Topic: Stuck on uploading... (Read 3532 times) previous topic - next topic
dalehand
Hello, I'm newbie here.
Months ago I used the Arduino Duemilanove with Atmega328P-PU, it was working perfectly.
Now it gets stuck on uploading.
I've formated my computer with Windows 7 recently, reinstalled arduino software and installed the FTDI drivers.
When I press the reset button, the L led flashes twice and when appears "uploading" on arduino software the L, TX and RX quickly flashes sometimes then stops on the TX light on, so I don't think is a bootload problem.
I tried the versions 1.0.5 and 1.5.5 in 2 different computers(both with Windows 7).
The program I'm testing is a very simple program:
Code: [Select]
  pinMode(13,OUTPUT);
  digitalWrite(13,HIGH);
  delay(250);
  digitalWrite(13,LOW);
  delay(250);
I'm a newbie on Arduino/eletronics, so I don't have a clue about what's going wrong...
cmiyc
Did you change the board selection in the IDE to Duemilanove?
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
dalehand
#2
Jan 26, 2014, 11:43 am Last Edit: Jan 26, 2014, 11:47 am by dalehand Reason: 1
Thank you for your reply James.
I did it: it is on Arduino Duemilanove or diecemila, with ATmega328 but is not working.
My program compiles and freezes on uploading...
cmiyc
It freezes or returns an error?
dalehand
Well, it keeps saying its uploading and dont show any errors. It stays uploading forever (I left it for 1h and it was still uploading). Only when I remove/reset the arduino it says:
avrdude: stk500_getsync(): not in sync: resp=0x00
dalehand
#5
Jan 26, 2014, 05:41 pm Last Edit: Jan 26, 2014, 06:21 pm by dalehand Reason: 1
Today it appeared one more message for the first time (but it happened only once):
avrdude: ser_send(): write error: sorry no info avail
and this when i removed:
processing.app.debug.RunnerException
   at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:129)
   at processing.app.Sketch.upload(Sketch.java:1672)
   at processing.app.Sketch.exportApplet(Sketch.java:1578)
   at processing.app.Sketch.exportApplet(Sketch.java:1550)
   at processing.app.Editor$DefaultExportHandler.run(Editor.java:2399)
   at java.lang.Thread.run(Unknown Source)
Caused by: processing.app.debug.RunnerException: Problema ao carregar para a placa. Veja http://www.arduino.cc/en/Guide/Troubleshooting#upload para sugestões.
   at cc.arduino.packages.Uploader.executeUploadCommand(Uploader.java:113)
   at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:127)
   ... 5 more
AJITnayak
What kind of peripheral you have been connected   before you getting above error.
For me same issue being raised , this arises 2 reason
1) If the boot loader has been crashed
2)if fat32 driver stopped working. Check whether ur IC is heating up or not.
AMPS
dalehand
Thank you for replying AMPS.
I have no other peripheral conected on my notebook besides arduino. I don't feel anywhere heating on arduino while the eternal uploading...
AJITnayak
Have you tried uploading bootloader using avr programmer.
AMPS
dalehand
No... Could you teach me how to do this, please?
AJITnayak
#10
Jan 27, 2014, 01:03 pm Last Edit: Jan 27, 2014, 01:52 pm by AMPS-N Reason: 1
It just simple
https://www.sparkfun.com/products/9825
and Burn boot loader .You will get boot loader updated succesfully
If didn't worked then replace atmega IC replace with new one and do above step. Which will work
AMPS
dalehand
Okay, I'll try. Just waiting the programmer arrive :)
dalehand
Well, I had some problems bootloading the arduino
I'm using a Mega 2560 to bootload, using this tutorial:
http://www.instructables.com/id/Burn-Arduino-Bootloader-with-Arduino-MEGA/?lang=pt
But I'm receiving this message:
avrdude: stk500_program_enable(): protocol error, expect=0x14, resp=0x50
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
