Topic: [RISOLTO]MLX90614 with wire.h libraries (Read 2863 times) previous topic - next topic
F4LK0
Jan 09, 2014, 10:25 pm Last Edit: Jan 21, 2014, 02:35 pm by F4LK0 Reason: 1
I  try to read temp value from MLX90614 using Arduino DUE. but I have a big problem. I receive always max value (0x7FFF).
I used this code
Code: [Select]
#define MLX90614_ADDR_1 0x5A
#define MLX90614_TOBJ1_RAM_ADDR 0x07
#define MLX90614_TOBJ2_RAM_ADDR 0x08
#define MLX90614_ENVIR_RAM_ADDR 0x06
 Wire.begin();
 uint16_t data = 0;
 uint8_t PEC = 0;
 //Inizio comunicazione
 Wire.beginTransmission(MLX90614_ADDR_1);
 //dico di leggere dall'area della RAM del sensore
 Wire.write(MLX90614_TOBJ1_RAM_ADDR);
 //fine comunicazione senza rilascio del canale
 Wire.endTransmission(false);
 //richiesta di invi odati dallo slave senza rilascio del canale
 Wire.requestFrom(MLX90614_ADDR_1, 3, true);
 //attendo finche ci sono dati sul canale
 while(Wire.available() < 3);
 //leggo il primo byte
 data = Wire.read();
 //leggo il secondo byte
 data |= (Wire.read() & 0x7F) << 8;
 //leggo il PEC
 PEC = Wire.read(); // PEC
 //fine transazione e chiusura del canale
 //Wire.endTransmission();
 delay(200);
 float celsius = data / 50 - 273.15; //temperatura in °C
 float kelvin  = data / 50; //temperatura in Kelvin
 //visualizzo nel debug il valore il valore
 Serial.print(data);
 Serial.print(" - ");
 Serial.print(PEC);
 Serial.print("\n °C = ");
 Serial.print(celsius);
 Serial.print("\n K = ");
 Serial.print(kelvin);
 Serial.print("\n");
Somebody can Help me to resolve my problem?
jmparatte
I've a similar problem with the same chip, but only with Arduino DUE, not with Arduino UNO. Look my message http://forum.arduino.cc/index.php?PHPSESSID=8tgp4v58dat11h17bsi42cta13&topic=209555.0 and watch the differences in the 2 attached pictures, the i2c START of Arduino DUE are bad.
F4LK0
hi,
i know your problem. I'm Simone and I wrote in this blog http://skyduino.wordpress.com/2013/11/02/arduino-capteur-de-temperature-sans-contact-mlx90614/.
F4LK0
somebody resolved the problem?
thanks
F4LK0
in this post I found the solution:
http://forum.arduino.cc/index.php/topic,137607.msg1101421.html#msg1101421
this is code
Code: [Select]
#include <Arduino.h>
#include <include/twi.h>
#define ADDR      0x5A
//EEPROM 32x16
#define TO_MAX    0x00
#define TO_MIN    0x01
#define PWM_CTRL  0x02
//RAM 32x16
#define RAW_IR_1  0x04
#define RAW_IR_2  0x05
#define TA        0x06
#define TOBJ_1    0x07
#define TOBJ_2    0x08
#define SYNC_PIN  2
static const uint32_t TWI_CLOCK = 100000;
static const uint32_t RECV_TIMEOUT = 100000;
static const uint32_t XMIT_TIMEOUT = 100000;
Twi *pTwi = WIRE_INTERFACE;
static void Wire_Init(void) {
  pmc_enable_periph_clk(WIRE_INTERFACE_ID);
