Topic: delay using timer (Read 1 time) previous topic - next topic
doors666
I want to use timers to measure time between two time instances. I tried these two approaches but none of them seem to work. output is always printed as 0.
Code: [Select]
// lets use timer number 6 (ch1, timer 2), address values are from the datasheet
// addresses are for capture mode.
unsigned int volatile * const TC_Control = (unsigned int *) 0x40084080;
unsigned int volatile * const TC_Mode = (unsigned int *) 0x40084084;
unsigned int volatile * const TC_Value = (unsigned int *) 0x40084090;
static void stop_timer()
Serial.println("stopping timer");
// control register - setting this to one will enable timer, set to 2 to disable timer
*TC_Control = TC_CCR_CLKDIS;
static void start_timer()
Serial.println("starting timer");
// this is used to set the prescalar, set it to 2 to use TIMER_CLOCK3 (MCK/32)
*TC_Mode = 2;
*TC_Control = TC_CCR_CLKEN | TC_CCR_SWTRG;
unsigned int t1, t2;
start_timer();
t1 = *TC_Value;
Serial.print("time 1 is ");
Serial.println(t1);
       // some more code comes here.
t2 = *TC_Value;
Serial.print("time 2 is ");
Serial.println(t2);
Serial.print("time taken by setup: ");
Serial.println(t2-t1);
Serial.println("exiting setup");
I also tried the arduino calls. that also printed zero.
Code: [Select]
start_timer();
t1 = TC_ReadCV(TC1, 2);
Serial.println(t1);
    // some code here..
t2 = TC_ReadCV(TC1, 2);
Serial.println(t2);
TC_Stop(TC1, 2);
TC_Configure(TC1, 2, TC_CMR_WAVE | TC_CMR_TCCLKS_TIMER_CLOCK3);
TC_Start(TC1, 2);
doors666
got it... i need to start the clock before doing the TC_Configure, like this -
   pmc_enable_periph_clk(ID_TC5);
THOR-00
#2
Jul 14, 2014, 12:47 pm Last Edit: Jul 14, 2014, 01:01 pm by THOR-00 Reason: 1
Hi, I'am trying to get time between two events but I also get only zeros. My code looks like this:
Code: [Select]
#include "avr/io.h"
#include "Arduino.h"
#include "../../Atmel/Atmel Toolchain/AVR8 GCC/Native/3.4.1056/avr8-gnu-toolchain/avr/include/avr/iomxx0_1.h"
#include "wiring.h"
#include "C:\Program Files (x86)\Arduino\hardware\arduino\sam\system\libsam\include\tc.h"
#include "C:\Program Files (x86)\Arduino\hardware\arduino\sam\system\libsam\include\pmc.h"
#include "time.h"
#include "sys\types.h"
//ports:
const int zero_signal = A0;
const int return_signal = A1;
const int sync_signal = 24;
const int clock_signal = 22;
//variables:
boolean clk, sync;
unsigned long int zero_value = 0, return_value = 0;
double zero_rise[3], return_rise[3], tim;
int i = 0, j = 0;
//put your setup code here, to run once:
pinMode(zero_signal, INPUT);
pinMode(return_signal, INPUT);
pinMode(sync_signal, INPUT);
pinMode(clock_signal, INPUT);
//MCK = 84MHz
//timer tuning:
//long dummy=REG_TC0_SR0; //vital - reading this clears some flag, otherwise you get infinite interrupts
//NVIC_EnableIRQ(TC0_IRQn); //enable TC0 interrupts
//REG_PIOA_PDR = 1<<25; //disable PIO, enable peripheral
//REG_PIOA_ABSR= 1<<25; //select peripheral A
analogReadResolution(12);
//put your main code here, to run repeatedly:
clk = digitalRead(clock_signal);
sync = digitalRead(sync_signal);
//if (clk) == 1 & sync == 0)
zero_signal_1:
zero_rise[i] = analogRead(zero_signal);
if (i == 1)
zero_rise[2] = ((zero_rise[1] - zero_rise[0]) / 4095);
if (((atan(zero_rise[2]))*180)/PI >= 2)
//start timer
Serial.println("Start timer");
Serial.flush();
pmc_enable_periph_clk(ID_TC1);
TC_Start(TC1, 2);
i = 0;
goto zero_signal_1;
i++;
goto zero_signal_1;
return_signal_1:
return_rise[j] = analogRead(return_signal);
if (j == 1)
return_rise[2] = ((return_rise[1] - return_rise[0]) / 4095);
if (((atan(return_rise[2]))*180)/PI >= 2)
//stop counter
tim = TC_ReadCV(TC1, 2);
TC_Stop(TC1, 2);
Serial.println(tim);
Serial.println("Stop timer");
Serial.flush();
j = 0;
goto return_signal_1;
j++;
Could you help my to configure clock correctly?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
