Topic: Success! Arduino as Wiimote Extension (Read 3049 times) previous topic - next topic
tim
Success!! I finally got one of my Arduinos to fool a Wiimote into treating as a real Extension.  My Wiimote can 'recognize' the Arduino as a Nunchuk, Calssic Controller and Guitar Hero 3 controller.
There are still lots of issues I have to work related to faking accelerometer,joystick and whammy bar data, but it's looking very promising.
As the code stands, it can be used to wirelessly send data to a PC via the Wiimote, using the standard Wiimote libraries, wiiuse and wiiuseJ. When all the issues have been resolved, I will post this to the Playground.
Before posting the code to date, this code was essentially written by Frank Zhao http://www.circleofcurrent.com/ and is released under an Apache license. My contrinbution has really been no more than porting it over to compile with the Arduino IDE, and figuring out how to send the correct Extension IDs to the Wiimote.
The code will be a multipart post .... to use simply copy each part into a single sketch. To actually send data via the Wiimote, in the function "sample" change various bits in the but_dat array bytes.
--Tim.
Code: [Select]
#include <string.h>
#include <avr/io.h>
#include <util/twi.h>
#include <avr/interrupt.h>
#include <avr/pgmspace.h>
#define twi_port PORTC
#define twi_ddr DDRC
#define twi_scl_pin 5
#define twi_sda_pin 4
#define dev_detect_port PORTD
#define dev_detect_ddr DDRD
#define dev_detect_pin 4
unsigned char drum_id[6] =   {0x01, 0x00, 0xA4, 0x20, 0x01, 0x03};  // drum id
unsigned char guitar_id[6] = {0x00, 0x00, 0xA4, 0x20, 0x01, 0x03};  // GH3 id
unsigned char nunchuk_id[6] = {0x00, 0x00, 0xA4, 0x20, 0x00, 0x00}; // nunchuck id
unsigned char classic_id[6] = {0x00, 0x00, 0xA4, 0x20, 0x01, 0x01}; // classic controller id
// crypto data
//   should all be declared as 'volatile' because they are access in an interrupt handler
volatile unsigned char wm_rand[10];
volatile unsigned char wm_key[6];
volatile unsigned char wm_ft[8];
volatile unsigned char wm_sb[8];
// virtual register
volatile unsigned char twi_reg[256];
volatile unsigned int twi_reg_addr;
volatile unsigned char twi_first_addr_flag; // set address flag
volatile unsigned char twi_rw_len; // length of most recent operation
// initialize wiimote interface with id, starting data, and calibration data
void wm_init(unsigned char *,  unsigned char *, unsigned char *, void (*)(void));
// set button data
void wm_newaction(unsigned char *);
// pointer to user function
static void (*wm_sample_event)();
void twi_slave_init(unsigned char);
void twi_clear_int(unsigned char);
void wm_slaveTxStart(unsigned char);
void wm_slaveRx(unsigned char, unsigned char);
void wm_timer_inc();
From Frank Zhao:
I'd like to thank Hector Martin for posting his encryption method!
His website is http://www.marcansoft.com/
Decryption method found at http://www.derkeiler.com/pdf/Newsgroups/sci.crypt/2008-11/msg00110.pdf
unsigned char wm_ror8(unsigned char, unsigned char);
void wm_gentabs();
Widely copied on the Internet
char wm_ext_encode_byte (char);
char wm_ext_decode_byte (char);
tim
#1
Jan 27, 2010, 07:41 pm Last Edit: Jan 27, 2010, 07:49 pm by tim Reason: 1
Code: [Select]
unsigned char ans_tbl[7][6] PROGMEM = {
