Topic: Digital scale (precise 0.01g) (Read 9954 times) previous topic - next topic
matsuo
Hello !
           I need to make digital scale with precise  0.01g , I have component as below
1. Load cell 300g
2. Ina125p (nstrumentation Amplifiers  max gain: 10,000 )
3.MCD3424  (Analog to digital convertor 18 bit)
4.Arduino mega2560
   My question :  I know Arduino have 10 bit (1024) ,so resulotion=300/1024 = 0.29 mv/step but I need 0.01 mv/step !!
so i have to use  external  ADC !.
#1. Can i  use (Load cell 300g===>MCD3424 ==>Arduino ) make  digital scale with precise  0.01g  , is it possible?
#2. If it's impossible,  I must use  (Load cell 300g==>Ina125p ===>MCD3424 ==>Arduino ) or not? How to design circuit
This's  calulation (codition #2)
This's my circuit (codition #2)
Can someone advice me, please
I'm sorry for my english is not well !  :smiley-mr-green:
michinyon
You will not succeed in making a device which is accurate to one part in 30000 of full scale.
matsuo
Did you mean that   I  have to  connect Load cell ==>Ina125p ===>MCD3424 ==>Arduino  ?
  :smiley-roll-blue:
Grumpy_Mike
#3
Dec 19, 2013, 05:58 am Last Edit: Dec 20, 2013, 05:03 pm by Grumpy_Mike Reason: 1
No he means you will not succeed because this is an unrealistic design requirement given the resources you have.
Are there any commercial scales like that? If so how much do they costs? Are you expecting to match this at a lower cost?
shooter
good possible however the input of your ADC needs big voltage so you will need the INA.
The loadcell power supply should come from the reference voltage as this is important the output is 10mV/V for example
paul deelen
shooter@home.nl
making controls with codesys PLC and arduino
matsuo
#5
Dec 23, 2013, 10:44 am Last Edit: Dec 23, 2013, 10:48 am by matsuo Reason: 1
@Shooter : Thanks for your advice!  Can I use Vref=5 v  for both of device?  :smiley-mr-green:
joemcder
Precision digital scales that I have used  do not work this way.
They use a current and magnetic field to balance the weight restoring the effective load to zero.
polymorph
I would not use Vcc (ie, ARef = 5V) for anything requiring any kind of precision. Noise, variations due to loads and digital switching noise.
Steve Greenfield AE7HD
Drawing Schematics: tinyurl.com/23mo9pf - tinyurl.com/o97ysyx - tinyurl.com/q7uqnvn
Multitasking: forum.arduino.cc/index.php?topic=223286.0
gammon.com.au/blink - gammon.com.au/serial - gammon.com.au/interrupts
polymorph
The balance thing is the way to do it. You can pick off the difference signal and filter out all the noise.
matsuo
#9
Dec 26, 2013, 08:01 am Last Edit: Dec 26, 2013, 10:43 am by matsuo Reason: 1
If I don't use Aref=5V , what could i use refer ?
This is my circuit
This is code
#include <Wire.h>
#include "MCP3424.h"
// Configuration variables for MCP3424
#define address  0x69 // address of this MCP3424. For setting address see datasheet
byte gain = 0; // gain = x1
byte resolution = 2; // resolution = 16bits
MCP3424 ADC1(address, gain, resolution); // create MCP3424 instance.
// Set the software mode and set the analog pin
int calibrate = 1; // 0 = Output to Processing Application, 1 = Calibration mode
int i = 0;
// Low end of the test load values
float loadLow = 0.00; // measured low end load in grammes from good scales
float analogLow = 242.65;; // analog reading from load cell for low end test load
// High end of the test load values
float loadHigh = 142.55; // measured high end load in grammes from good scales
float analogHigh = 708.84; // analog reading from load cell for high end test load
// This is used when you change the load cell platform to something else that weighs
// different and the load is no longer on zero. Add an offset to set to zero.
