this topic.
because of using ie8,  zepto.js must not work with ie8.   jQuery 1.x
works.  The newer jquery 2.x doesn't. They explicitly say can't be used
with ie6, ie7, or ie8.    Also there is a compressed or minimized version
of jQuery 1.x  to download which works.
ElROnaldo
How can I adjust this script so it does not require a login when visiting the web page?
I had an index.html (since renamed) in this same directory that did not require a login.
ElROnaldo
Angelo9999
To disable the login request you have to change the REST API access to open http://arduino.cc/en/Guide/ArduinoYun#toc5
https://github.com/sngl
hankk
I have only  "0" i try change zepto.js on  jQuery 1.x but it did not help.
