Topic: Psuedo Random 4 LED twinkler (Read 9868 times) previous topic - next topic
SargentSeven
Dec 28, 2013, 12:12 am Last Edit: Dec 29, 2013, 12:15 am by SargentSeven Reason: 1
Hi there, First time posting a project up here.
I have designed and coded a circuit for the ATTiny85 that Randomly blinks at random durations 1 of 4 LEDs.
I am only using 2 of the 6 pins available on the chip by using the Tri state function of the GPIO pins.
(in plain English, I made the two pins do 3 different things, Sink, source, and Open (or HI-Z))
I programmed everything with the MIT method using an Uno as an ICSP.
The relevant part of this project is the code. I'm not sure if anyone has posted anything similar but I pretty much did this without much reference to anything else.
here is the code.
Code: [Select]
Code by Nick Tracy 2013
May contain code parts from other programs, all credit goes to those who helped.
Designed around the ATTiny85 @ 8 Mhz with internal oscillator, accuracy is not important here and is actually beneficial.
This code uses a random number generator to simulate a twinkling effect on 4 different outputs.
Used in a decoration for the holidays, can be used for just about anything really.
it uses 4 LEDs connected to 2 pins (3 and 4 for ATTiny85) that are Tri-stated to provide a HIGH, LOW, and High Impedance output.
the LEDs are connected in a sink/source set up on each pin. when the pin mode is changed to the third state the LEDs on that pin are off.
//Use Define so that not a lot of memory is wasted.
#define LED1 3
#define LED2 4
//long for random number variables
long rand1;
long rand2;
long rand3;
 pinMode(LED1, INPUT_PULLUP);
 pinMode(LED2, INPUT_PULLUP);
 //Generate Random numbers seed
 randomSeed(12345612);
 rand1 = random(1,5); //Used for selecting which LED to fire.
 rand2 = random(5,20); //Used to determine delay for On.
 rand3 = random(50,300); //Used to determine delay for Off.
 //Switch case for selecting the appropriate LED
 //Fires one Random LED at a time each loop at a random duration On and Off.
 switch (rand1){
 case 1:
   pinMode(LED1, OUTPUT); //set pin mode to output
   pinMode(LED2, INPUT_PULLUP); //makes sure other output is off
   digitalWrite(LED1, HIGH); //turn on led number 1 of 4
   delay(rand2); //delay for On duration
   pinMode(LED1, INPUT_PULLUP); //turn off the output
   delay(rand3); //delay before next cycle
 case 2:
   digitalWrite(LED1, LOW); //turn on led number 2 of 4
 case 3:
   pinMode(LED2, OUTPUT); //set pin mode to output
   pinMode(LED1, INPUT_PULLUP); //makes sure other output is off
   digitalWrite(LED2, HIGH); //turn on led number 3 of 4
   pinMode(LED2, INPUT_PULLUP); //turn off the output
 case 4:
   digitalWrite(LED2, LOW); //turn on led number 4 of 4
 default:
   //If no LED is selected, turn off all LEDs for a random amount of time.
   delay(rand2);
EDIT: The LEDs I used were White with a 3.2v drop and 20ma draw. but with different resistor values you can use any LED so long as you choose the correct current limiting resistor for your LED.
My only issue here is that two of the LEDs are dimly lit in the HI-Z state due to the internal pull up resistors. there is just enough current to light the LEDs I'm using. if anyone has a recommendation for that let me know.
Motivation comes in the form of knowing the wife is going to hurt me if I don't follow through with my projects after spending our entertainment budget on parts. XD
Coding Badly
Quote
Schematic?
SargentSeven
#2
Dec 28, 2013, 03:31 am Last Edit: Dec 28, 2013, 07:53 pm by SargentSeven Reason: 1
Here it is, If i had a good camera I would upload a video to youtube.
EDIT: added more traditional schematic as well.
EDIT EDIT: Removed schematic due to error in wiring.
EDIT to the EDIT that I EDITED: New Fritzing diagrams with correct wiring. sorry
P.S. I'm refusing to use fritzing anymore, what a terrible program. going back to hand drawing.
