Topic: Error while reading values from two differant Infrared receivers? (Read 571 times) previous topic - next topic
emreakay
Hi i got a problem and i need help
i use Ken Shirriff's IRremote library
i want to read differant values from two differant ir receiver.
i can read one value but when connect second ir receiver and try to read 1 and 2 together, i cant see any result.
here is my code
* IRremote: IRrecvDemo - demonstrates receiving IR codes with IRrecv
* An IR detector/demodulator must be connected to the input RECV_PIN.
* Version 0.1 July, 2009
* Copyright 2009 Ken Shirriff
* http://arcfn.com
#include <IRremote.h>
int F = 2;
int B = 3;
IRrecv irrecvF(F);
IRrecv irrecvB(B); // bunu yaz?nca cal??smiyor
decode_results resultsF;
decode_results resultsB;
 irrecvF.enableIRIn(); // Start the receiver
 irrecvB.enableIRIn();
 if (irrecvF.decode(&resultsF)) {
   Serial.print("F: ");
   Serial.println(resultsF.value, DEC);
   irrecvF.resume(); // Receive the next value
 if (irrecvB.decode(&resultsB)) {
   Serial.print("B: ");
   Serial.println(resultsB.value, DEC);
   irrecvB.resume(); // Receive the next value
michinyon
what actually happens when you run this ?
is the "resume()" function causing the whole thing to wait indefinitely ?
