Topic: New library: IR remote send/receive (Read 39891 times) previous topic - next topic
kenshirriff
I've written a new IR remote control library.  It handles both sending and receiving codes, and supports the Sony, NEC, RC5, and RC6 protocols.  For more details see http://arcfn.com/2009/08/multi-protocol-infrared-remote-library.html
Please take a look and let me know if you have any suggestions, bugs, etc.
bHogan
Anxious to try this. Very nice writeup.  :) You might want to put it on the Playground.
Thanks!
"Data is not information, information is not knowledge, knowledge is not understanding, understanding is not wisdom."
~ Clifford Stoll
alsterg
Great work! Does it support multiple IR receivers on the same arduino board?
kenshirriff
It doesn't currently support multiple IR receivers.
The easiest thing would be to AND the receiver outputs together (since the sensors are active-low) and provide this as a single input to the Arduino.  This would work if only one receiver is being used at a time, or if they are receiving the same signal.  You could also use multiple Arduino inputs and do this AND logic in the interrupt routine, testing if any of the inputs are low.
It would be fairly difficult to support multiple IR receivers that could receive different signals simultaneously, as each one would need to be tracked independently.
alsterg
#4
Sep 09, 2009, 01:19 am Last Edit: Sep 09, 2009, 01:20 am by alsterg Reason: 1
I have tried your library and it works great. However when I used the  same arduino board for both sending and receiving IR data I noticed the following:
1. I couldn't receive the data I was sending, but I could receive data from other IR sources. The explanation probably here is that while IR data is sent, arduino is busy and the IR reception subsystem doesn't get a chance to record data.
2. I was receiving fine up until I sent the first byte via IR. From that point and further reception of IR data from any IR source stopped. Could this be some sort of "API interference" between IRsend and IRrecv?
The program is:
#include <IRremoteInt.h>
#include <IRremote.h>
// IRSendPin fixed to 3 (PWM)
int IRRecvPin = 11;
IRsend irsend;
IRrecv irrecv(IRRecvPin);
decode_results results;
 irrecv.enableIRIn(); // Start the receiver
 if (Serial.read() != -1) {
   for (int i = 0; i < 3; i++) {
     irsend.sendSony(0x90, 8); // Sony TV power code
     delay(100);
 if (irrecv.decode(&results)) {
   Serial.println(results.value, HEX);
   irrecv.resume(); // Receive the next value
kenshirriff
You can't use sending and receiving at the same time.  When you do a send, the receiving is disabled.  To re-enable it after sending you need to call:
Ken
vios
Hi Ken,
I've tried your code and its work. I got this raw code "2FD807F"  when I press no 1 button on the remote. I am trying to make a small robot that can be control by remote.
Can you or somebody who read this  help me to trnslate this code to light an Led.
I will publish this project in my blog.
Thanks.
         http://arduinostudio.wordpress.com/
Alexander Erk
Hello all,
does anyone have an idea, who to convert the codes from Adafruits TV-B gone, to be used by this library, for an Arduino based TV-B gone clone.
Alex
tom_eaton
I'm really confused. How do you put LIRC data into the library so that it detects it as a protocol and not as raw data?
This is the remote in question:
http://lirc.sourceforge.net/remotes/samsung/BN59-00940A
Big Oil
How would you send RC5 : 820 ?  What needs to be replaced in your Sony example to make it work?
Big Oil
Got it.  To send RC5 (the magnavox protocol)  And code 20 (for turning the channel up) you would use this code:
Code: [Select]
IRsend irsend;
     irsend.sendRC5(0x20, 12); // 20 is the channel up code
     delay(50);
TeamMCS
Had a bash with this Library myself, looks good and recognises my Sky Remote.
It does seem as 90% of the codes from the remote come through as "Unknown" whilst a few come through as the correct RC6 code.
I've picked up an TV controller (an IR extender basically). Cut the receiver cable, wired that up to the Arduino and stuck the signal cable (which runs back to the blaster) in the "transmit" pin.
ie:
Receiver >>>>>>>>> Blaster >>>>>>>> TV
Now
Receiver >>>> Arduino >>>> Blaster >>>> TV
The return path from the Arduino to blaster isn't working. I've tried the "Replay" feature of this library but no joy.
Hopefully I can figure it out. Does anyone have any tips? I notice the library doesn't technically support RC6.
Stanley
I made the IR remote controller using the IR remote library and IR record examples... together with a 2x16 LCD on a breadboard.
It seems only NEC & Yamaha codes are working for me...whereas other IR signals once it is recorded, I am not able to produce the recorded IR signal ..
How to I troubleshoot this ?
How to I save those unknown signals to a header files ?
How can I boost or increase the IR signal ? I am using 220R between the Pin 3 to the IR transmitter..
Should I use a lower resistor for this ?
Thank you for reading this ...  :)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
