Can i use GPS LEA-4A
Hello,
can i use GPS LEA-4A with arduino to receive current GPS coordinates?
Can you give me the schema?
Thanks!
http://www.alphamicro.net/resources/u-blox/LEA-4x_Data_Sheet(GPS.G4-MS4-06143).pdf
I didn't read all the way through but if you can find mention of a TTL serial interface you'd be in business!
Serial and I/O
Voltages
Configurable output levels between
1.65 and 3.6V
5V tolerant inputs
So it looks like you can use this. Notice that it is powered by 3.3V, though, and requires 35mA. That may be more than the 3.3V source on a 5V Arduino can supply.
Can you give me a tutorial i buy this module (LEA-4A), and i want to make it working - thanks :slight_smile:
http://www.sparkfun.com/commerce/tutorial_info.php?tutorials_id=173