 {0xA8,0x77,0xA6,0xE0,0xF7,0x43  },
 {0x5A,0x35,0x85,0xE2,0x72,0x97  },
 {0x8F,0xB7,0x1A,0x62,0x87,0x38  },
 {0xD,0x67,0xC7,0xBE,0x4F,0x3E  },
 {0x20,0x76,0x37,0x8F,0x68,0xB7  },
 {0xA9,0x26,0x3F,0x2B,0x10,0xE3  },
 {0x30,0x7E,0x90, 0xE,0x85, 0xA  },
unsigned char sboxes[10][256] PROGMEM = {
   0x70,0x51,   3,0x86,0x40, 0xD,0x4F,0xEB,0x3E,0xCC,0xD1,0x87,0x35,0xBD,0xF5, 0xB,
   0x5E,0xD0,0xF8,0xF2,0xD5,0xE2,0x6C,0x31, 0xC,0xAD,0xFC,0x21,0xC3,0x78,0xC1,   6,
   0xC2,0x4C,0x55,0xE6,0x4A,0x34,0x48,0x11,0x1E,0xDA,0xE7,0x1A,0x84,0xA0,0x96,0xA7,
   0xE3,0x7F,0xAF,0x63,0x9C,0xFA,0x23,0x5B,0x79,0xC8,0x9E,0xBA,0xB2,0xC9,0x22,0x12,
   0x4B,0xB3,0xA1,0xB6,0x32,0x49,0xA2,0xE1,0x89,0x39,0x10,0x66,0xC5,   7,0x8F,0x54,
   0xEA,0x91,0xCA,0x3F,0xF9,0x19,0xF0,0xD7,0x46,0xBC,0x28,0x1B,0x61,0xE8,0x2F,0x6A,
   0xAE,0x9D,0xF6,0x4E,   9,0x14,0x77,0x4D,0xDB,0x1F,0x2E,0x7B,0x7C,0xF1,0x43,0xA3,
   0,0xB8,0x13,0x8C,0x85,0xB9,0x29,0x75,0x88,0xFD,0xD2,0x56,0x1C,0x50,0x97,0x41,
   0xE5,0x3B,0x60,0xB5,0xC0,0x64,0xEE,0x98,0xD6,0x2D,0x25,0xA4,0xAA,0xCD,0x7D,0xA8,
   0x83,0xC6,0xAB,0xBE,0x44,0x99,0x26,0x3C,0xCE,0x9F,0xBF,0xD3,0xCB,0x76,0x7A,0x7E,
   0x82,   1,0x8A,0x9A,0x80,0x1D, 0xE,0xB0,0x5C,0xD4,0x38,0x62,0xF4,0x30,0xE0,0x8E,
   0x53,0xB7,   2,0x57,0xAC,0xA6,0x52, 0xA,0x6D,0x92,0x65,0x17,0x24,0x33,0x45,0x72,
   0x74,0xB1,0xB4,0xF7,0x5D,0xED,0x2C,0xFF,0x47,0x37,0x5A,0x90,0xBB,0xDF,0x2A,0x16,
   0x59,0x95,0xD9,0xC4,0x27,0x67,0x73,0xC7,0x68,0xFE,0xA5,0xDD,0x6B,0x5F,0x93,0xD8,
   0xEC,   5,0x3A,0x8D,0x6E,0xFB,0x3D,0xA9,0x69,0x36,0xF3,0x94,0xDE,0xEF,0x15,0x6F,
   0x8B,0x9B,   8, 0xF,0xDC,0x81,0x18,0x20,   4,0xE4,0x71,0xCF,0xE9,0x2B,0x42,0x58,
   1,0xA0,0xA9,0x62,0xD6,0x3F,0x85,0xA7,0xB6,0xD4,0xFA,0x15,0x66,0x17,   9,0xBD,
   0x5D,0x14,0x34,0x26,0x59,0x72,0x91,0x54,   6,0x4F,0xF8,0xB0,0x5B,0x74,0x93,0x99,
   0x8C,0xF2,0x45,0xCD,0xEA,0x4E,0xAD,0x10,0x4A,0xE5,0xCA,0xEE,0xDF,0xC6,0x6F,0x9F,
   0x88,0x8E,   2,0xCC,   8,0xA8,0x77,0x94,0x6D,0x21,0xB1,0x28,0xE4,0x39,0x79,0x96,
   0x60,0x71,0x81,0x16,0x2E,0xE6,0x78,0xB9,0xC4,0x46,0x9A,0x42,0xAE,0xB7,0x7C,0x43,
   0xB3,0x22,0x1A,0x86,0xC2,0x32,0x3D,0x2D,0x9C,0xD2,0x29,0xE9,0x63,0x9B,0xD1,0x31,
   0x38,0x5E,0x1E,0x36,0x41,0xBB,   3,0x18,0x2B,0x3E,0xBF,0x68,0x61,0xFC,0x52,0xC0,
   0xDE,0xE0, 0xA,0x58,0x13,0x5A,   0,0xBE,0x1C,0x90, 0xE,0x53,0x12,0xFD,0xE2,0x6E,
   0xBA,0xCE,0x24,0x27,0x44,0x7F,0x87,0xA3,0xA1,0xD5,0x50,0x40,0xE3,0xF9,0x83,0xF7,
   0xC7,0xA2,0x35,0xC8,0xDB,0x19,0xAB,0x2F,0x11,0x25,0xED,0x33,0x9E,0x55,0xE1,0x48,
   0xAF,0x73,0x84,0xDA,0x2A,0xAA,0x51,0xEB,0x9D,0x95,0xB2,0xCB,0xE7,0x70,0x80,0xFE,
   0x4C,0x65,   4,0xEF,0xC5,0xF1,0xC3,0x3A,0xB4,0xF5,0x5F,0x23,0x89,0xDD,0x30,0xA5,
   0x8B,0xD3,0xF6,0xDC,0x4D,0x64,0xD7,0xF0,0x8F,0xEC,0x56,0x37,0x5C,0xA4, 0xD,   7,
   0x76,0x8A,0x2C, 0xB,0xB5,0xD8,0xC1,0x1F,0xE8,0x3B,0xF4,0x4B,0x1B,0x47,0x6C,0x49,
   0x67,0x7B,0x92,0xCF,0x75,0x7E,0x20,0xD9,0x7D,0x3C,0x97,0x7A,0xD0,   5,0x6B, 0xF,
   0x1D,0xFB,0x82,0x98,0x57,0x8D,0xF3,0x6A,0xBC,0xAC,0xC9,0xA6,0xFF,0xB8,0x69, 0xC,
   0x4C,0x4D,0x72,   7,0x5A,0x49,0x33,0x8D,0xA2,0xAB,0x46,0x3D,0x63, 0xD,0xA0,0x97,
   0xFF,0xF0,0xF5,0xFA,0xC0,0xE9,0xDB,0x62,0xE4,0xE1,0x74,0x43,0xDC,0x86,0x18,0x29,
   0x37,0xF4,   6,0xE2,0xED,0x6F,0x90,0x48,0x1E,0x2D,0x1D,0xEA,0x73,0x94,0x54,0xDF,
   0x25,0xF6,0x47,0x27,0xD9,0x11,0x77,0xC9,0x84,0x1C,0x5B,0x5C,0x51,0x81,0xA6,0x22,
