Topic: Arduino + Web Control + Relays = Home Automation (Read 75043 times) previous topic - next topic
tehjrow
I have had to stop my project for personal reasons, but I was going to use solid state relays, like this one:
http://www.relays.cc/images/solid-state-relay-SSR-75DA-H.jpg
Here's a vid I made of me controlling an AC lamp with one:
http://www.youtube.com/watch?v=Bad4VXTFmVg
LMas
Hi all.Want to ask is it possible using on page 7 UI make Buttons Up and Down and use them as a temporary keys so they only active when they is pressed?
Can someone help me with example of php and arduino code?
sasaa
#227
Nov 10, 2010, 12:23 pm Last Edit: Nov 10, 2010, 12:28 pm by sasaa Reason: 1
I guess that is possible with JavaScript trough:
Onmousedown(); -> loop in a up/down command towards the arduino
OnMouseUp(); -> do nothing really
or Mouseover(); -> if you don't want to push the button.
but I don't know a lot about JavaScript
_____________________________________
@RDantas
I made a perf board with the relais on them and then wire the light from there and use 2x0,8mm cable to connect the switches so they can be used to...
so i made my own "protoshield" with almost everyting on it.
btw i finished the beamer turning on and the lights going off :P its really nice :P
todo list:
Add automatic curtains :P
