Topic: Measuring execution time of functions without Serial.print (Read 829 times) previous topic - next topic
boylesg
I figured out a solution to that other problem I was having with Serial.println distorting the execution time of functions.
I put 14 LEDs on a prototype shield and connected them to 14 digital pins.
Using digitalFastWrite(...) I can then output the difference in calls to micros(), before and after the function, as a binary number on the LEDs.
With this I got an execution time, of one particular function, of around 600us rather than 6-8ms when I was trying to use Serial.print.
pito
You can send the time value via SPI to an external 16bit shift register. You may need maybe 5 usecs to do that...
Caltoa
There is timing measurement somewhere in this sketch: http://playground.arduino.cc/Main/ShowInfo
You could add such a section for timing of the Serial.print().
Serial.print puts the character in a buffer. But if the buffer is full, the Serial.print waits until there is a free place in the buffer. That will slow things down a lot.
robtillaart
If you just want tp measure the time of a function you could do the following
start = micros();
for (int i=0; i< 1000; i++)
   x = f();
t1 = micros() - start;
start = micros();
   x = f();
  x = f();
t2 = micros() - start;
Serial.println(t2 - t1);
this way you subtract the all overhead (excl. interrupts) of the loop to get the time of  f();
Rob Tillaart
Caltoa
That's a very nice solution.
But 1000 Serial.print will not work. Will it work with only 10 Serial.print ?
The buffer is 64 bytes (I think), so that will be 20 each time.
I suggest:
- wait until all serial transfer has finished.
- run 20 times Serial.print in loop with micros()
- run 20 times two Serial.prints in loop with micros()
graynomad
Buy a logic analyser and pulse a pin. Job done.
______
Rob
pYro_65
______
Rob
Yes that is kind of what I do.
For a project that had to have minimal impact I simply toggled a pin which was connected to another Uno. It recorded the time between a high and low. It also removed the overhead of the serial lib and could monitor multiple pins/ timing jobs.
Forum Mod anyone?
https://arduino.land/Moduino/
robtillaart
Maybe not in exact identical code but the principle is sound. Another trick involves using timers directly,
I measured serial print to optimize the performance of printing float's - http://forum.arduino.cc/index.php?topic=179111.60 -
Rob Tillaart
