Topic: > 1 analogRead / analogWrite on Due (Read 2087 times) previous topic - next topic
gpud
having successfully had an LDR (with fading led reading the LDR values) a 100K VR and 10KVR + MPU9150 raw data on x, y,z axis (euler angles) over serial from a Due board to Processing, i had to reinstall my OS since then i have had this problem.........
I had been using 3.3V direct to mpu9150  and used the 5V to a breadboard from which i ran the analog inputs. I now realize that this could have damaged the Due chip. But, i tested each of the Analog pins I'd been using and individually they were all fine. However, if i use more than one VR, or one VR and the LDR, only one of them works. I have double, triple tested the code and  have now moved the 'analogRead and analogWrite (PWM) for the leds' into  separate sketches for testing. I am attaching the last test sketch version i have tried. However, the error is the same on all the sketches - whereas, with identical code previously, i had no problems with this at all (using them as a help reference for graphical representation) -  Now, i have spent almost 2 days trying work out where/how/why the debug readings in the serial monitor, change on both pins readings for the A0 values i.e. on the A1 input analogRead too (or if i try a different one, the same thing). The led also fades with the value of A0, when it is instructed to respond to the other analog input - which doesnt respond to anything.
I have tested the pots, the pins, the LEDs, the connectors. I have also used two different breadboards - i moved breadboards initially but at the moment cant think what else could be wrong.
I have got the instructions in a separate function - but even if i put all the code in the loop function - the same thing happens.
as you can no doubt tell, i am very new to Arduino and would really appreciate some help as I'm baffled
(aslo i'm using floats, as i had all values going to processing and it was easier to use one value data type when splitting the string and converting)
Code: [Select]
//the A0 LDR works with a calibration sketch etc so i've left it out in this version
// const int sensLDRPin = A0;       // pin that the LDR is attached to
//const int ledLDRPin = 9;           // pin that the Red LED is attached to
const int VRhunkPin = A1;
const int ledVRhkPin = 10;
const int VRtenkiPin = A2;
const int ledVRtkiPin = 11;
float sensVRhunkValue;
float VRhunkvoltage;
float sensVRtenkiValue;
float VRtenkivoltage;
// the setup routine runs once when you press reset:
  // initialize serial communication at 9600 bits per second:
  pinMode(ledVRhkPin, OUTPUT);
  pinMode(ledVRtkiPin, OUTPUT);
  digitalWrite(ledVRhkPin,LOW);  //keep leds down on start up
  digitalWrite(ledVRtkiPin,LOW); //keep leds down on start up
// the loop routine runs over and over again forever:
readVRs();
  // print out the value you read:
  Serial.print(sensVRhunkValue);
  Serial.print(": ");
  Serial.print(VRhunkvoltage);
  Serial.print(".  ");
  Serial.print(sensVRtenkiValue);
  Serial.print(": ");
  Serial.print(VRtenkivoltage);
  Serial.println(".  ");
void readVRs()
    // read the input on analog pin A1:
  sensVRhunkValue = analogRead(VRhunkPin);
  // Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
  VRhunkvoltage = sensVRhunkValue * (3.3 / 1023.0);
  analogWrite(ledVRhkPin, sensVRhunkValue);
     // read the input on analog pin A2:
  sensVRtenkiValue = analogRead(VRtenkiPin);
  // Convert the analog reading to 0 - 3.3V
  VRtenkivoltage = sensVRtenkiValue * (3.3 / 1023.0);
  analogWrite(ledVRtkiPin, sensVRtenkiValue);
MarkT
Sounds like the known bug in 1.5.5 with analogRead from more than one pin, either revert to 1.5.3 or download overnight builds.
gpud
thank you  SO MUCH for letting me know - it's mad cos from oct'13 to jan'14 i'll have to go back to the last version of both Processing and Arduino - thank you!