   0x3E,0x24,0x96,0xC8,0x8A,0xEC,0x82,0x7C,   9,0xB8,0x45,0x4A,0x57,0xBB,0x2F,0x50,
   0x75,0x8E,0x61,0x70,0x8C,0x6C,0xAF,0xD0,0xFD,0xB4,0x1B,0xAE,0xDE,0xFE,0x3B,0xB5,
   0x36,0xBD,0x55,   1, 0xE,0x9C,0x41,0x56,0x5F,0xB3,0x26,   3,0x83,0xBA,0x13,0x4B,
   0xCA,0xC5, 0xA,0xF8,0x60,0xA5,0xB9,0xC7,0xC3,0x98,0x32,0xFB,0x12,0xF9,0xA7,0x92,
   0xAA,0x68,0xF3,0x78,0x7E,   5,0x20,0x21,   2,0xE8,0xBF,0xF2,0xB0,0x59,0x8F,0xD2,
   0xCB,0x87,0x65,0x15,0xF1,0x1A,0xB2,0x30,0xAD,0xEE,0x58,0xA3,0x8B,0x66,0x1F,0x2C,
   0xD7,0x5D,0x19,0x85,0xA8,0xE6,0xD3,0x6B,0xA1, 0xC,0x91,0x93,0x6A,0x5E, 0xB,0x79,
   0xE3,0xDD,   0,0x4F,0x3C,0x89,0x6E,0x71,0x69,0xA9,0xAC,0x40,0xE5,0x99,0x28,0xC6,
   0x31,0x4E,0x7A,0xCD,   8,0x9E,0x7D,0xEF,0x17,0xFC,0x88,0xD8,0xA4,0x6D,0x44,0x95,
   0xD1,0xB7,0xD4,0x9B,0xBE,0x2A,0x34,0x64,0x2B,0xCF,0x2E,0xEB,0x38,0xCE,0x23,0xE0,
   0x3A,0x3F,0xF7,0x7B,0x9F,0x10,0x53,0xBC,0x52,0x67,0x16,0xE7,0x80,0x76,   4,0xC4,
   0xB6,0xC1,0xC2,0x7F,0x9A,0xDA,0xD5,0x39,0x42,0x14,0x9D,0xB1, 0xF,0x35,0xD6,0xCC,
   0xB9,0xDA,0x38, 0xC,0xA2,0x9C,   9,0x1F,   6,0xB1,0xB6,0xFD,0x1A,0x69,0x23,0x30,
   0xC4,0xDE,   1,0xD1,0xF4,0x58,0x29,0x37,0x1C,0x7D,0xD5,0xBF,0xFF,0xBD,0xC8,0xC9,
   0xCF,0x65,0xBE,0x7B,0x78,0x97,0x98,0x67,   8,0xB3,0x26,0x57,0xF7,0xFA,0x40,0xAD,
   0x8E,0x75,0xA6,0x7C,0xDB,0x91,0x8B,0x51,0x99,0xD4,0x17,0x7A,0x90,0x8D,0xCE,0x63,
   0xCB,0x4E,0xA0,0xAB,0x18,0x3A,0x5B,0x50,0x7F,0x21,0x74,0xC1,0xBB,0xB8,0xB7,0xBA,
   0xB,0x35,0x95,0x31,0x59,0x9A,0x4D,   4,   7,0x1E,0x5A,0x76,0x13,0xF3,0x71,0x83,
   0xD0,0x86,   3,0xA8,0x39,0x42,0xAA,0x28,0xE6,0xE4,0xD8,0x5D,0xD3,0xD0,0x6E,0x6F,
   0x96,0xFB,0x5E,0xBC,0x56,0xC2,0x5F,0x85,0x9B,0xE7,0xAF,0xD2,0x3B,0x84,0x6A,0xA7,
   0x53,0xC5,0x44,0x49,0xA5,0xF9,0x36,0x72,0x3D,0x2C,0xD9,0x1B,0xA1,0xF5,0x4F,0x93,
   0x9D,0x68,0x47,0x41,0x16,0xCA,0x2A,0x4C,0xA3,0x87,0xD6,0xE5,0x19,0x2E,0x77,0x15,
   0x6D,0x70,0xC0,0xDF,0xB2,   0,0x46,0xED,0xC6,0x6C,0x43,0x60,0x92,0x2D,0xA9,0x22,
   0x45,0x8F,0x34,0x55,0xAE,0xA4, 0xA,0x66,0x32,0xE0,0xDC,   2,0xAC,0xE8,0x20,0x8C,
   0x89,0x62,0x4A,0xFE,0xEE,0xC3,0xE3,0x3C,0xF1,0x79,   5,0xE9,0xF6,0x27,0x33,0xCC,
   0xF2,0x9E,0x11,0x81,0x7E,0x80,0x10,0x8A,0x82,0x9F,0x48, 0xD,0xD7,0xB4,0xFC,0x2F,
   0xB5,0xC7,0xDD,0x88,0x14,0x6B,0x2B,0x54,0xEA,0x1D,0x94,0x5C,0xB0,0xEF,0x12,0x24,
   0xCD,0xEB,0xE1,0xE2,0x64,0x73,0x3F, 0xE,0x52,0x61,0x25,0x3E,0xF8, 0xF,0x4B,0xEC,
   0xC0,   0,0x30,0xF6,   2,0x49,0x3D,0x10,0x6E,0x20,0xC9,0xA6,0x2F,0xFE,0x2C,0x2B,
   0x75,0x2E,0x45,0x26,0xAB,0x48,0xA9,0x80,0xFC,   4,0xCC,0xD3,0xB5,0xBA,0xA3,0x38,
   0x31,0x7D,   1,0xD9,0xA7,0x7B,0x96,0xB6,0x63,0x69,0x4E,0xF7,0xDE,0xE0,0x78,0xCA,
   0x50,0xAA,0x41,0x91,0x65,0x88,0xE4,0x21,0x85,0xDA,0x3A,0x27,0xBE,0x1C,0x3E,0x42,
   0x5E,0x17,0x52,0x7F,0x1F,0x89,0x24,0x6F,0x8F,0x5C,0x67,0x74, 0xE,0x12,0x87,0x8D,
   0xE9,0x34,0xED,0x73,0xC4,0xF8,0x61,0x5B,   5,0xDF,0x59,0x4C,0x97,0x79,0x83,0x18,
   0xA4,0x55,0x95,0xEB,0xBD,0x53,0xF5,0xF1,0x57,0x66,0x46,0x9F,0xB2,0x81,   9,0x51,
   0x86,0x22,0x16,0xDD,0x23,0x93,0x76,0x29,0xC2,0xD7,0x1D,0xD4,0xBF,0x36,0x3F,0xEA,
   0x4B,0x11,0x32,0xB9,0x62,0x54,0x60,0xD6,0x6D,0x43,0x9A, 0xD,0x92,0x9C,0xB0,0xEF,
   0x58,0x6C,0x9D,0x77,0x2D,0x70,0xFA,0xF3,0xB3, 0xB,0xE2,0x40,0x7E,0xF4,0x8A,0xE5,
   0x8C,0x3C,0x56,0x71,0xD1,0x64,0xE1,0x82, 0xA,0xCB,0x13,0x15,0x90,0xEC,   3,0x99,
   0xAF,0x14,0x5D, 0xF,0x33,0x4A,0x94,0xA5,0xA8,0x35,0x1B,0xE3,0x6A,0xC6,0x28,0xFF,
   0x4D,0xE7,0x25,0x84,0xAC,   8,0xAE,0xC5,0xA2,0x2A,0xB8,0x37, 0xC,0x7A,0xA0,0xC3,
   0xCE,0xAD,   6,0x1A,0x9E,0x8B,0xFB,0xD5,0xD0,0xC1,0x1E,0xD0,0xB4,0x9B,0xB1,0x44,
   0xF2,0x47,0xC7,0x68,0xCF,0x72,0xBB,0x4F,0x5A,0xF9,0xDC,0x6B,0xDB,0xD2,0xE8,0x7C,
   0xC8,0xEE,0x98,0xA1,0xE6,0xD8,0x39,   7,0x5F,0xFD,0x8E,0x19,0xB7,0x3B,0xBC,0xCD,
   0x7C,0xE3,0x81,0x73,0xB2,0x11,0xBF,0x6F,0x20,0x98,0xFE,0x75,0x96,0xEF,0x6C,0xDA,
   0x50,0xE1,   9,0x72,0x54,0x45,0xBA,0x34,0x80,0x5B,0xED,0x3E,0x53,0x2C,0x87,0xA4,
   0x57,0xF3,0x33,0x3F,0x3C,0xB7,0x67,0xB4,0xA3,0x25,0x60,0x4F,   7,0x6B,0x1B,0x47,
   0x15, 0xF,0xE4, 0xA,0xEA,0xD1,0x32,0x78,0x36,0x49,0x8D,0x4B,0xD2,0xBC,0xA5,0xDC,
   0x1D, 0xD,0x4D,0xCD,0x9A,0x82,0x5F,0xFC,0x94,0x65,0xBE,0xE2,0xF4,0xC9,0x1E,0x44,
   0xCB,0x9E, 0xC,0x64,0x71,0x26,0x63,0xB3,0x14,0xE8,0x40,0x70,0x8A, 0xE,0x19,0x42,
   0x6D,0xAC,0x88,0x10,0x5C,0xDF,0x41,0xA9,0xAD,0xE5,0xFB,0x74,0xCC,0xD5,   6,0x8E,
   0x59,0x86,0xCE,0x1F,0x3D,0x76,0xE0,0x8F,0xB9,0x77,0x27,0x7B,0xA6,0xD8,0x29,0xD3,
   0xEC,0xB8,0x13,0xF7,0xFA,0xC3,0x51,0x6A,0xDE,0x4A,0x5A,0xEB,0xC2,0x8B,0x23,0x48,
   0x92,0xCF,0x62,0xA8,0x99,0xF8,0xD0,0x2E,0x85,0x61,0x43,0xC8,0xBD,0xF0,   5,0x93,
   0xCA,0x4E,0xF1,0x7D,0x30,0xFD,0xC4,0x69,0x66,0x2F,   8,0xB1,0x52,0xF9,0x21,0xE6,
   0x7A,0x2B,0xDD,0x39,0x84,0xFF,0xC0,0x91,0xD6,0x37,0xD4,0x7F,0x2D,0x9B,0x5D,0xA1,
   0x3B,0x6E,0xB5,0xC5,0x46,   4,0xF5,0x90,0xEE,0x7E,0x83,0x1C,   3,0x56,0xB6,0xAA,
   0,0x17,   1,0x35,0x55,0x79, 0xB,0x12,0xBB,0x1A,0x31,0xE7,   2,0x28,0x16,0xC1,
   0xF6,0xA2,0xDB,0x18,0x9C,0x89,0x68,0x38,0x97,0xAB,0xC7,0x2A,0xD7,0x3A,0xF2,0xC6,
   0x24,0x4C,0xB0,0x58,0xA0,0x22,0x5E,0x9D,0xD9,0xA7,0xE9,0xAE,0xAF,0x8C,0x95,0x9F,
tim
Code: [Select]
   0x28,0xB7,0x20,0xD7,0xB0,0x30,0xC3,   9,0x19,0xC0,0x67,0xD6,   0,0x3C,0x7E,0xE7,
   0xE9,0xF4,   8,0x5A,0xF8,0xB8,0x2E,   5,0xA6,0x25,0x9E,0x5C,0xD8,0x15, 0xD,0xE1,
   0xF6,0x11,0x54,0x6B,0xCD,0x21,0x46,0x66,0x5E,0x84,0xAD,   6,0x38,0x29,0x44,0xC5,
   0xA2,0xCE,0xF1,0xAA,0xC1,0x40,0x71,0x86,0xB5,0xEF,0xFC,0x36,0xA8,0xCB, 0xA,0x48,
   0x27,0x45,0x64,0xA3,0xAF,0x8C,0xB2,0xC6,0x9F,   7,0x89,0xDC,0x17,0xD3,0x49,0x79,
   0xFB,0xFE,0x1D,0xD0,0xB9,0x88,0x43,0x52,0xBC,   1,0x78,0x2B,0x7D,0x94,0xC7, 0xE,
   0xDE,0xA5,0xD5,0x9B,0xCC,0xF7,0x61,0x7A,0xC2,0x74,0x81,0x39,   3,0xAB,0x96,0xA0,
   0x37,0xBD,0x2D,0x72,0x75,0x3F,0xC9,0xD4,0x8E,0x6F,0xF9,0x8D,0xED,0x62,0xDB,0x1C,
   0xDF,   4,0xAC,0x1B,0x6C,0x14,0x4B,0x63,0xD0,0xBF,0xB4,0x82,0xEC,0x7B,0x1A,0x59,
   0x92,0xD2,0x10,0x60,0xB6,0x3D,0x5F,0xE6,0x80,0x6E,0x70,0xC4,0xF2,0x35,0xD9,0x7C,
   0xEE,0xE5,0x41,0xA4,0x5B,0x50,0xDD,0xBB,0x4C,0xF3,0x1F,0x9D,0x5D,0x57,0x55,0x51,
   0x97,0xE3,0x58,0x42,0x4D,0x9C,0x73,0xBA,0xC8,0x77,0x31,0x69,0x26,0xAE,0xEA,0x8A,
   0xDA,0x22,0xB3,0x87,0x56,0xFA,0x93, 0xB,0x34,0x16,0x33,0xE8,0xE4,0x53,0xBE,0xA9,
   0xB1,0x3A,0x3E,0xF5,0x90,0x6A,0xCF,0x3B,0x12,0xFD,0x8F,0x9A,0xA7,0x47,0x91,0x99,
   0xEB, 0xF,0x24,0xFF,0x23,0x18,0x85,0x4E,0x7F, 0xC,0xE0,0xA1,0xD2,0xD1,0x2C,0x2A,
   0x4A,   2,0x4F,0x1E,0x95,0x68,0x8B,0x98,0x83,0x6D,0x76,0xCA,0x65,0x32,0x13,0x2F,
   0xC3,0x82,0x9A,0xA4,0xBA,0x81,0x60,0x37,0x34,0x35,0xFC,0x80,0xA8,0x51,0x65,0x67,
