Loading...
Pages: 1 [2] 3 4 ... 16   Go Down
Author Topic: Arduino + Web Control + Relays = Home Automation  (Read 14155 times)
0
Offline Offline
Full Member
Arduino rocks
View Profile
I'm in the beginning stages of doing this exact thing.  Ordered the Ethernet shield already.  If I need more pins than the arduino has i'll use shift registers.
Keep us posted!
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
Me too!! I've collected TOO many toys and ideas for this project already.
But go ahead and give me more ideas and comments!!
I know everyone who has ever owned an Arduino or messed with automation has pondered the possibility... so give all your thoughts! I'll try to put as many of them into effect as possible!
Logged
Wigan, UK
Offline Offline
God Member
View Profile
WWW
I've been thinking about this too (doesn't everyone).
When it comes to ethernet shield interraction I've found it easier to have the arduino poll a web site. I've got a local web server (I have a QNAP NAS box that does web server as well as being NAS), and my arduino polls a website for instructions every time it's idle.  The web server is built to handle multiple threads, whereas my arduino is going to get confused if multiple requests come in at once.
I've also thought about having an arduino per room or per pair of rooms, so I'm not trying to do too much on one arduino and it'll simplify the wiring.
I got myself a couple of smart card sockets and ten smart cards so I can do door access.  I'm renting at the moment though, but I want to buy mainly so I can do stuff to my house that I can't when renting.
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
Here's a post to the rfid door unlocker I was doing.
http://jrowarduino.blogspot.com/
I haven't installed it yet because I want to change it a bit.
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
It has begun. Parts started to arrive today.
I will start programming and prototyping soon.
Follow and comment :-P
http://vinhworkblog.blogspot.com/
Logged
Vejen, Denmark
Offline Offline
Edison Member
RAWR! ^,..,^
View Profile
WWW
Pictures!!!! ;D Want to see the toys too, not only read about them. smiley-wink
Logged
captain-slow.dk | non contagious!
0
Offline Offline
Newbie
Arduino rocks
View Profile
Photos, Videos, everything!
Your project sounds nice!!
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
Here's some pix:
http://img820.imageshack.us/g/0711101240.jpg/
Logged
HOLLAND
Offline Offline
Full Member
HOLLAND!!!
View Profile
LOL @ this pic -> components smiley-razz sticker smiley-razz
Nice layout right now!
nice bag with reed/magnet switches smiley-grin
how large is your hous in terms of windows, doors, rooms, floors and doors to the outside world (I have 5 :S) to bad i rent...
why don't you live close by smiley-razz so I could help smiley-razz (I'm a electrician to)
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
MAN! I surely could use the help! haha. Or at least just another person to check my work. All my friends are clueless as to what I'm doing...
As for the house, there are TONS of windows... at least 20. There are 5 doors in all that enters the house. So that's about 25 input pins on the Arduino right there. 5 for electric strike plate lock, a couple for PIR, Ultrasonic sensors, a couple for temperature sensor and heater/AC control... by the end, I'm going to be putting most of the pins on this Seeeduino Mega to work! smiley-razz
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
Here's how i'm thinking about doing mine.
Server with php/lighttpd/mysql will host 2 php pages (just two at first to make it simple).
The first php page will be the "front end" that I will connect to from a computer.  It will have buttons and things to turn stuff on/off.  It will connect to a mysql database to get/change the status of something (say light = off).
The second php page will be what the arduino will poll every few seconds.  It will connect to the database and see if the state has been changed.  If, say, light = on now, it will fire the correctly relay.
I already have part of it setup.  I can't figure out how to use the data that has come back from the server on the arduino.  Can you take a peek at my post here?
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1278888171
Also, is this how you are planning to do it?  Or is there a different way?
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
No, I'm more in the business of instant gratification, so with your concept where the Arduino polls the PHP/MySQL every few second will have a slight delay. The delay will be longer since I will be using it through my phone's Web access through wifi... so from the point I click the button on the phone, then wait a few second for the light to turn on, or a door to open would be... un-pleasing.
I mean it would work fine, but I want a better solution. What I was thinking is that when I press a certain button, it will trigger a GET sending straight to the Seeeduino's Ethernet shield. This will turn on whatever relay it's attached to, then the Seeeduino send the appropriate "event" back to the mySQL server with a POST.
So it's suppose to act first, then log. This way, I can also code in the Seeeduino to "check" to see if the appropriate light is on before sending the status. Else it'll have to try again. I will have a bunch of LDR (light detecting diode) wired up to every rooms pretty much, so I can check light status that way. And I can also check to see if a certain door opened up with the use of the Reed switch that will also be use for security purpose.
I think by doing a GET/POST method, the Seeeduino will be acting as the primary server for everything, the only thing the PHP server will be doing is relaying the message from the Seeeduino back and forth.
Let me know if you think this will work. From what I've read of the Ethernet shield, this shouldn't be a problem... but then again I can be wrong. I haven't even gotten the Seeeduino mega to work with the Ethernet shield yet.
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
I'll work on in that way tonight and see where I can get.
Logged
HOLLAND
Offline Offline
Full Member
HOLLAND!!!
View Profile
Quote
since you use a digital pin to controll a relay, transistor or something you can just digitalRead(); the relay pin...
instead of usingpins to check the light of every room smiley-grin
this cuts the pins per light in half smiley-razz
I always use a function to toggle.
Code:
// use like toggle(13); to switch pin 13.
// simple but does the job!
int toggle(int pinnumber){
  if(digitalRead(pinnumber) == HIGH){
    // if light is on turn it off
    digitalWrite(pinnumber, LOW);
    // if light is off turn it on
    digitalWrite(pinnumber, HIGH);
+ a mysql server for the status of the lights?
Why? you can program arduino to do it directly why use a database.
i would use a html file or a php file to create a form like:
Code:
<center>
<form method="GET" action="http://myarduino-ip">
      <input type="SUBMIT" name=led13 value="toggle led 13">
</form>
<iframe src ="http://website-that-has-the-forms" width="100%" height="100%">
  <p>Your browser does not support iframes.</p> <!-- shows the pages just fine -->
</iframe>
</center>
Code:
#include <WString.h>
#include <Ethernet.h>
byte mac[] = { 0x00, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 2, 150 }; // MY IP change to your needs
Server server(80);
String readString = String(100);
void setup(){
  Ethernet.begin(mac, ip);
void loop(){
  Client client = server.available();
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        if (readString.length() < 100){
          readString.append(c);
        if (c == '\n') {
          if(readString.contains("msg")){
            toggle(13);
          // Now output HTML data starting with standart header
          client.println("Content-Type: text/html");
          client.println();
          client.println("led 13 is"); client.println(digitalRead(13));
          readString="";
          client.stop();
NOT TESTED!
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
Quote
I still want to have light switch control (on the wall), so the arduino can't know if the light is truly on or off without a light sensor.
Logged
Pages: 1 [2] 3 4 ... 16   Go Up
Print
Jump to:
