Topic: One output blinking, another output fading? (Read 5185 times) previous topic - next topic
Norwegian_User
I am a newbie and this question may sound a little bit silly.
How can I have a flashing LED on output 13 and a fading LED on output 11.
And why not throw in a pushbutton on input 2.
I don't see to understand how to do "multiple" tasks that are "independant" from each other.
Am I supposed to write several void loops? Or do I have to put  all my diffrent "tasks" inside {}
Cheater
Throw them all in to loop().
The only catch is you cannot use delay(). You need to do your own timing.
westfw
Here you go.
int ledPin = 13;                 // LED connected to digital pin 13
int fadePin = 3;
unsigned long nextBlink, nextFade;
int fadeBrightness = 0;
char ledState = LOW, fadeDir = 10;
   pinMode(ledPin, OUTPUT);      // sets the digital pin as output
   pinMode(fadePin, OUTPUT);
   ledState = LOW;
   nextBlink = millis();
   nextFade = millis();
* This checks whether it's time to change the state of the LED, and
* does the write if so.  But it doesn't execute delay(), so in either
* case it takes essentially no time to execute.
void blink(void)
   unsigned long now;
   now = millis();
   if (now >= nextBlink) {
       nextBlink = now + 1000;    // Next change in one second
       if (ledState == LOW) {
           digitalWrite(ledPin, HIGH);
           ledState = HIGH;
       else {
           digitalWrite(ledPin, LOW);
           ledState = LOW;
void fade(void)
   unsigned long now;
   now = millis();
   if (now >= nextFade) {
       nextFade = now + 200;    // Next change in one second
       if (fadeDir > 0) {
           if (fadeBrightness > (255 - fadeDir)) {
               fadeDir = - fadeDir;
       else {
           if (fadeBrightness < (-fadeDir)) {
       fadeBrightness += fadeDir;
       analogWrite(fadePin, fadeBrightness);
   blink();
   fade();