   0xED,0x30,0x5F,0x10,0xD3,0x4A,0x27,0x2F,0x13,0xB9,0x2A,0xD2,0xCC,0xE1,0xEF,0xAE,
   0xEB,0xBE,0xF4,0xBD,0xCF,0x43,0xB3,0xC5,0x88,0x84,0xB7,0xDD,0x39,0x40,0xCE,0x48,
   0x6D,0x9B,0x72,0x61,0x7E,0xE7,0xA1,0x4E,0x53,0x2E,0x77,0x3B,0xE2,0xC9,0x36,0x22,
   0x1B,0x6E,0x73,0xB1,   3,0xB2,0x4C,0x87,0xA9,0xD4,0x4D, 0xF,0xD8,0x15,0x6C,0xAA,
   0x18,0xF6,0x49,0x57,0x5D,0xFB,0x7A,0x14,0x94,0x63,0xA0,0x11,0xB0,0x9E,0xDE,   5,
   0x46,0xC8,0xEE,0x47,0xDB,0xDC,0x24,0x89,0x9C,0x91,0x97,0x29,0xE9,0x7B,0xC1,   7,
   0x1E,0xB8,0xFD,0xFE,0xAC,0xC6,0x62,0x98,0x4F,0xF1,0x79,0xE0,0xE8,0x6B,0x78,0x56,
   0xB6,0x8D,   4,0x50,0x86,0xCA,0x6F,0x20,0xE6,0xEA,0xE5,0x76,0x17,0x1C,0x74,0x7F,
   0xBC, 0xD,0x2C,0x85,0xF7,0x66,0x96,0xE4,0x8B,0x75,0x3F,0x4B,0xD9,0x38,0xAF,0x7C,
   0xDA, 0xB,0x83,0x2D,0x31,0x32,0xA2,0xF5,0x1D,0x59,0x41,0x45,0xBF,0x3C,0x1F,0xF8,
   0xF9,0x8A,0xD0,0x16,0x25,0x69,0x12,0x99,0x9D,0x21,0x95,0xAB,   1,0xA6,0xD7,0xB5,
   0xC0,0x7D,0xFF,0x58, 0xE,0x3A,0x92,0xD1,0x55,0xE3,   8,0x9F,0xD6,0x3E,0x52,0x8E,
   0xFA,0xA3,0xC7,   2,0xCD,0xDF,0x8F,0x64,0x19,0x8C,0xF3,0xA7, 0xC,0x5E, 0xA,0x6A,
   9,0xF0,0x93,0x5B,0x42,0xC2,   6,0x23,0xEC,0x71,0xAD,0xB4,0xCB,0xBB,0x70,0x28,
   0xD5,0x1A,0x5C,0x33,0x68,0x5A,   0,0x44,0x90,0xA5,0xC4,0x26,0x3D,0x2B,0xF2,0x54,
   0x96,0xAD,0xDA,0x1F,0xED,0x33,0xE1,0x81,0x69,   8, 0xD, 0xA,0xDB,0x35,0x77,0x9A,
   0x64,0xD1,0xFC,0x78,0xAA,0x1B,0xD0,0x67,0xA0,0xDD,0xFA,0x6C,0x63,0x71,   5,0x84,
   0x17,0x6A,0x89,0x4F,0x66,0x7F,0xC6,0x50,0x55,0x92,0x6F,0xBD,0xE7,0xD2,0x40,0x72,
   0x8D,0xBB,0xEC,   6,0x42,0x8A,0xE4,0x88,0x9D,0x7E,0x7A,0x82,0x27,0x13,0x41,0x1A,
   0xAF,0xC8,0xA4,0x76,0xB4,0xC2,0xFE,0x6D,0x1C,0xD9,0x61,0x30,0xB3,0x7C,0xEA,0xF7,
   0x29, 0xF,0xF2,0x3B,0x51,0xC1,0xDE,0x5F,0xE5,0x2A,0x2F,0x99, 0xB,0x5D,0xA3,0x2B,
   0x4A,0xAB,0x95,0xA5,0xD3,0x58,0x56,0xEE,0x28,0x31,   0,0xCC,0x15,0x46,0xCA,0xE6,
   0x86,0x38,0x3C,0x65,0xF5,0xE3,0x9F,0xD6,0x5B,   9,0x49,0x83,0x70,0x2D,0x53,0xA9,
   0x7D,0xE2,0xC4,0xAC,0x8E,0x5E,0xB8,0x25,0xF4,0xB9,0x57,0xF3,0xF1,0x68,0x47,0xB2,
   0xA2,0x59,0x20,0xCE,0x34,0x79,0x5C,0x90, 0xE,0x1E,0xBE,0xD5,0x22,0x23,0xB1,0xC9,
   0x18,0x62,0x16,0x2E,0x91,0x3E,   7,0x8F,0xD8,0x3F,0x93,0x3D,0xD4,0x9B,0xDF,0x85,
   0x21,0xFB,0x11,0x74,0x97,0xC7,0xD7,0xDC,0x4C,0x19,0x45,0x98,0xE9,0x43,   2,0x4B,
   0xBC,0xC3,   4,0x9C,0x6B,0xF0,0x75,0x52,0xA7,0x26,0xF6,0xC5,0xBA,0xCF,0xB0,0xB7,
   0xAE,0x5A,0xA1,0xBF,   3,0x8B,0x80,0x12,0x6E, 0xC,0xEB,0xF9,0xC0,0x44,0x24,0xEF,
   0x10,0xF8,0xA8,0x8C,0xE8,0x7B,0xFF,0x9E,0x2C,0xCD,0x60,0x36,0x87,0xB5,0x94,0xA6,
   0x54,0x73,0x3A,0x14,0x4E,   1,0x1D,0xB6,0xFD,0x37,0x48,0x4D,0x39,0xCB,0xE0,0x32,
tim
Code: [Select]
// begin FZ's original work
void twi_slave_init(unsigned char addr)
 // initialize stuff
 twi_reg_addr = 0;
 // set slave address
 TWAR = addr << 1;
 // enable twi module, acks, and twi interrupt
 TWCR = _BV(TWEN) | _BV(TWIE) | _BV(TWEA);
 // enable interrupts
 sei();
void twi_clear_int(unsigned char ack)
 // get ready by clearing interrupt, with or without ack
 if(ack != 0)
   TWCR = _BV(TWEN) | _BV(TWIE) | _BV(TWINT) | _BV(TWEA);
   TWCR = _BV(TWEN) | _BV(TWIE) | _BV(TWINT);
The 'encode' and 'decode' functions have been so widely copied on
the Internet that it is impossible to attribute correctly.
Refer to http://wiibrew.org/wiki/Wiimote/Extension_Controllers
