Topic: Arduino and php (Read 739 times) previous topic - next topic
pedrolopes746
I was wondering if my arduino is on or off with the following php script:
Code: [Select]
<?php
    $connected
= @ fsockopen('192.168.1.10'80$numberErro$stringErro0);
    if (
$connected) {
        echo
'arduino online';
    else {
        echo
'arduino offline';
        echo
"<br/>";
        echo
"Erro: $numberErro - $stringErro";
output:
Quote
arduino offline
destination host unreachable
but does not work ..
Arduino code:
Code: [Select]
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
   0x90, 0xA2, 0xDA, 0x0E, 0xAA, 0xBB  };
IPAddress ip(192,168,1,10);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip);
  server.begin();
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
  // listen for incoming clients
  if (client) {
    Serial.println("new client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println("Connection: close");  // the connection will be closed after completion of the response
  client.println("Refresh: 5");  // refresh the page automatically every 5 sec
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
          // output the value of each analog input pin
          for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
            int sensorReading = analogRead(analogChannel);
            client.print("analog input ");
            client.print(analogChannel);
            client.print(" is ");
            client.print(sensorReading);
            client.println("<br />");
          client.println("</html>");
        if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disconnected");
any ideas?
pedrolopes746
I solved the problem by changing the following line:
$connected = @ fsockopen('192.168.1.10', 80, $numberErro, $stringErro, 5);
The timeout cannot be zero.
