Topic: Arduino USB host shield pin 3 not working (Read 1 time) previous topic - next topic
Hello everyone,
I recently bought the arduino usb host shield. I wired up some circuits to test out what i can do with it using a 360 controller. What i found out after playing around with it and some research was that i cant use I/O pins 10- 13. The problem is that PWM pin 3 is not responding to the arduino programs i write using it.
I dont know what the problem is....
So i decided to reconnect every pin with jumper wires until i find out when pin 3 would turn off.  I wired up an LED with a HIGH written to pin 3 and started connecting everything from the shield to the arduino. Pin 3 only turned off when i connected the reset ISCP pin from the shield to the arduino.
That seems to be what the problem is, I don't know what to do now....
PaulS
Quote
Which one?
Quote
Because the USB Host shield is an SPI device.
Quote
Perhaps because the timer that is involved has been hijacked for another purpose.
Quote
Perhaps you could give some consideration to posting your code.
The shield is this one: http://www.amazon.com/gp/aw/d/B00CPYSX1M?cache=1390772369&pi=AC_SX110_SY165_QL70#ref=mp_s_a_1_14
The code I used:
Const int LED = 3;
Void setup(){
pinMode(LED, OUTPUT);
Void loop(){
digitalWrite(LED, HIGH);
PaulS
Quote
The code I used:
No, it isn't. That code won't even compile.
For all the details provided about that shield, I hope you got your money's worth. That site is useless. I can only hope that their products aren't.
#4
Jan 27, 2014, 09:27 pm Last Edit: Jan 27, 2014, 09:46 pm by GreatStoneDragon Reason: 1
Umm, why won't it compile....
If it's because of case sensitive, then that is dealt with in the IDE, I just wrote the progress format
PaulS
Quote
No, it isn't.
Quote
The what?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