for details on why this works for Nintendo controllers
// Encode/Decode data to format that most wiimote drivers except
// only needed if you use one of the regular wiimote drivers
char wm_ext_decode_byte (char x)
   x = (x ^ 0x17) + 0x17;
   return x;
char wm_ext_encode_byte (char x)
 x = x - 0x17;
 x = (x ^ 0x17);
 return x;
From Frank Zhao:
unsigned char wm_ror8(unsigned char a, unsigned char b)
 // bit shift with roll-over
 return (a >> b) | ((a << (8 - b)) & 0xFF);
void wm_gentabs()
 unsigned char idx;
 // check all idx
 for(idx = 0; idx < 7; idx++)
   // generate test key
   unsigned char ans[6];
   unsigned char tkey[6];
   unsigned char t0[10];
   for(unsigned char i = 0; i < 6; i++)
     ans[i] = pgm_read_byte(&(ans_tbl[idx][i]));
   for(unsigned char i = 0; i < 10; i++)
     t0[i] = pgm_read_byte(&(sboxes[0][wm_rand[i]]));
   tkey[0] = ((wm_ror8((ans[0] ^ t0[5]), (t0[2] % 8)) - t0[9]) ^ t0[4]);
   tkey[1] = ((wm_ror8((ans[1] ^ t0[1]), (t0[0] % 8)) - t0[5]) ^ t0[7]);
   tkey[2] = ((wm_ror8((ans[2] ^ t0[6]), (t0[8] % 8)) - t0[2]) ^ t0[0]);
   tkey[3] = ((wm_ror8((ans[3] ^ t0[4]), (t0[7] % 8)) - t0[3]) ^ t0[2]);
   tkey[4] = ((wm_ror8((ans[4] ^ t0[1]), (t0[6] % 8)) - t0[3]) ^ t0[4]);
   tkey[5] = ((wm_ror8((ans[5] ^ t0[7]), (t0[8] % 8)) - t0[5]) ^ t0[9]);
   // compare with actual key // TJM void* cast
   if(memcmp(tkey, (void*)wm_key, 6) == 0) break; // if match, then use this idx
 // generate encryption from idx key and rand
 wm_ft[0] = pgm_read_byte(&(sboxes[idx + 1][wm_key[4]])) ^ pgm_read_byte(&(sboxes[idx + 2][wm_rand[3]]));
 wm_ft[1] = pgm_read_byte(&(sboxes[idx + 1][wm_key[2]])) ^ pgm_read_byte(&(sboxes[idx + 2][wm_rand[5]]));
 wm_ft[2] = pgm_read_byte(&(sboxes[idx + 1][wm_key[5]])) ^ pgm_read_byte(&(sboxes[idx + 2][wm_rand[7]]));
 wm_ft[3] = pgm_read_byte(&(sboxes[idx + 1][wm_key[0]])) ^ pgm_read_byte(&(sboxes[idx + 2][wm_rand[2]]));
 wm_ft[4] = pgm_read_byte(&(sboxes[idx + 1][wm_key[1]])) ^ pgm_read_byte(&(sboxes[idx + 2][wm_rand[4]]));
 wm_ft[5] = pgm_read_byte(&(sboxes[idx + 1][wm_key[3]])) ^ pgm_read_byte(&(sboxes[idx + 2][wm_rand[9]]));
 wm_ft[6] = pgm_read_byte(&(sboxes[idx + 1][wm_rand[0]])) ^ pgm_read_byte(&(sboxes[idx + 2][wm_rand[6]]));
 wm_ft[7] = pgm_read_byte(&(sboxes[idx + 1][wm_rand[1]])) ^ pgm_read_byte(&(sboxes[idx + 2][wm_rand[8]]));
 wm_sb[0] = pgm_read_byte(&(sboxes[idx + 1][wm_key[0]])) ^ pgm_read_byte(&(sboxes[idx + 2][wm_rand[1]]));
 wm_sb[1] = pgm_read_byte(&(sboxes[idx + 1][wm_key[5]])) ^ pgm_read_byte(&(sboxes[idx + 2][wm_rand[4]]));
 wm_sb[2] = pgm_read_byte(&(sboxes[idx + 1][wm_key[3]])) ^ pgm_read_byte(&(sboxes[idx + 2][wm_rand[0]]));
 wm_sb[3] = pgm_read_byte(&(sboxes[idx + 1][wm_key[2]])) ^ pgm_read_byte(&(sboxes[idx + 2][wm_rand[9]]));
 wm_sb[4] = pgm_read_byte(&(sboxes[idx + 1][wm_key[4]])) ^ pgm_read_byte(&(sboxes[idx + 2][wm_rand[7]]));
 wm_sb[5] = pgm_read_byte(&(sboxes[idx + 1][wm_key[1]])) ^ pgm_read_byte(&(sboxes[idx + 2][wm_rand[8]]));
 wm_sb[6] = pgm_read_byte(&(sboxes[idx + 1][wm_rand[3]])) ^ pgm_read_byte(&(sboxes[idx + 2][wm_rand[5]]));
 wm_sb[7] = pgm_read_byte(&(sboxes[idx + 1][wm_rand[2]])) ^ pgm_read_byte(&(sboxes[idx + 2][wm_rand[6]]));
void wm_slaveTxStart(unsigned char addr)
 if(addr >= 0x00 && addr < 0x06)
   // call user event
   wm_sample_event();