  PIO_Configure(
  g_APinDescription[PIN_WIRE_SDA].pPort,
  g_APinDescription[PIN_WIRE_SDA].ulPinType,
  g_APinDescription[PIN_WIRE_SDA].ulPin,
  g_APinDescription[PIN_WIRE_SDA].ulPinConfiguration);
  PIO_Configure(
  g_APinDescription[PIN_WIRE_SCL].pPort,
  g_APinDescription[PIN_WIRE_SCL].ulPinType,
  g_APinDescription[PIN_WIRE_SCL].ulPin,
  g_APinDescription[PIN_WIRE_SCL].ulPinConfiguration);
  NVIC_DisableIRQ(TWI1_IRQn);
  NVIC_ClearPendingIRQ(TWI1_IRQn);
  NVIC_SetPriority(TWI1_IRQn, 0);
  NVIC_EnableIRQ(TWI1_IRQn);
static void Wire1_Init(void) {
  pmc_enable_periph_clk(WIRE1_INTERFACE_ID);
PIO_Configure(
g_APinDescription[PIN_WIRE1_SDA].pPort,
g_APinDescription[PIN_WIRE1_SDA].ulPinType,
g_APinDescription[PIN_WIRE1_SDA].ulPin,
g_APinDescription[PIN_WIRE1_SDA].ulPinConfiguration);
PIO_Configure(
g_APinDescription[PIN_WIRE1_SCL].pPort,
g_APinDescription[PIN_WIRE1_SCL].ulPinType,
g_APinDescription[PIN_WIRE1_SCL].ulPin,
g_APinDescription[PIN_WIRE1_SCL].ulPinConfiguration);
NVIC_DisableIRQ(TWI0_IRQn);
NVIC_ClearPendingIRQ(TWI0_IRQn);
NVIC_SetPriority(TWI0_IRQn, 0);
NVIC_EnableIRQ(TWI0_IRQn);
  pinMode(SYNC_PIN, OUTPUT);
  digitalWrite(SYNC_PIN, LOW);
  Wire_Init();
  // Disable PDC channel
  pTwi->TWI_PTCR = UART_PTCR_RXTDIS | UART_PTCR_TXTDIS;
  TWI_ConfigureMaster(pTwi, TWI_CLOCK, VARIANT_MCK);
  uint16_t tempUK;
  float tempK;
  uint8_t hB, lB, pec;
  digitalWrite(SYNC_PIN, HIGH);
  delayMicroseconds(10);
  TWI_StartRead(pTwi, ADDR, TOBJ_1, 1);
  lB = readByte();
  hB = readByte();
  //last read
  TWI_SendSTOPCondition(pTwi);
  pec = readByte();
  while (!TWI_TransferComplete(pTwi))
  //TWI_WaitTransferComplete(pTwi, RECV_TIMEOUT);
  tempUK = (hB << 8) | lB;
  if(tempUK & (1 << 16)) {
    Serial.print("Error !");
    Serial.println(tempK);
  else {
    tempK = ((float)tempUK * 2) / 100 ;
    Serial.print("Temp UK: ");
    Serial.print(tempUK);
    Serial.print(" C: ");
    Serial.println(tempK - 273.15);
  Serial.print(hB, HEX);
  Serial.print(" : ");
  Serial.print(lB, HEX);
  Serial.println(pec, HEX);
  delay(2000);
uint8_t readByte() {
  //TWI_WaitByteReceived(pTwi, RECV_TIMEOUT);
  while (!TWI_ByteReceived(pTwi))
  return TWI_ReadByte(pTwi);
static inline bool TWI_WaitTransferComplete(Twi *_twi, uint32_t _timeout) {
  while (!TWI_TransferComplete(_twi)) {
    if (TWI_FailedAcknowledge(_twi))
      return false;
    if (--_timeout == 0)
      return false;
  return true;
static inline bool TWI_WaitByteReceived(Twi *_twi, uint32_t _timeout) {
  while (!TWI_ByteReceived(_twi)) {
      return false;
      return false;
  return true;
static inline bool TWI_FailedAcknowledge(Twi *pTwi) {
  return pTwi->TWI_SR & TWI_SR_NACK;
and jmparatte tested the signal.....
