Topic: Show us your arduino electronic work area, no matter how humble or grand. (Read 13590 times) previous topic - next topic
TomGeorge
Hi, I have just spent my work Christmas Bonus to make my idea of a decent work bench area to get things done, after working off an old kitchen table and makeshift shelf to put test gear on, down the back of my garage.
Here is my new work area, show us your humble or grand work space that all these arduino and other electronic masterpieces are born.
Tom.... :)
Everything runs on smoke, let the smoke out, it stops running....
TomGeorge
Hi, I have got the new workbench top finished, well 90%, there will always be something to add.
Its made of lengths of 1200mm long 19mm thick pine board.
I tried to do as little timber cutting as possible, so the shelve frame is 1200mm wide and 1200mm plus 2x19mm high.
I only had to cut the three shelves that fit inside the frame, taking 38mm off their length.
The bottom shelf with the CRO and power supply, is actually two pieces, one that fits in the frame and a narrow piece that is glued and screwed with tags to the deeper one. This makes this shelf deeper for the instruments. (If you look at the picture, near the roll of red tape you can see one of the tags.)
Under this shelf I have made a light box, a piece of timber across the front acts as a shade and support for the LED array that shines down. This box, painted white, will be for containers for holding bits and pieces as well as tools while working on a project, I have a portable tool cabinet to store and lock-up my tools.
In-front of the base of the frame I lashed out and bought a piece of 19mm melamine laminated board to be the main work area.
To keep the frame rigid the back of the light box is a sheet of 12mm particle board glued and screwed to the base and up the two sides.
Higher up each of the narrower shelves has a length of the same shelving material behind it to strengthen and provide a back to it.
Assembled it can be carried by two people.
My next job is to fit brackets on the side for glue gun, heat gun, drills and fit a 4way power board to the timber shade, and also the row of terminals for DC power from the power supply.
(CAUTION: Not all timber in a rack is 1200mm, I had pre warning from a relatives mate who works there, spent quite a bit of time matching 1200mm lengths. In the long term worth the effort.)
Before this my home workbench was an old kitchen table and a wooden shelf made of bricks and plank to hold test equipment, that was okay because I could use my employers workshop if anything got serious.
It used  to be ½ a block away, now its 15min drive when he bought a factory shed.
So out of necessity!!!!
Whether the results of my work will improve or become more inspiring will only tell with time.
The overall height on the table is just right for a duck diseased guy like me,(bum to close to the ground)
Tom.....
Now let us see where you work, slave, succeed and play with electronics, from pictures posted of some projects the creation environment is pretty minimal in some cases.
So be proud forum members, show us where you do your worst, best in this activity striving for excellence.
SirNickity
Haha!  Love it!  I'm so glad you took the bait on this idea.  I'm in the planning stages to overhaul my workroom, so I'm going to shamelessly rob ideas from this thread.  Keep 'em coming.   8)
TomGeorge
Hi, feel free, most of stuff I've done so far has been trouble free productions, SO FAR.
Tom.... :)
MAS3
Nice.
How do like those LED strips ?
Do you see a lot of light sources (so also a lot of different shades at your project which might bother you) ?
If so, consider indirect lighting.
Have the LEDs send their light towards the white wall and have that reflect it/
Have a look at "blink without delay".
Did you connect the grounds ?
Je kunt hier ook in het Nederlands terecht: http://arduino.cc/forum/index.php/board,77.0.html
TomGeorge
Hi MAS3 ,yes I thought about that, because they are elcheapo ebay strips.
The way they are mounted I'm not looking directly at them, and there appears to be enough reflection from the back of the box to minimize any spotlighting.
The LED itself appears to have a wide transmitting angle so coverage looks good.
I'm on the lookout for an old panto-graph type overhead lamp that I can convert to LED to bolt to the side for the shelves.
Off to local trash and treasure market this weekend to see what I can find.
That strip which is three rows consumes 1A at 12Vdc.
Tom..... 8)
Pedro147
Tom I'm glad to see that you put in some quality Duinotime over the break. Your new work space is looking good. I have posted this pic of my humble work area before but hey I'm into recycling
Pedro
http://www.pedroduino.com
graynomad
As I've been living in a motorhome for 13 years I don't have a lot of room. Here is a pic of my "workbench" from a couple of years ago, it's a BBQ set box that's been stripped of most of the holders for the BBQ tools.
This normally sits on my 1x1=foot slide out table that you can just see in the background with yellow-handled cutters on it. And it packs away above the laptop (far right) for driving.
This is from 2BA (2 years Before Arduino), note the STK500 dev board I'm using to program my ATmega644-based truck speedo. One of the small chips on the breadboard is an ATtiny85 that's generating pulses so I can test the speedo.
That was then, and this is now.
We've pretty much dropped anchor on our land in central Queensland and I have two shipping containers. One for tools, .5 for junk, and .5 is going to be a workshop. I've already built the benches but need to add shelves and a front door etc.
No pics of that yet but I plan to get a good new CRO (do you non-Aussies know what a CRO is?) bench PSU etc. I may even spash out and get a new PC with triple screens, luxury I suppose but great for CAD work.
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
Chagrin
My workroom is currently stripped down to the studs. Been at it for almost two months now; never underestimate the surprises you can find in the walls of a 113yr old home.
TomGeorge
Hi Pedro, good stuff, your pic has reminded met to make a holder for the coffee mug, preferably away from soldering station.
Graynomad, love the case method, I have similar arrangement with amateur radio gear, all in a case so I can move from car to car.
Shipping containers, now there's an idea, instead of trying to clean out shed or garage, just buy a container. hmmm.
Chagrin, underconstruction, I could imagine in a 113yr old house, found anything interesting under the lino?
Thanks guys, looking good.
Tom..... 8) (36DegC here today, it rained, dropped to 32 then jumped back to 34 now.)
Pedro147
graynomad
He he, Tom used it as well. Not many cathode rays in scopes theses days eh, but I still tend to use the term.
It's amazing what you can buy now for $500 or less, better than our old Tektronics 465s that even our company was hard pressed to afford.
______
Rob
TomGeorge
Hi Rob.
If you look in my first pic, on the shelf is a Lab Supply and a CRO, its portable, bought it back in 1985, has nicads in it, or will run from 11 to 30V DC, or 240/120AC.
It has bounced around in the back of a Ford Falcon Station Wagon for over 1 Million kms. Only problem, bolts fell out of power transformer brackets and transformer swung around inside chassis on its leads.
Still works, only 6Mhz but was all I needed at the time.
Hidden under bench is 4ch, 100Mhz CRO, which fits nicely on shelf as well.
Tom..  :) (10:15pm local, 23DegC, thunder storms, spot fires all over western half of state.)
(Been to golden arches, coffee kick frappe, ahh yes..)
SirNickity
Yes!  But only because I watch that crazy Aussie bloke, Dave Jones...   XD
BTW, I dare you to try and board an airplane with that case!
graynomad
Quote
A highly unlikely scenario, mostly because I can't afford to fly anywhere :)
Here is one of the containers workshops.
That's our motorhome in the background, this has all been landscaped since, it looks a lot nicer now.
______
Rob
