Topic: ThingSpeak Live Chart, multi channel, second axis, historical data, csv export (Read 22735 times) previous topic - next topic
Mr_ToR
Dear Turgo, (or anyone else)
Could you please help how to define different units for tooltip valueSuffix when multiple series are used?
Right now in your code everything shows up as temperature. I can get it to work in Highcharts examples but non of them includes values being used from Thingspeak since i'm having a bit of a problem understanding how you got thingspeak data to appear in chart. I'm not very good with javascript :-)
The 'series' show like the following in the highcharts example, however the series part in your code is just 'series: []' so i can not figure out where to include that tooltip valueSuffix per series.
        series: [{
            type: 'column',
            yAxis: 1,
            data: [49.9, 71.5, 106.4, 129.2, 144.0, 176.0, 135.6, 148.5, 216.4, 194.1, 95.6, 54.4],
            tooltip: {
                valueSuffix: ' mm'
            name: 'Sea-Level Pressure',
            type: 'spline',
            yAxis: 2,
            data: [1016, 1016, 1015.9, 1015.5, 1012.3, 1009.5, 1009.6, 1010.2, 1013.1, 1016.9, 1018.2, 1016.7],
            marker: {
                enabled: false
            dashStyle: 'shortdot',
            tooltip: {
                valueSuffix: ' mb'
            type: 'spline',
            data: [7.0, 6.9, 9.5, 14.5, 18.2, 21.5, 25.2, 26.5, 23.3, 18.3, 13.9, 9.6],
            tooltip: {
                valueSuffix: ' °C'
Mr_ToR
OK disregard my last message because i got it to work
here is the working code
http://jsfiddle.net/calculathor/oLp97nd1/
however there is only one problem
i just can not get the 'opposite: true' to work for one of the 'yAxis:' data. So both of the Y axises appear on the right side. I just need to get one of the axises appear on the opposite side. Please someone help :-)
Mr_ToR
ok, disregard the last one as well :-)
somehow the code works differently here, i tried 'opposite: false' instead of 'opposite: true' and it worked. apparently all y-axis are 'opposite: true' by default in Turgo's code somehow.
so anyone is free to check it out there :-)
good luck  :D
Alx-I
easydoor
Can someone tell me how can I manually chose the colour for new graphs?
Thx
cweinhofer
Thx
I am wondering the same thing. Anyone know where the line colors are set?
