Topic: negative wire problem (Read 1 time) previous topic - next topic
donce16
Dec 27, 2013, 02:10 pm Last Edit: Dec 27, 2013, 02:58 pm by donce16 Reason: 1
Hi! i'm having a little problem. Then i touch negative wire led's turn on, I don't know why...
Pin 2 in arduino always turned on. Then i don't touch negative wire, led don't turn on... Image:
pwillard
#1
Dec 27, 2013, 04:18 pm Last Edit: Dec 27, 2013, 04:19 pm by pwillard Reason: 1
Where are you getting such bad ideas about how transistors really work.
Your drawing is wrong,  For one, you are missing a base current limit resistor.  Are you sure you have a PNP transistor?  Because that is what you have drawn... and that would be the wrong part here.
MarkT
The original bad circuit is holding the PNP base-emitter junction at the point
of reverse breakdown, so a small extra voltage is perhaps all that's needed to
modulate the current substantially.   Or it could be that the circuit is undergoing
parasitic oscillation which is damped down by touching the ground wire.
Anyway it doesn't matter, its completely wrong in the first place!  You may have
damaged both pin 2 and the PNP transistor, note, double check they still work
(reverse biasing the base-emitter junctions usually fries a transistor, and the breakdown
voltage is often about 5V)
donce16
Now i have problem, pin from  2 to 12 led didn't turn on, but then i connect led to pin 13 its perfectly work. Please help. IMAGE:
polymorph
LEDs require current limiting resistors when used this way. Pin 13 has one built-in, none of the other pins do. You may have burned out either the LED or the pins on the Arduino.
Steve Greenfield AE7HD
Drawing Schematics: tinyurl.com/23mo9pf - tinyurl.com/o97ysyx - https://tinyurl.com/Technote8
Multitasking: forum.arduino.cc/index.php?topic=223286.0
gammon.com.au/blink - gammon.com.au/serial - gammon.com.au/interrupts
donce16
Arduino nano. from 2-12 pins i get 1.52 volts, from 13 3.40 volts, from 5v only 3.5 volts.
Grumpy_Mike
Have you set the pins to be outputs using a pinMode call?
You sure your meter is correct?
donce16
OH YES, i forget to write  pinMode(ledPin, OUTPUT); Thanks dude, very helped. :))
Then all led's off i get 3.60 volts.