void wm_slaveRx(unsigned char addr, unsigned char l)
 // if encryption data is sent, store them accordingly
 if(addr >= 0x40 && addr < 0x46)
   for(unsigned int i = 0; i < 6; i++)
     wm_rand[9 - i] = twi_reg[0x40 + i];
 else if(addr >= 0x46 && addr < 0x4C)
   for(unsigned int i = 6; i < 10; i++)
   for(unsigned int i = 0; i < 2; i++)
     wm_key[5 - i] = twi_reg[0x40 + 10 + i];
 else if(addr >= 0x4C && addr < 0x50)
   for(unsigned int i = 2; i < 6; i++)
   if(addr + l == 0x50)
     // generate decryption once all data is loaded
     wm_gentabs();
void wm_newaction(unsigned char * d)
 // load button data from user application // TJM: void* cast
 memcpy((void*)twi_reg, d, 6);
void wm_init(unsigned char * id,  unsigned char * t, unsigned char * cal_data, void (*function)(void))
//  int encrypt = 1;
 // link user function
 wm_sample_event = function;
 // start state
 wm_newaction(t);
// FIXME: encryption
//  if (encrypt) {
   twi_reg[0xF0] = 0xAA;
//  } else {
//    twi_reg[0xF0] = 0; // disable encryption
 int numIdBytes = 6;
 unsigned int idAddrRegStart = 0xFA;
 for(unsigned int i = 0, j = idAddrRegStart; i < numIdBytes; i++, j++) {
//      if (encrypt) {
         twi_reg[j] = wm_ext_encode_byte(id[i]);
//      } else {
//          twi_reg[j] = id[i];
 // set calibration data
 for(unsigned int i = 0, j = 0x20; i < 6; i++, j++) {
//      if (encrypt) {
         twi_reg[j] = wm_ext_encode_byte(cal_data[i]);
//      } else {
//          twi_reg[j] = cal_data[i];
 // initialize device detect pin
 dev_detect_port &= 0xFF ^ _BV(dev_detect_pin);
 dev_detect_ddr |= _BV(dev_detect_pin);
 delay(500); // delay to simulate disconnect // TJM was _delay_ms(500)
 // ready twi bus, no pull-ups
 twi_port &= 0xFF ^ _BV(twi_scl_pin);
 twi_port &= 0xFF ^ _BV(twi_sda_pin);
 // start twi slave, link events
 twi_slave_init(0x52);
 // make the wiimote think something is connected
 dev_detect_port |= _BV(dev_detect_pin);
tim
Code: [Select]
ISR(TWI_vect)
 switch(TW_STATUS)
   // Slave Rx
 case TW_SR_SLA_ACK: // addressed, returned ack
 case TW_SR_GCALL_ACK: // addressed generally, returned ack
 case TW_SR_ARB_LOST_SLA_ACK: // lost arbitration, returned ack
 case TW_SR_ARB_LOST_GCALL_ACK: // lost arbitration generally, returned ack
   // get ready to receive pointer
   twi_first_addr_flag = 0;
   // ack
   twi_clear_int(1);
 case TW_SR_DATA_ACK: // data received, returned ack
 case TW_SR_GCALL_DATA_ACK: // data received generally, returned ack
   if(twi_first_addr_flag != 0)
     // put byte in register
     unsigned char t = TWDR;
     if(twi_reg[0xF0] == 0xAA && twi_reg_addr != 0xF0) // if encryption is on
       // decrypt
       twi_reg[twi_reg_addr] = (t ^ wm_sb[twi_reg_addr % 8]) + wm_ft[twi_reg_addr % 8];
       twi_reg[twi_reg_addr] = t;
     twi_reg_addr++;
     twi_rw_len++;
     // set address
     twi_reg_addr = TWDR;
     twi_first_addr_flag = 1;
     twi_rw_len = 0;
   twi_clear_int(1); // ack
 case TW_SR_STOP: // stop or repeated start condition received
   // run user defined function
   wm_slaveRx(twi_reg_addr - twi_rw_len, twi_rw_len);
   twi_clear_int(1); // ack future responses
 case TW_SR_DATA_NACK: // data received, returned nack
 case TW_SR_GCALL_DATA_NACK: // data received generally, returned nack
