Topic: Why the signal strength is empty? (Read 5147 times) previous topic - next topic
tseeteck
I'v a GSM shield and Arduino Uno. I am able to get the following message from Serial Monitor using example programme: GSM/Tools/gsmNetworkScan.
GSM networks scanner
looping start
looping end
Modem IMEI: 359231038101091
Scanning available networks. May take some seconds.
> STARHUB Pte Ltd
> MOBILEONE
> SingTel
Current carrier:
Signal Strength:  [0-31]
Current carrier:
Thanks for any help...
toonlumberjack
same here. Did you solve the problem?
Best regards
davidgoth
Execute the sketch replacing the line:
GSM gsmAccess;
with:
GSM gsmAccess(true);
Post your serial output.
RayIshido
Replacing GSM gsmAccess; with: GSM gsmAccess(true); doesn't change the serial output. I partially solved the problem commenting this lines:
//  Serial.println("Scanning available networks. May take some seconds.");
//  Serial.println(scannerNetworks.readNetworks());
now "current carrier" and "signal strength" are working.
davidgoth
I don't understand. In my shield in Spain works perfectly. Although, it's possible there may be a bug in the library.
Could you show more details?.
Saphyr
i have a similar problem, but i didnt find a solution for me. if i upload program from my old notebook (Dell Vostro, win7 sp1) everything works good. Bud if i upload the same scatch from any other computer, signalStr is 0. Please, can someone help me?
Code:
#include <GSM.h>
#define PINNUMBER ""
#define GPRS_APN       "Internet"
#define GPRS_LOGIN     ""
#define GPRS_PASSWORD  ""
GSMClient client;
GPRS gprs;
GSMScanner signalScanner;
GSMModem modem;
boolean unconnected = true;
boolean serverConnected = false;
String IMEI = "";
while (unconected) {
    if (gsmAccess.begin(PINNUMBER) == GSM_READY){
      Serial.println("GSM ready");
      if  (gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD) == GPRS_READY) {
      unconnected = false;
      Serial.println("!!!!!! ERROR !!!!!!");
      delay(200);
  Serial.println("GPRS ready");
  String net;
  int signalStr;
  net = signalScanner.getSignalStrength();
  signalStr = net.toInt() * (100 / 31);
  Serial.print("signal strength: ");
  Serial.print(SignalStr);
  Serial.println(" %");
delay(2000);