SargentSeven
This method could be used to expand the amount of leds. Just duplicate this to each pin and change the code accordingly by adding new case switch statements and changing the max number for the random function.
Coding Badly
Uh, how do you light any of the LEDs?  For example LED2 and LED4 have the cathodes connected to Vcc.  No matter what you do with pin 4 (physical pin 3) neither of those LEDs is going to conduct.
SargentSeven
#5
Dec 28, 2013, 04:08 am Last Edit: Dec 28, 2013, 04:38 am by SargentSeven Reason: 1
Sorry I'm new to fritzing and wasn't paying attention to that, I was more concerned with getting the traces to look nice and kinda threw that up in a hurry.
on my breadboard they are hooked up correctly.
fungus
How about a schematic that fits on the screen?
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
SargentSeven
You can easily view the image by right clicking it and clicking "view image" it will open the full image in a new window. I won't change the resolution of the image because it may lower the quality, not my fault the arduino forum can't properly handle image attachments like every other forum software out there.
SargentSeven
and why is there so much interest in the schematic? there isn't anything there besides 2 pins and 4 leds with resistors. the main focus of this project was the code.
its as simple as connecting it like this
| ATtiny85 |
Physical pin 2---------(a)LED1(c)-------100ohm--------Common -
Physical pin 2---------(c)LED2(a)-------100ohm--------Positive 5v
Physical pin 3---------(a)LED3(c)-------100ohm--------Common -
Physical pin 3---------(c)LED4(a)-------100ohm--------Positive 5v
4 to ground
8 to Vcc 5v
very simple.
Coding Badly
Two reasons...
1. I assumed you are wiring the LEDs the way you are in fact wiring them.  If the forward voltage was close to 2.5V it could explain the symptom.  In your first post you failed to mention the fact that you are using white / forward voltage = 3.2V LEDs.  By asking for the schematic I can validate my assumption and confirm the forward voltage is high enough for the circuit to work.
2. Anyone new to Arduinos / electronics who wants to build a similar device is going to have trouble without a schematic.  In addition, they would be rather disappointed if they had used red LEDs instead of white.  By providing details you are helping future adventurers.
Coding Badly
Now, back to the dim LEDs...
Change INPUT_PULLUP to INPUT.  All lines like this...
[font=Courier New]  pinMode(LED2, INPUT_PULLUP); //makes sure other output is off[/font]
...become this...
[font=Courier New]  pinMode(LED2, INPUT); //makes sure other output is off[/font]
SargentSeven
#11
Dec 28, 2013, 11:57 pm Last Edit: Dec 29, 2013, 12:08 am by SargentSeven Reason: 1
...become this...
The reason I used the internal pullup resistors is because i had read that with any CMOS chip, if you leave an input pin floating in this circuit, you could damage the chip. is this not true for the AVR chips?
here is my source for this information, in the comment section someone brought up this point about using internal pullups to prevent burning up the pins. http://www.neufeld.newton.ks.us/electronics/?p=151
SargentSeven
I tried this with other LEDs besides red and i can confirm that it will work with most leds, for the red all i had to do was change the resistor to 150ohm and it worked the same.
I apologize, i kind of assumed that LEDs and current limiting resistors were pretty entry level knowledge. if someone is trying to get into this project and doesn't know at least that much then they should be starting on something simpler IMO.
Coding Badly
#13
Dec 29, 2013, 12:14 am Last Edit: Dec 29, 2013, 12:18 am by Coding Badly Reason: 1
This appears to be a good description of the problem...
http://www.ti.com/lit/an/scba004c/scba004c.pdf
I'm too lazy to read it thoroughly but from a cursory glance I gather the problem has to do with overheating caused by an input floating in the linear region of the transistor or from excessive switching.  Neither of those is a problem for an AVR processor.  Switching does burn energy but nowhere near enough to cause overheating problems.
In other words, floating inputs are most certainly not a problem for AVR processors.  That's how they are initialized after a reset or power-up.
Coding Badly
Well, it's on the internet so it must be true.   ;)