float loadAdjustment = 0;  // Adjust non loaded load cell to 0
// Values for the analog sample buffer for running average to smooth analogue reads
int samplesBuffer = 50; // Should be the same as the number of samples
float analogSamples[50] = {0}; // Number of analog samples to average and set to 0
int lastSampleIndex = 0; // Last analog sample
float sampleBufferTotal = 0; // The sum of all the samples held in the buffer
float analogSamplesAverage = 0; // Running average of the sum of the buffer
// Results plot or display frequency
long time = 0;  // Set time to mark start of delay
int plotDelay = 10; // Time gap between plots for display or graph
 if (calibrate) {
//   Serial.begin(9600);  // Set a slower boadrate for calibration
   plotDelay = 1000;  // Slow the readings output to display for calibration
//Serial.begin(115200);  // Set a faster baudrate for Processing Application
    Wire.begin();
float analogValue = ADC1.getChannelmV(0);
 // Add new analog reading to buffer and return oldest reading
float oldestSample = addSample(analogValue);
 // Get running average, pass the latest and oldest analog sample reading
 analogSamplesAverage = runningAverage(analogValue, oldestSample);
 if(millis() > time + plotDelay){
   // Convert analog value to load in grams
   float loadGrams = mapfloat(analogSamplesAverage, analogLow, analogHigh, loadLow, loadHigh);
         loadGrams = loadGrams-loadAdjustment ;  // Shift the load to measure from 0 load
   if (calibrate) {// print test results
     Serial.print("Analog pin value: ");Serial.println(analogValue);
     Serial.print("Smoothed analog value: ");Serial.println(analogSamplesAverage);
     Serial.print("Scale load (grammes): ");Serial.println(loadGrams,2);
     Serial.println(" ");
    delay(50);
   } else {  // Output to Processing as such
    Serial.print("Load:"); Serial.println(loadGrams,2);
   // delay(500);
   time = millis();  // Set time to mark start of delay
float mapfloat(float x, float in_min, float in_max, float out_min, float out_max)
 return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
// Function - running average
float runningAverage(float newSample, float oldSample) {
 // Add new sample and subtract old sample from the samples buffer total
 // then return sample average
 sampleBufferTotal += newSample;  // Add new analog sample
 sampleBufferTotal -= oldSample;  // Subtract oldest analog sample
 return sampleBufferTotal / samplesBuffer;  // Return average analog sample reading
// Function - add and remove analog samples from ring buffer, return oldest sample
// The ring buffer is used to keep track of the oldest sample.
float addSample( float newSample) {
 // Add new analog read sample to the ring buffer and return the oldest analog reading
float oldSample;
 if (lastSampleIndex == samplesBuffer - 1 ) { // Check if end off buffer reached
   oldSample = analogSamples[0];  // Get old analog sample from start of buffer
   analogSamples[0] = newSample;  // Add new analog sample to start of buffer
   lastSampleIndex = 0;  // Record sample index currently working on
   lastSampleIndex ++;  // Move to next index
   oldSample = analogSamples[lastSampleIndex];  // Get old analog sample
   analogSamples[lastSampleIndex] = newSample;  // Add new analog sample
 return oldSample;  // Return old analog sample
This picture is reading from MCP3424 ,I think that it has many noise .How to reduce noise ?
polymorph
Use the internal reference voltage. On most Arduinos, that is 1.1V. It isn't exact so you'll have to calibrate for it, but it is very stable over time and temperature.
Use bypass capacitors liberally. A 1nF and 1uF on the ARef pin. With an Arduino, you can't really add an isolation resistor and capacitor to the power pin to the ADC in the Arduino as suggested by Atmel, unless you are using a Freeduino.
matsuo
#11
Jan 13, 2014, 01:56 pm Last Edit: Jan 13, 2014, 02:10 pm by matsuo Reason: 1
Thanks you for your advice, Now I've changed ADC from MCP3424 ( 18 bit ) to LTC2400 ( 24 bit )
As you can see my video,   i used voltage referent 3.3 volt at LTC2400 from arduino board and Vref = 5v at INA125
, used the power supply 5 v both of 2 IC   but a voltage is not stable. How to solve this problem? =(
***i'm so sorry about my English is not well  :smiley-red:
http://www.youtube.com/watch?v=U0jelwgRgZI
polymorph
The 3.3V output from an Arduino is just another DC power supply voltage. Not as stable as a reference voltage.
If you are using an external ADC, especially one that is 18 or 24 bits, you need something much better than the Arduino's internal reference. Use one of the many ICs made just to supply a reference voltage, they are much stabler and more accurate. When I mentioned the internal reference, I'd forgotten that you are using a much higher bit external ADC.
With 18 and especially 24 bits, you are going to need really, really well filtered power supplies and a very, very low noise, low offset, low drift instrumentation amplifier.
matsuo
#13
Jan 17, 2014, 11:35 am Last Edit: Jan 18, 2014, 11:47 am by matsuo Reason: 1
Thanks you again
                Now I'm using  a referrence voltage Ic ( REF195 : 5.00 v)  at ADC pin (V ref pin) i got a stable voltage more but i thing it isn't enough. I have some a question to ask you should i use a reference voltage to Vcc of Ina125 (amp) and Load cell ?
emily66013
#14
Jan 25, 2014, 07:22 am Last Edit: Jan 29, 2014, 06:13 am by emily66013 Reason: 1
It's depend on you which  kind of digital scale you need. A loot of different digital scales are available for different purposes .Please specify that for which purpose you need digital scale.
