Topic: Thomas Edison vs Tesla (Read 5730 times) previous topic - next topic
cjdelphi
Edison and westinghouse pitched the ideas for a Generator, tesla high voltage ac, edison low voltage dc.
Great shows were put on, electrocution from both power sources, DC was supposed to hurt but not kill you... well I've been zapped a couple of times at 240ac but I've felt my muscles contract from the sparks from battery terminal clips when high current flows...
So it begs the question a high powered dc low voltage placed near your heart, this should be able to kill?
Henry_Best
I can't comment on the safety aspect, but just imagine the size of the conductors in the distribution grid if we'd have gone the DC route. There wouldn't have been enough copper in the world.
MarkT
Absolutely, electrocution is indeed possible with DC (it causes more muscle contraction than AC), both AC and DC kill.
BTW DC power transmission is employed, the problem is the large cost of 100kV inverters to convert back to AC
A common use is to bridge between countries that use different line frequencies or to decouple segments of a power
network so they don't have to be phase-locked.
elac
#3
Jan 15, 2014, 03:42 am Last Edit: Jan 15, 2014, 03:44 am by elac Reason: 1
High voltage high current DC can stop your heart.
Think of TV tube caps.
But while pondering the question, a bit of comic relief- Edison Vs Tesla
It's all about the skills
graynomad
Quote
decouple segments of a power network so they don't have to be phase-locked.
Is that how they connect all those wind turbines?
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
SirNickity
Obligatory link to The Oatmeal:
http://theoatmeal.com/comics/tesla
graynomad
I don't know if it's all true but it makes me mad every time I read that.
_______
Rob
AWOL
Quote
Fibrillation can start from as low as 150uA applied at the heart.
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
retrolefty
Quote
______
Rob
Actually any and all types of power generator plants that are to supply power to a common 'grid' must be phased-locked with the grid.
MarkT
Quote
______
Rob
I think it varies.
Quote
They will be phase locked whether they like it or not - failure to do so blows
the fuses since an efficient generator set can carry vastly higher than normal
currents if mis-phased.  A series of generator sets on the grid has been likened
to a row of heavy pendulums connected by cotton thread - if they are not in
synchrony something breaks.
retrolefty
Quote
______
Rob
I think it varies.
Quote
Correct. Starting up or shutting off a plants grid connected generator is a very structured process often done in coordination with grid operators to slowly ramp up and down power as such generators cannot do 0-100% and 100%-0 instantaneously. First step is to syn up with the grid and then manipulate the generator's phase control to force a specific amount of current onto the grid.
KeithRB
Quote
Some of the super high voltage transmission lines are DC now. To bring DC to the home requires highly efficient DC-DC converters, however. In the beginning, transformers were a very nice way to transform voltages up and down. To do this with DC requires high voltage semidonductors.
Boardburner2
Ther used to be a dc link between england and france to make best use of nuclear plants i think.
TomGeorge
Hi, there is a HV DC link between Tasmania and Victoria.
In the cases I have seen,  Wind Turbines in a wind farm supply a common HV DC bus then it is cycloinverted into the national grid.
Tom...... :)
Everything runs on smoke, let the smoke out, it stops running....
retrolefty
Tom...... :)
Never heard of a cycloinvertor.
Wikipedia says that cyclonconverter is used to convert AC to AC not DC to AC?
http://en.wikipedia.org/wiki/Cycloconverter