   twi_clear_int(0); // nack back at master
   // Slave Tx
 case TW_ST_SLA_ACK:     // addressed, returned ack
 case TW_ST_ARB_LOST_SLA_ACK: // arbitration lost, returned ack
   wm_slaveTxStart(twi_reg_addr);
   twi_rw_len = 0;
 case TW_ST_DATA_ACK: // byte sent, ack returned
   // ready output byte
   if(twi_reg[0xF0] == 0xAA) // encryption is on
     // encrypt
     TWDR = (twi_reg[twi_reg_addr] - wm_ft[twi_reg_addr % 8]) ^ wm_sb[twi_reg_addr % 8];
     TWDR = twi_reg[twi_reg_addr];
   twi_reg_addr++;
   twi_rw_len++;
 case TW_ST_DATA_NACK: // received nack, we are done
 case TW_ST_LAST_DATA: // received ack, but we are done already!
   twi_clear_int(1);
 default:
   twi_clear_int(0);
tim
Code: [Select]
// array containing button data
unsigned char but_dat[6] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
// calibration data
unsigned char cal_data[32] = {
Data format info can be found at:
http://wiibrew.org/wiki/Wiimote/Extension_Controllers#Guitar_Hero_.28Wii.29_Guitars
 // GH3 Gibson Les Paul
 but_dat[0] = B11111111;
 but_dat[1] = B11111111;
 but_dat[2] = B00011111;
 but_dat[3] = B00011111;
 but_dat[4] = B11111111;
 but_dat[5] = B10000110;
 // make wiimote think this is a valid extension controller
wm_init(guitar_id, but_dat, cal_data,wm_timer_inc);
 // /*not supported with wiiuse*/  wm_init(drums_id, but_dat, cal_data,wm_timer_inc);
 // wm_init(nunchuk_id, but_dat, cal_data,wm_timer_inc);
 //  wm_init(classic_id, but_dat, cal_data,wm_timer_inc);
 while(1) {
   sample();
   delay(5);
called after wiimote has completed a request
void wm_timer_inc() {
static int counter = 0;
static int idx = 3;
unsigned char idxc = 0xF0;
void sample() {
 if (counter > 400) {
   counter = 0;
   if (idx == 8) {idx = 3; idxc = 0xF0;}
   but_dat[3] = ++idxc;
   but_dat[5] ^= (1 << 3);
   but_dat[5] ^= (1 << 4);
   but_dat[5] ^= (1 << 5);
   but_dat[5] ^= (1 << 6);
   but_dat[5] ^= (1 << 7);
   twi_reg[5] = wm_ext_encode_byte(twi_reg[5]);
   wm_newaction(but_dat);
   idx++;
 counter++;
tim
Finally, the twi.h file needs to be changed to enable "Fast I2C" - here's my changed twi.h You can find the file on your PC at:
[install dir]/hardware/libraries//Wire/utility/twi.h:
Code: [Select]
#ifndef twi_h
#define twi_h
 #include <inttypes.h>
 #define ATMEGA8
 #ifndef CPU_FREQ^M
 #define CPU_FREQ 16000000L
 #endif
 #ifndef TWI_FREQ^M
 #define TWI_FREQ 400000L
 #endif
 #ifndef TWI_BUFFER_LENGTH
 #define TWI_BUFFER_LENGTH 32
 #endif
 #define TWI_READY 0
 #define TWI_MRX   1
 #define TWI_MTX   2
 #define TWI_SRX   3
 #define TWI_STX   4
 void twi_init(void);
 void twi_setAddress(uint8_t);
 uint8_t twi_readFrom(uint8_t, uint8_t*, uint8_t);
 uint8_t twi_writeTo(uint8_t, uint8_t*, uint8_t, uint8_t);
 uint8_t twi_transmit(uint8_t*, uint8_t);
 void twi_attachSlaveRxEvent( void (*)(uint8_t*, int) );
 void twi_attachSlaveTxEvent( void (*)(void) );
 void twi_reply(uint8_t);
 void twi_stop(void);
 void twi_releaseBus(void);
#endif
The dev environment is:
  • Arduino diecimilia
  • Arduino IDE 0017
  • Windows XP Pro with SP3
  • Bluetooth dongle (I think it has the WIDCOMM stack)
  • BlueSoleil v6.0.x
  • wiiuse 0.12
  • wiiuseJ 0.12
--Tim.
Sodrohu
What are the pins you use to connect to the wiimote's cable? is the red wire connected to Arduino's voltage reference?
