Topic: How to insert bit flipping error Manually in NAND Flash (Read 960 times) previous topic - next topic
sureshmca
Hi All,
I'm using Yaffs FS in my Nand flash, i'm getting bit flip issue.
So i enable the NAND on-die ECC to overcome the bit flip issue. Now i couldn't see the bit flip issue often.
I want to know, is there any way to inserting the bit flipping error manually in the NAND flash by using any script? I need this to check whether the NAND on-die ECC fix the bit flip issue.
Please help me out and let me know any way to do this?
Regards,
Suresh.S
pito
I think while on-die ECC is enabled the bit flip could be introduced by external means only - ie by a radiation source, high temperature, strong emag field, etc..
Graynomad
Can you disable the ECC, write a byte then enable it?
_______
Rob
