Topic: High Frequency Outputs with Arduino? (Read 709 times) previous topic - next topic
metaBit
Hello,
I am wondering if it is possible to get output frequencies of between 100kHz and 200kHz with Arduino?
From reading the ATMEGA168 data sheet it certainly seems possible if I were to program it in assembly, but I think that would mean I would have to get a new programmer. I'd prefer to just program the ATMEGA using my Arduino board.
Is it possible to access the timers through the Arduino programming environment so that I can get high frequency outputs?
Thanks!
Cheater
A) Said programmer is only 4 resistors or so. :)
B) C is translated to a .hex file and then transfered. Assembly is processed the same way. You'd just need to figure out the right commands to use assembly.
metaBit
I found the answer in several posts.
To summarize: you can use the built in Port Manipulation: DDRx, PORTx, PINx to set or clear the pin(s)  and use inline assembly NOPs (or loops of them) to delay the amount you need to create the frequency you need. Each NOP takes 62ns. To execute a NOP you use the inline assembly directive: asm("NOP"); or __asm__("NOP");
http://www.arduino.cc/en/Reference/PortManipulation
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1169088394
Hope this helps anyone else who wants to create fast output frequencies.
westfw
Of course, you can put more than "nop" instructions into inline assembler statements, even within code that is to be compiled and downloaded from the arduino environment.  The arudino/wiring/etc encourages use of a somewhat limited subset of the C/C++ languages, but it doesn't restrict you to that subset.
In theory, you  can also write assembler in some other assembly language and somehow produce library files that are compatible with the gnu avr linker.  (I don't know which assemblers can produce these, but there might be SOME!)
follower
Someone please correct me if I'm wrong but my understanding is that you could write a pure-assembly program and upload it to the chip on the Arduino using the tools supplied with Arduino.
Until a couple of days ago I hadn't realised this but my research indicates any .hex file can be uploaded to the chip on the Arduino board.
My notes on the topic:
 http://code.rancidbacon.com/Arduino#Bootloader10
But if it met your need, inline assembly sounds like a much better option.
--Phil.
