Topic: Problems with Arduino auto format (Read 910 times) previous topic - next topic
zapta
(using 1.0.5 on Max OSX).
Auto format often give faulty results. For example, this one  (the 'private' has negative indent).
Code: [Select]
namespace foo {
  struct  {
    static void enter() {
private:
    static uint8 i;
  bar;
Is it possible to customize the auto format style?  If not, any suggestion for a better auto formatter that works nicely with the Arduino IDE?
zapta
Here is another example, notice the negative indentation of  the ':'.
Code: [Select]
namespace foo {
  class bar {
    bar(int a)
      a_(a) {
    int a_;
