Topic: Compiler error associated with Switch (using documentation) (Read 4290 times) previous topic - next topic
tweedius
Hello,
The compiler was giving me a rather hard to track error, I was getting the dreaded "expected primary-expression before '}' token" error.  I looked through the code 50 times and had all my }'s and ;'s in order.  What I found out is that if you use "default:" without a break; or without some sort of statement that ends in ";" while using the switch() statement you will get this error.
The documentation has commented lines in the example code after the default: label (http://arduino.cc/en/Reference/SwitchCase).  However if you ran the code as is in the example code you would get this same error.
I know this may be minor, but it took me a good deal of time to track down the error until I remembered the comment everything out and then slowly un-comment everything trick.
I hope I have given enough detail and I hope this may be useful, it is getting late and the caffeine isn't helping anymore.  Also, I hope this is the appropriate place to post this, as the reference page led me here.
Thanks.
-Mat
robtillaart
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
tweedius
Sorry for the late reply.  I didn't see this until today.  Here is some code that produces the compiler error:
Error:
Code: [Select]
lightbar.cpp: In member function 'void lightbar::set_led(int, int, int, int)':
lightbar.cpp:81: error: expected primary-expression before '}' token
lightbar.cpp:81: error: expected `;' before '}' token
This code is just a little project I am working on and completely unfinished, but if this is a rare case I wanted to be able to demonstrate it:
Relevant code:
Main sketch:
Code: [Select]
#include "Tlc5940.h"
#include "lightbar.h"
lightbar lightbar;
int counter = 0;
int d = 30;
int r, g, b;
  lightbar.init();
  r = 0;
  g = 0;
  b = 0;
  for(int i=0; i <=1000; i++){
    lightbar.set_led(0, i, 0, 0);
    lightbar.set_led(1, i, 0, 0);
    lightbar.set_led(2, i, 0, 0);
    lightbar.set_led(3, i, 0, 0);
    lightbar.set_led(4, i, 0, 0);
    delay(d);
  for(int i=1000; i <=1000; i++){
    lightbar.set_led(0, 500, 0, i);
    lightbar.set_led(1, 500, 0, i);
    lightbar.set_led(2, 500, 0, i);
    lightbar.set_led(3, 500, 0, i);
    lightbar.set_led(4, 500, 0, i);
    delay(d);
  for(int i=1000; i > 0; i--){
    lightbar.set_led(0, i, 0, i);
    lightbar.set_led(1, i, 0, i);
    lightbar.set_led(2, i, 0, i);
    lightbar.set_led(3, i, 0, i);
    lightbar.set_led(4, i, 0, i);
    delay(d);
    lightbar.set_led(0, 0, i, 0);
    lightbar.set_led(1, 0, i, 0);
    lightbar.set_led(2, 0, i, 0);
    lightbar.set_led(3, 0, i, 0);
    lightbar.set_led(4, 0, i, 0);
    delay(d);
lightbar.cpp:
Code: [Select]
#include "Arduino.h"
lightbar::lightbar(){
  //Constructor, empty for now
// calls Tlc5940.h init function and clears any values on the chip
void lightbar::init(){
  //initialize tlc(s)
  Tlc.init();
  //reset pins to off
  Tlc.set(0, 0);
  Tlc.set(1, 0);
  Tlc.set(2, 0);
  Tlc.set(3, 0);
  Tlc.set(4, 0);
  Tlc.set(5, 0);
  Tlc.set(6, 0);
  Tlc.set(7, 0);
  Tlc.set(8, 0);
  Tlc.set(9, 0);
  Tlc.set(10, 0);
  Tlc.set(11, 0);
  Tlc.set(12, 0);
  Tlc.set(13, 0);
  Tlc.set(14, 0);
  Tlc.set(15, 0);
  //send data
  Tlc.update();
void lightbar::set_led(int led, int r, int g, int b){
  switch (led) {
    case 0:
      Tlc.set(0, r);
      Tlc.set(1, b);
      Tlc.set(2, g);
      Tlc.update();
    case 1:
      Tlc.set(3, r);
      Tlc.set(4, b);
      Tlc.set(5, g);
      Tlc.update();
    case 2:
      Tlc.set(6, r);
      Tlc.set(7, b);
      Tlc.set(8, g);
      Tlc.update();
    case 3:
      Tlc.set(9, r);
      Tlc.set(10, b);
      Tlc.set(11, g);
      Tlc.update();
    case 4:
      Tlc.set(12, r);
      Tlc.set(13, b);
      Tlc.set(14, g);
      Tlc.update();
    default:
      //Tlc.update();
void lightbar::set_all(int color){
  //reset pins to off
  Tlc.set(0, color);
  Tlc.set(1, color);
  Tlc.set(2, color);
  Tlc.set(3, color);
  Tlc.set(4, color);
  Tlc.set(5, color);
  Tlc.set(6, color);
  Tlc.set(7, color);
  Tlc.set(8, color);
  Tlc.set(9, color);
  Tlc.set(10, color);
  Tlc.set(11, color);
  Tlc.set(12, color);
  Tlc.set(13, color);
  Tlc.set(14, color);
  Tlc.set(15, color);
  //send data
  Tlc.update();
void lightbar::clear_all(){
    //reset pins to off
  Tlc.set(0, 0);
  Tlc.set(1, 0);
  Tlc.set(2, 0);
  Tlc.set(3, 0);
  Tlc.set(4, 0);
  Tlc.set(5, 0);
  Tlc.set(6, 0);
  Tlc.set(7, 0);
  Tlc.set(8, 0);
  Tlc.set(9, 0);
  Tlc.set(10, 0);
  Tlc.set(11, 0);
  Tlc.set(12, 0);
  Tlc.set(13, 0);
  Tlc.set(14, 0);
  Tlc.set(15, 0);
  //send data
  Tlc.update();
lightbar.h:
Code: [Select]
#ifndef lightbar_h
  #define lightbar_h
  #define MAX_BRIGHTNESS 1023
  class lightbar
    public:
      lightbar();
      void init();
      void set_led(int led, int r, int g, int b);
      void set_all(int color);
      void clear_all();
    private:
#endif
Judging by your response, I'm guessing it may not occur in a normal sketch, but my problem may be associated with the switch statement being in a .cpp file?
