Topic: Yún do not accept opkg update (Read 15356 times) previous topic - next topic
maufirma
I had the same problem today, after reflashing my Yun.
I solved it using 8.8.8.8 as name server.
Code: [Select]
root@Arduino:/etc# nslookup downloads.arduino.cc 8.8.8.8
Server:    8.8.8.8
Address 1: 8.8.8.8 google-public-dns-a.google.com
Address 1: 5.254.127.101 101.miami.ssd2.wizzsolutions.com
Address 2: 5.254.114.221 221.ssd1.mia.wizzsolutions.com
Adding "5.254.127.101 downloads.arduino.cc" to my /etc/hosts file I solved the signature problem.
edsonsoares
How can I sync with browser? It seems this was the solution that worked fine for this problem, but I'm new to working with linux and the command line. Can someone be clearer on how to check the date and then sync. What should I type at the terminal? Thanks for the patience.
Angelo9999
https://github.com/sngl
Hasr
I had this problem too and found 2 possible problems and their solutions:
1 - Time not sync; Solving: at LUCI sync with browser, select the right timezone for you and reboot.
2 - Wrong IP configurations; Solving: Use DHCP instead of static IP because you probably configured it wrong. To check if it is bad IP configurations you can 'ping' somthing on the yun console.
