TomGeorge:
Hi, I'm not familiar with the mega, but you shouldn't have set outputs LOW on startup.
Can you post your complete sketch and let us find the solution.
Have you used PINMODE to set your pins up as inputs and outputs?
Tom....
Sure.This is the sketch.I shortened the sketch.But the idea is the same.
int analog1 = A1;
int analogread1 = 0;
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
pinMode(11, OUTPUT);
pinMode(12, OUTPUT);
pinMode(13, OUTPUT);
pinMode(14, OUTPUT);
pinMode(15, OUTPUT);
pinMode(16, OUTPUT);
pinMode(17, OUTPUT);
pinMode(18, OUTPUT);
pinMode(19, OUTPUT);
pinMode(20, OUTPUT);
pinMode(21, OUTPUT);
pinMode(22, OUTPUT);
pinMode(23, OUTPUT);
pinMode(24, OUTPUT);
pinMode(25, OUTPUT);
pinMode(26, OUTPUT);
pinMode(27, OUTPUT);
pinMode(28, OUTPUT);
pinMode(29, OUTPUT);
pinMode(30, OUTPUT);
pinMode(31, OUTPUT);
pinMode(32, OUTPUT);
pinMode(33, OUTPUT);
pinMode(34, OUTPUT);
pinMode(35, OUTPUT);
pinMode(36, OUTPUT);
pinMode(37, OUTPUT);
pinMode(38, OUTPUT);
pinMode(39, OUTPUT);
pinMode(40, OUTPUT);
pinMode(41, OUTPUT);
pinMode(42, OUTPUT);
pinMode(43, OUTPUT);
pinMode(44, OUTPUT);
pinMode(45, OUTPUT);
pinMode(46, OUTPUT);
pinMode(47, OUTPUT);
pinMode(48, OUTPUT);
pinMode(49, OUTPUT);
pinMode(50, OUTPUT);
pinMode(51, OUTPUT);
pinMode(52, OUTPUT);
pinMode(53, OUTPUT);
void loop(){
analogread1 = analogRead (analog1);
if ((analogread1 >= 100 && analogread1 <= 200)) {
digitalWrite(2, LOW);
digitalWrite(3, LOW);
digitalWrite(4, HIGH);
digitalWrite(5, LOW);
digitalWrite(6, LOW);
digitalWrite(7, LOW);
digitalWrite(8, HIGH);
digitalWrite(9, LOW);
digitalWrite(10, LOW);
digitalWrite(11, LOW);
digitalWrite(12, HIGH);
digitalWrite(13, LOW);
digitalWrite(14, LOW);
digitalWrite(15, HIGH);
digitalWrite(16, HIGH);
digitalWrite(17, LOW);
digitalWrite(18, LOW);
digitalWrite(19, HIGH);
digitalWrite(20, HIGH);
digitalWrite(21, LOW);
digitalWrite(22, LOW);
digitalWrite(23, LOW);
digitalWrite(24, HIGH);
digitalWrite(25, LOW);
digitalWrite(26, LOW);
digitalWrite(27, HIGH);
digitalWrite(28, LOW);
digitalWrite(29, LOW);
digitalWrite(30, LOW);
digitalWrite(31, HIGH);
digitalWrite(32, LOW);
digitalWrite(33, LOW);
digitalWrite(34, LOW);
digitalWrite(35, HIGH);
digitalWrite(36, LOW);
digitalWrite(37, LOW);
digitalWrite(38, LOW);
digitalWrite(39, HIGH);
digitalWrite(40, LOW);
digitalWrite(41, LOW);
digitalWrite(42, LOW);
digitalWrite(43, HIGH);
digitalWrite(44, LOW);
digitalWrite(45, LOW);
digitalWrite(46, LOW);
digitalWrite(47, HIGH);
digitalWrite(48, HIGH);
digitalWrite(49, HIGH);
digitalWrite(50, HIGH);
digitalWrite(51, HIGH);
digitalWrite(52, HIGH);
digitalWrite(53, HIGH);
else {
if ((analogread1 >= 300 && analogread1 <= 400) ) {
digitalWrite(2, HIGH);
digitalWrite(3, HIGH);
digitalWrite(15, LOW);
digitalWrite(19, LOW);
digitalWrite(26, HIGH);
digitalWrite(40, HIGH);
digitalWrite(48, LOW);
digitalWrite(49, LOW);
digitalWrite(51, LOW);
digitalWrite(52, LOW);
else {
if ((analogread1 >= 500 && analogread1 <= 600)) {
digitalWrite(6, HIGH);
digitalWrite(14, HIGH);
digitalWrite(18, HIGH);
digitalWrite(29, HIGH);
digitalWrite(53, LOW);
else {
digitalWrite(22, HIGH);
digitalWrite(46, HIGH);