-Mat
tweedius
Also, if you uncomment the line after the default: label or add break; or any statement that ends with a ';' the error goes away.
pYro_65
I got the same error in my test sketch.
It appears switch cases are labels, so the compiler needs a valid instruction to jump to.
  • Omit the default label.
  • Add a semi colon after it.
  • Add a break.
    I'm still trying to find an exact answer, however other compilers may simply handle this situation by adding their own break;
Forum Mod anyone?
https://arduino.land/Moduino/
westfw
gcc definitely doesn't like it, even on an x86 system:
BillW-MacOSX-2<5010> more break.c
#include <stdio.h>
#include <stdlib.h>
int main(int c, char *argv[])
    switch(c) {
    case 12: printf("12");
    case 99: printf("99");
    default:
    exit(0);
BillW-MacOSX-2<5011> gcc -c99 break.c
break.c: In function 'main':
break.c:12: error: label at end of compound statement
robtillaart
not only switch case labels but any label. Minimal version
Code: [Select]
  monkey:
Rob Tillaart
pYro_65
Yeah that's why I assumed case labels are actual line labels. I'm pretty sure labels do require source to point to, its other compilers playing nice that are allowing it. However I thought switch was an exception.
It must be because the compiler cannot decide what to do with it. It could point to the implicit compiler generated return, or the explicit next statement outside of the function. However every situation the error occurs is quite illogical and is probably a good hint to change things.
Forum Mod anyone?
westfw
pYro_65
I'm not sure about labels outside of a switch,  but I have many times commented out the code in a default case to debug my code. This was in visual studio, but I haven't got  a recent version to verify. The OP's post caught my attention as its something I remember doing without error.
Oh, it was all in C++, no C files were used to compile the code.
Forum Mod anyone?
LozK
I got a similar error with a switch statement in my code today.
While searching on the forum for a solution (and to see if it had been answered elsewhere), I came to the conclusion that this has not really been "fixed" in at least one sense - that the example on the Reference page ("switch / case statements", at: https://www.arduino.cc/en/Reference/SwitchCase) gives an error when used as it is on that page. I got a similar error with a switch statement in my code today.
Since people use the Reference pages to learn the right way to do things, shouldn't the code be correct and functional for the platform/compiler that the code is intended for as it is written the page?
If that code is copied and pasted into an otherwise blank sketch (just after declaring the "var" variable that it uses, or using any other variable in its place), the code fails with an "expected primary-expression before '}' token" error.
It would seem helpful to either change the code on that Reference page so that there is break in the default section (so that the example actually works), and/or include some text as way of explanation that if something is not included in the last case / default section then an error will occur.
I can see the point of some of the comments I have read on this (maybe it's not logical to include nothing in the default, or any, section / it's the fault of the compiler / etc.), but those seem like side issues - the main issue is that the example code on the Reference page is still erroneous, despite comments on this going back to at least Dec, 2009. Is nobody able to change the Reference pages?
I am sorry if I sound a little irate, but it took quite a long time to fix my problem, especially as I was reassured by the Reference page that I was doing it right. So I was just wondering if a change the Reference page's code or comments might help others before they tear all of their hair out, too?
PaulS
Quote
"Able to" and "Willing to" seem to be two different things. There HAVE been some corrections, though nowhere near enough, but ONLY when those things are pointed out on the Website and Forum part of the forum in a FACTUAL manner (no whining!).
And, no, I can't do it.
pert
It was fixed, regressed in the new Language Reference system, then I just fixed it again:
https://github.com/arduino/reference-en/pull/212
The bug still exists on the website but hopefully they'll push the recent changes here from the reference repository soon.
