Topic: Is there a SRAM extension Shield? (Read 3189 times) previous topic - next topic
Andreas1984
Hello,
I need a significant amount of SRAM for my project (around 10Mbyte)...
Currently I am using an SD-card to read data from - tough this is problematic, because after each 512 bytes, the SD-Card has to reload data, and is causing a 1mS delay.
I want to avoid this, one way would by to transfer the data from the SD-Card to the SRAM, in some cases it could be a huge amount of data - up to 10 MB...
Is there an easy way to extend the SRAM of an Arduino DUE?
Kind Regards
robtillaart
have you checked - http://shieldlist.org -
Rob Tillaart
Mr_arduino
As far as I am aware this is impossible due to the fact that the arduino DUE does not even have all pins broken out. It is quite a shame that they would make such an expensive product and not even break out all pins.
pito
#3
Jan 18, 2014, 11:26 pm Last Edit: Jan 19, 2014, 12:26 am by pito Reason: 1
What read/write speeds do you expect?
Many times discussed here - for accessing the sdcard fast and in regular intervals you have to implement an FIFO buffer.
See for example NilRtos demo. An sdcard may have 10-250ms write latency anytime.
So the calculation is easy:
You need a FIFO N bytes deep, where (worst case):
N = 0.25sec * wr_data_rate [bytes/sec]
For example to write 100kB/sec into the sdcard you need a FIFO 25kB large(deep). This will allow you to write without overruns.
Search this forum for "FIFO".
http://forum.arduino.cc/index.php?topic=144715.msg1092515#msg1092515
CrossRoads
FIFOs are hard to find - I wanted some for audio for a past project, they were hard to find and pricey.
Putting together a bank of memory chips to get 10Mbyte wouldn't be hard.
http://www.digikey.com/product-detail/en/23LC1024-I%2FSN/23LC1024-I%2FSN-ND/3543084
Just need a bunch of them.
With an external address latch, data latch, and maybe shift register if you want to keep serial access, can go with bigger parallel address parts & use less chips overall:
http://www.digikey.com/product-search/en?pv16=11422&FV=fff40027%2Cfff80434%2C2380073&k=sram&mnonly=0&newproducts=0&ColumnSort=0&page=1&stock=1&quantity=0&ptm=0&fid=0&pageSize=25
http://www.digikey.com/product-detail/en/CY62148ELL-55SXI/CY62148ELL-55SXI-ND/1784966
etc.
pito
#5
Jan 19, 2014, 12:29 am Last Edit: Jan 19, 2014, 12:43 am by pito Reason: 1
The FIFO is implemented on your arduino. You do not need an external one...
With 1284p or Due you can implement large enough FIFO buffer for even your audio streaming :)
With max latencies of 50msecs and 14kB of 1284p ram you can go up to 280kB/sec sustained writing speed to the sdcard.. (provided your 1284p or Due is fast enough)  :P
PS: I ran 333samples/sec (100bytes a sample) with 1284p without a single overrun to a cheap sdcard recently..
CrossRoads
"max latencies of 50mS" - and OP seemed to say 1mS delay was problem.
pito
Long time back I designed a ramdisk (for retrobsd swap file) - with xilinx cpld and 4MB sram. With arduino is the speed ~200kB/sec random wr/read, with larger blocks (ie 512b) 850kB/sec (with pic32 ~6MB/sec, the same with Due probably).
The ramdisk has an 8bit interface + 3 control bits.
ralphnev
willing to share the cpld code ?
a few months ago i started to build a large fifo out of  a AL440B but got distracted / will revisit eventually
