Topic: Sketch not working after disconnect/connect power (Read 3975 times) previous topic - next topic
bishkot
Jan 10, 2014, 08:08 pm Last Edit: Jan 10, 2014, 10:18 pm by bishkot Reason: 1
I amI have a very strange issue. My sketch works great, but it is not working after i disconnect/connect the power supply (external 12V, 3.5A)
Sketch works if i press manually the RESET button of the Arduino uno or that in GSM Shield.
I am not a specialist but it seemd to me like a booting problem or something? Is this right? How can i make it reset every time the power is reconected? Is there such thing?
Thanks in advance, i hope to solve this problem ASAP.
davidgoth
Check if your issue happens with the examples included with Arduino IDE (GSM).
bishkot
Yes its same thing....sometimes it works fine but sometimes works about till 20% of the code and then freezes there...very strange..
What can that be?
bishkot
It sounds to me like there is something to do with gsmbegin(pin,restart) because when i set it to
    if(gsmAccess.begin(PINNUMBER,false)==GSM_READY)
instead of
if(gsmAccess.begin(PINNUMBER)==GSM_READY)
- added , false parameter everything vorks fine....i am not sure why it works better with the false parameter....
